BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
01-04-2024, 06:25 PM | #1 |
Drives: BRZ 2018
ProVent air oil separator / catch can anyone?
According to this video
Most of baffled or bronze filter catch cans - Mishimoto included - cause significant crankcase pressure increase which is only bad for the engine. Has anyone installed Provent 100 or 200 air oil separator to tell us his experience as it causes zero pressure increase and has the best air oil separation? |
01-04-2024, 06:56 PM | #2 |
Drives: '23 BRZ
You do not need a catch can or air/oil separator.
The Following 2 Users Say Thank You to ZDan For This Useful Post: | NoHaveMSG (01-04-2024), x808drifter (01-05-2024) |
01-04-2024, 10:14 PM | #3 |
chicken tonight
...or an oil cooler
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
01-05-2024, 03:18 AM | #4 |
Drives: BRZ 2018
Why you believe we don't need AOS or catch cans, have you ever seen in your intake how much oil/carbon build up is there?
Especially for some of us with remap that use less than OEM map the port injectors, so valves are not cleaned the same! |
01-05-2024, 04:01 AM | #5 | |
Drives: '23 BRZ
IMO, you dont need an air/oil separator or catch can, but go ahead if you wanna. |
The Following 2 Users Say Thank You to ZDan For This Useful Post: | Wally86 (01-05-2024), x808drifter (01-05-2024) |
01-05-2024, 04:59 AM | #6 | |
LMGTFY
Drives: 13 FRS, 91 Miata
There is almost none. Far from the OEM port map/timing on my tune. |
01-06-2024, 10:51 AM | #7 |
Drives: Crapcan
How much intake buildup do you think is normal, even for a purely port injected engine? You will always get some.
01-07-2024, 11:17 AM | #8 |
Drives: 2017 BRZ w/PP
I had a provent 200 on my diesel truck before i sold it but it is way overkill for an NA brz. If you are looking for catch cans I would recommend radium. The only issue they have caused was a fitting was made of some type of plastic and yielded. That was in my wrx and radium sent me a metal fitting to replace it.
The Following User Says Thank You to Breadman For This Useful Post: | whataboutbob (01-07-2024) |
01-07-2024, 06:22 PM | #9 | |
Drives: BRZ 2018
Provent uses elastomers in his catch cans non tested on petrol engines anyway so I ordered a cheap aluminum one! |
01-08-2024, 09:14 AM | #10 |
Drives: Crapcan
If you are that worried about it then don’t route the PVC back to the intake.
01-08-2024, 09:27 AM | #11 |
Drives: BRZ 2018
01-08-2024, 12:16 PM | #12 |
Drives: 2013 BRZ HKS Turbo
You'll never feel any difference from adding a catch can (AOS), whether it is "good" or "bad". However, catch cans are for preventative care, in my opinion, to reduce oil fumes being introduced into the intake air, which effectively lowers knock resistance. No car "needs" a catch can. If a catch can is a "solution" to a problem, it is just band aid that will surely result in a negative end.
In addition, for maximum engine efficiency, a vaccum should be pulled on the crank case, especially under high load situations. Depending on engine setup, applying vaccum to crank case can yield over 50 hp, more realistically 1-5 hp (check out some high horsepower Supra's with downpipe venturi ports). This is why it is not a good idea to vent the catch can to the atmosphere, you aren't pulling any vaccum. This is also why it would be a bad idea to add a catch can that is too restrictive, which is what I assume the youtube video is getting at (I didn't watch it). No experience with Mishimoto, but I highly recommend Chase Bay's catch can. No restriction, baffled, and uses a steel mesh filter.
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
01-10-2024, 05:00 AM | #13 | |
Drives: BRZ 2018
01-10-2024, 07:58 AM | #14 |
“Significant pressure increase” does not equal excessive crankcase pressure. All those catch cans do increase crankcase pressure but none created excessive crankcase pressure. I will trade off some more crankcase pressure to reduce blow by in the intake.
Similar Threads | ||||
oil catch can/air oil separator | TOPUTO | Engine, Exhaust, Transmission | 10 | 09-22-2017 10:21 AM |
Air oil separator vs. catch can | snowdog | Forced Induction | 9 | 07-25-2015 09:37 AM |
Perrin Air Oil Separator/Catch Can! FS | Batman | Engine, Exhaust, Bolt-Ons | 8 | 03-31-2014 02:02 PM |
Air Oil Separator? Do I need one? | hmong337 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 21 | 12-31-2013 10:14 PM |
FS: Cusco Oil Catch Can (Separator Type) | howiedoit | Engine, Exhaust, Bolt-Ons | 4 | 12-02-2013 12:47 AM |
