Old 06-21-2021, 08:18 AM   #295
Autoxer62
Thanks, now I know they're specific to the newer cars. I did notice the front side protection, however I know a couple folks who broke them out from the backside (eat a cone with the front tire, tears out the fender liner too). Might not be an issue with the smaller units, but at least for the moment I can move it down my priorities.
I'll look through the thread for the parking light wiring update, it looks like I'm not the only one that wants a parking/fog setup.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 06-22-2021, 09:39 AM   #296
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
This may have what you're looking for (even though it's for the early cars). Otherwise it at least will get you headed in the right direction.
Video could probably be half as long as it is because they spend a lot of time not doing the thing the video is about (in typical vlogger fashion), but
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Autoxer62 (06-23-2021)
Old 05-16-2022, 11:58 PM   #297
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Looking to swap my 2016 BRZ front end with a 2017+ front end and have a couple of questions:
1) it looks like the plugs are different between 13-16 BRZ and 17+ BRZ fog lights? Will I need a harness or does someone make an adapter?
2) is OEM the only good fog lights for 2017+ BRZ? or does someone make an adapter? The Morimoto XB are nice but only fit '13-'16
Jyn is offline   Reply With Quote
Old 02-07-2024, 03:56 AM   #298
.RSG.
.RSG.
Drives: 2012 GT86 GT
dont know if been asked but I can't find in search.
I am upgrading the Australian GT low spec 6 pin (FR-S) headlight to the GT-S high spec (HID) Headlight.
I have connectors and pins. I can get DRL etc. But I cannot get the LED to work with the PARK Light setting.
Any help is appreciated.
the BRZ diagram has not helped.
the AU GTS headlight only has 7 pins on the headlight 8 pin plug. pin 1 is empty.
Any ideas on a diagram. I can supply what ive done to date
IF I get this working ... I WILL create a you tube vid, because there's nothing up there.
.RSG. is offline   Reply With Quote
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
