Old 01-29-2023, 09:16 AM   #4299
KxngCorey
KxngCorey's Avatar
Drives: Hot Lava FR-S
I know this is a longshot. but does anybody have this part that they want to get rid of. Spare or otherwise? Was doing some maint. and saw that when my bolt snapped it turned the mounting plate into some trash.
2015 Hot Lava FR-S Kraftwerks Supercharged 329 WHP 259 Tq
KxngCorey is offline   Reply With Quote
Old 05-22-2023, 01:07 PM   #4300
pkat696
Drives: 2013 Scion FR-S 10 Series
California referee smog check?
Anyone in California pass a referee smog check with this kit? If so, any tips and tricks?
pkat696 is offline   Reply With Quote
Old 08-11-2023, 08:47 PM   #4301
GraysBRZ
Drives: Silver 2017 brz limited
Tunes for kraftwerks c-38 kit for 2017 BRZ
Looking for information on where I could get a tune for the kit. I want to purchase the kit and do the install however I have not been able to find anything related to a base map for it.
GraysBRZ is offline   Reply With Quote
Old 08-11-2023, 09:32 PM   #4302
KxngCorey
KxngCorey's Avatar
I'm 10,000 miles in tuned with xero limit
Sent from my SM-S908U using Tapatalk
Old 08-24-2023, 08:12 PM   #4303
GraysBRZ
How would i go about getting a base tune form them?
Old 12-07-2023, 01:27 PM   #4304
Apolllo
Drives: 2018 Subaru BRZ Limited
Does anyone know what the difference is between the 13-16 kit and the 17-20 kit? Would you be able to get a 13-16 kit fit a 2018?
I asked this same question to Kraftwerks, and they just came back with "Intercooler piping is different" which I figured, but didnt answer my question on if it would fit. I dont mind cutting or making a few modifications to get the piping to fit...I just dont want to have the intercooler pipes sticking out the side of the bumper or something lol
Apolllo is offline   Reply With Quote
Old 01-07-2024, 02:48 PM   #4305
jflogerzi
jflogerzi's Avatar
the front bumpers are different and thus a slight modification will be needed in my guess with piping
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 01-08-2024, 06:54 PM   #4306
Apolllo
Seemed like it fit up pretty well. The intercooler piping on the driver side was snug, and hitting some metal frame, but I just put some pieces of rubber between them. Other than that seemed fine.
Unfortunately, the Rotrex unit was be bad and seized up. The metal fins busted and made their way through the intake tubes, intercooler, and tiny pieces somehow made it to the throttle body which threw multiple codes in my car. Got burned buying used trying to save a few bucks
Old 04-18-2024, 06:23 PM   #4307
srhode579
Drives: 2013 Ablaze FRS 30K miles.
C38-91 Kraftwerks Racekit Help
Hello! I have been working with a c38-91 kit and am running into an over boosting problem. I have the 95mm pulley attached to the blower and 128mm on the crank.
This kit is making way too boost for my stock frs. I am using the MAP sensor which saying at 7.2k the MAP is reading about 2 bar (~14psi). I obviously ran into fueling issues as the car is stock. To lower the boost I tried the 100mm pulley option from the s2k kit. Unfortunately this pulley is 12mm thicker and contacts the ac compressor.
Has anyone run into this over boosting problem and come to a solution? I don’t want to change my fueling as this is a daily and I’m not trying to break any records.
If I can’t find a solution I will be selling this brand new kit along with some other goodies that came with it (fuel pump, larger injectors, 72mm throttle body).
Cheers
srhode579 is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
