02-08-2024, 10:06 AM | #9927 |
helmholtz resonator
Drives: '15 ultramarine
Yep. Small in an Exige too. Have to wear ballet slippers.
02-08-2024, 10:25 AM | #9928 |
LMGTFY
Drives: 13 FRS, 91 Miata
Have too...
02-08-2024, 10:30 AM | #9929 |
Drives: 1993 Caterham HPC Evo
Yep but, you still have more room than I will in my seven. You at least have room for a dead pedal to rest your left foot on. I'll have to do some adjusting and modding to move the brake and clutch pedals to the right. This so I can turn my ankle and slid my left foot past the clutch like in the other Seven that missed out on.
02-08-2024, 10:44 PM | #9930 |
Drives: 2017 BRZ
Huh. Really now, size doesn't matter. It's all in the technique.
The Following 3 Users Say Thank You to cjd For This Useful Post: |
02-09-2024, 02:46 PM | #9931 |
Drives: Crapcan
I guess I shouldn’t say the pedal box is too small. With the brake pedal so close to the gas it is very uncomfortable to get my feet that close together. Of course I would have a difficult time with heel toe. Should probably come up with a brake pedal cover that extends to the left.
02-09-2024, 04:09 PM | #9932 |
Because compromise ®
Drives: Red Herring
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | Spuds (02-09-2024), Ultramaroon (02-09-2024) |
02-09-2024, 04:14 PM | #9933 |
chicken tonight
Wow!
02-09-2024, 06:07 PM | #9934 |
Drives: 2018 Subaru BRZ
I knew I must’ve had a leak somewhere on the exhaust and sure as shit I did. Replaced the gaskets the Motiv OP came with for some grimspeed ones, tightened everything, but the leak is still there, between the OP and the front pipe. Maybe a double gasket?
02-09-2024, 06:21 PM | #9935 |
chicken tonight
Double gasket is ghetto. Pull them both and find the issue with Prussian blue or dry erase marker. I bet you can work it out with proper use of a bastard file. Lap the two faces together if you want to be really artistic.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
02-09-2024, 06:33 PM | #9936 | |
Just the tip
Drives: 2017 DGM BRZ
While my exhaust never leaked to begin with (perrin resonated), I read that adding a bit of copper high temp RTV to a flat gasket exhaust connection can help ensure a good seal. So I did... 3 years later and it's never leaked. The annoying part was having to let it sit and cure for 24 hours before I could start the car again. Now it may not have ever leaked without it... but it didn't hurt. |
The Following 2 Users Say Thank You to wolffbite For This Useful Post: | spcmafia (02-09-2024), x808drifter (02-10-2024) |
02-09-2024, 06:35 PM | #9937 | |
Drives: Crapcan
https://catalog.remflex.com/category_s/31.htm proper way is to lap the flanges
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post: |
02-09-2024, 07:13 PM | #9938 | |
Which one am I looking at. I don’t see anything for the FA20 |
02-09-2024, 07:23 PM | #9939 | |
Im assuming you used the RTV seal in lieu of the gasket? |
02-09-2024, 07:52 PM | #9940 | |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (02-10-2024) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
