01-08-2024, 02:09 PM | #253 |
Drives: '13 BRZ TLM Spec
Possibly....
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
02-08-2024, 09:47 PM | #254 |
Does anyone have a picture of the actual cylinder heads from an FA24 from a BRZ/GR86?
I ask because I have an idea that has been brewing in my head.... FA24 block and cylinder heads with FA20 cam carriers, cams, front timing cover and oil pan (upper & lower). IF, and I say IF, this all goes together this would be a drop in FA20 replacement. It obviously would need a tune to make it happy but based on parts diagrams only it looks feasible. I have the ability to try and assemble this...looks like about $5k in parts (FA24 short block + L & R FA24 cylinder heads. I have a donor FA20 to get the cams, carriers, front timing cover and oil pans from. Anybody want to donate $ towards the parts, or donate an FA24, to see if this works? I'll put up $2500 of my own money....
02-09-2024, 06:30 AM | #255 | |
Drives: 22 BRZ limited
02-09-2024, 08:52 AM | #256 |
Appreciate it, I've got access to the entire Subaru Service Manuals as well.
02-09-2024, 12:57 PM | #257 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Might be interesting as a proof of concept.
Using a non-OEM tune going forward as a marketing leader may be difficult. It could fly in Florida. Will be hard to pass a smog test elsewhere. Track only transported would likely work for the time being. Does using 20 cams offer some sort of advantage over the 24's?
"I gotta rock." -- Charley Brown |
02-09-2024, 02:23 PM | #258 |
chicken tonight
But there's only space for four.
02-09-2024, 05:30 PM | #259 | |
Drives: 2015 FR-S
@Kevin Vo tore down his GR86 you can ping him, I've seen a few more FA24D engine tear downs. Maybe you guys do a collab for YouTube, he needs content
02-09-2024, 05:41 PM | #260 | |
02-09-2024, 06:01 PM | #261 | ||
The Following User Says Thank You to Opie For This Useful Post: | bcj (02-09-2024) |
02-09-2024, 06:06 PM | #262 |
Drives: None
There is a guy in the FT86Club Discord that has a 2017+ car running a FA24 longblock with few FA24 sensors and a few repinned wires. Are you sure they even need to be swapped?
02-09-2024, 08:55 PM | #263 |
For a 2013 - 2016 car, yes.
The Following 3 Users Say Thank You to Opie For This Useful Post: |
02-09-2024, 09:44 PM | #264 |
Drives: None
Sorry, I missed the part where that year range was mentioned.
The Following User Says Thank You to RedReplicant For This Useful Post: | Opie (02-10-2024) |
02-10-2024, 01:33 PM | #265 |
Drives: Crapcan
I have a whole spare long block I got for free. 2013. I can get you whatever parts you need in it. Keep in mind, my understanding is that the cam trigger wheels may not bolt up to the fa24 cams. RS Motor’s is making different ones. Here is a picture they posted on FB. May be able to mod the stock ones to work but IDK.
02-10-2024, 07:23 PM | #266 | |
The Following User Says Thank You to Opie For This Useful Post: | bcj (02-12-2024) |
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
