Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-13-2024, 07:37 PM | #1 |
Professional wrench
Drives: 2020 BRZ ST RS
Simple supercharger options??
Hi. I'd like to get a simple, basic supercharger for my 2020 BRZ. I don't want to run bigger boost. 4-5 PSI would be plenty. I am not after a "max attack" kinda thing, just something to wake it up, not overpower it.
My problem is that I can't find anything that's not a complicated, expensive kit that takes a long time to install. Honestly, I'd just want the supercharger, mounting bracket, and a 4-5psi pulley. Not sure if they would need a separate belt or use the stock one. I could get the couplers to the airbox and throttle. I'm thinking a Rotrex C30-64 would be great. Good flow, and capable of enough for what I want. I don't want to run an intercooler because at that low pressure its not needed, and the complexity of the install turns me off. Plus the added cost for minimal gain doesn't attract me. If I need to I will run methanol/water injection. From my experience in boosted engines, I won't need it, but I will probably run it down the road anyway for the other benefits it brings. thoughts? thanks!
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
01-14-2024, 02:53 AM | #2 | |
LMGTFY
Drives: 13 FRS, 91 Miata
2. If you think these are complicated? Boost isn't for you. IE: calling routing in an intercooler complicated. 3. It sounds like your experience is only with older American V8s. If you wanna dive in you're going to have to do it from scratch. (I never understood why the SC kits in general are so fkn expensive for almost all the cars) The only thing OTS would be the SC. Belt/s, bracket, piping. all one off. Then there's the upgraded headers, tune. Headers aren't "needed" but something you should have. |
01-14-2024, 07:50 AM | #3 | |
Drives: FR-S,GTI
01-14-2024, 08:38 PM | #4 | |
Professional wrench
2/3. Nope. I haven't owned a domestic V8 for several decades, tho I do know how to tune those as thats all there was for normal people to hot rod when I started doing it My tuning experience with turbo 4 cylinders is extensive and has gone on for decades. 300-500whp 2.0-2.3 Japanese 4 cylinders is what I have been playing with for nearly 30 years. I simply don't want to complicate this. I work on everyone elses cars all day long and its not fun for me to rip off a bumper to put an intercooler in, especially when most people have trouble putting them back on correctly. And its not needed in this situation. My car is nearly pristine, having about 3k miles on it and I want it to stay that way. Its not some rat rod with zip ties thru the panels. But thank you for your insight. Oh, and its clearly in my signature that my car has a header and overpipe already.
The Following User Says Thank You to JohnH For This Useful Post: | x808drifter (01-15-2024) |
01-14-2024, 08:45 PM | #5 | |
Professional wrench
very interested in the Torqamp thing. Looks like they have made it better now that tech is catching up to the idea. Guys have been trying to do this for some time now, but motor and battery tech weren't really there. I played with it sometime back in the late 90s as well, but my electronics skills are pretty limited. Thing is, its pretty much as expensive as a belt driven SC kit, and its got limited boost up top. I wonder if the electronics could be tweaked to start the thing at higher RPM to keep the batteries and motor cooler longer? Or maybe the impeller size is just too small to flow the air required at higher rpm? I found their website in the Netherlands, and they show a Canadian dealer and a couple of west coast US dealers but the websites are not much help. And with it being over 3000 Euros, I suspect cost will actually be more than just getting a used regular SC kit and modifying it to meet my simpler needs. thanks for your help
01-15-2024, 07:41 AM | #6 |
Looks like you want the non intercooled sprintex supercharger. As simple as you can get and no intercooler.
01-15-2024, 01:30 PM | #7 |
Drives: 2018 Subaru BRZ Limited
Correct me if I am wrong, but all the Rotrex style Superchargers come with a intercooler IE: Jackson, Kraftwerks, HKS, Vortech will come with a intercooler.
Then you have Edelbrock that does not use a intercooler, just has a heat exchanger. I looked up Sprintex and it shows a intercooler...might be another option without. I know you said Supercharger, but what about a Turbo kit? Something like Works stage 1 kit might be what you are looking for. No intercooler, but you do have to install their downpipe. https://store.worksmotorsports.com/W..._p/142.211.htm |
The Following User Says Thank You to Apolllo For This Useful Post: | JohnH (01-22-2024) |
01-15-2024, 01:35 PM | #8 |
Honestly, intercooler might be the easiest part to install of a forced induction kit. Like drifter said, if the intercooler installation is the part worrying you, might not want to go down the FI route. Any forced induction kit is going to ask you to take off the bumper during installation anyways to remove the factory airbox.
01-15-2024, 03:10 PM | #9 |
Master Collaborator
I installed my Harrop without removing my front bumper, although it would have been easier had I had it on a lift for the air-to-water intercooler. If you can replace an intake manifold, you can install a Harrop.
The Following User Says Thank You to FR-S2GT86 For This Useful Post: | JohnH (01-19-2024) |
01-15-2024, 04:04 PM | #10 |
Drives: 2015 BRZ 2004 SVT Cobra
Second vote for non intercooled Sprintex. I have the intercooled one and it was easy to install.
01-15-2024, 04:41 PM | #11 |
friendly
Drives: 17' 86
forcing compressed hot air into a high compression engine sans an intercooler seems like a recipe for a bad time.
Seek comfort in discomfort.
01-15-2024, 10:03 PM | #12 |
Drives: BRZ ts
You already have headers, is ethanol available in your area? Just do that.
01-16-2024, 10:04 AM | #13 |
Guy doesn't sound like he's interested in racing it or driving it hard constantly. As long as common sense is used and he has a good tune it will be fine. If it is a worry still then e85 can help keep it cool.
The Following User Says Thank You to EvilPenguin04 For This Useful Post: | alphasaur (01-18-2024) |
01-16-2024, 10:48 AM | #14 | ||
LMGTFY
A flex fuel kit and a tune since OP already has headers is going to be way cheaper and easier. |
Similar Threads | ||||
FI options: Turbo or Supercharger | Misha235 | Forced Induction | 44 | 06-05-2020 09:31 AM |
DC Sports cat back review and new supercharger options for the 86 | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 02-09-2017 06:17 PM |
Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
