Old 03-05-2024, 10:05 PM   #15
B00STED86
Drives:
Originally Posted by x808drifter View Post
Please clarify.
Is the new tune for the ID1050X's?
You need a working tune for those injectors. Don't worry about anything else yet.
Yes. The new tune is for the ID 1050x
An error must have occurred or I did something wrong. I’m getting a error stating that the ECU VIN () does not match ROM VIN
B00STED86 is offline   Reply With Quote
The Following User Says Thank You to B00STED86 For This Useful Post:
x808drifter (03-05-2024)
Old 03-05-2024, 11:46 PM   #16
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by RedReplicant View Post
This is not my experience, whatever you're experiencing more than likely isn't the injectors. I am running them on my K24 swapped car, it idles like stock and there are zero issues starting hot on the scales at impound or anywhere else.
do you have Brz /gt86 ECU with your swap motor?
if not, then this is entirelly useless as it s not same tune and same logic and same injection splitting
this car, if the tuner doesn t put active work into it to make it stable, gives idle problems with big injectors
there is a brief moment when warm specially, that the car will idle for some seconda only with PI but car is warm and low idle speed so the big injectors struggle to mantain afr since they d have to inject a very small amount of fuel and they are not able to provide it nicely because it s out of their linearity range
Old 03-05-2024, 11:50 PM   #17
tomm.brz
you need ecutek support. write to ecutek support you can find the email easily, bypass even delicious you ll make it faster
another guy had same issue, he flashed baxk to stock and license was wiped somehow
and then ecutek will give anothwr license for free as long aa you provide the log they will ask you
Old 03-06-2024, 11:04 AM   #18
RedReplicant
Drives: None
No, but I also ran ID1050X when my car was FA20 on stock BRZ ECU with Ecutek and it idled like stock and did not have an issue starting hot either.
RedReplicant is offline   Reply With Quote
Old 03-06-2024, 11:05 AM   #19
B00STED86
Drives:
Thank you for the information. I will be send them and email right now.
Old 03-06-2024, 11:32 AM   #20
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pretty sure Delicious is familiar with the platform.
Or do they have more than one person making the tunes now?
They should be familiar with it. SO familiar that maybe they've grown used to generic latency and adjustment settings? I'm sure they do great, but everyone makes mistakes.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
tomm.brz (03-06-2024), x808drifter (03-06-2024)
Old 03-06-2024, 03:06 PM   #21
B00STED86
Drives:
Stalling after ID 1050X install and new tune
So EcuTek said that whoever did the previous tune (I don’t have a way to contact the previous owner) deleted the VIN from the ECU.
How do you go about putting that information back on to the ECU? Can a dealership do that, or can I take it to any shop that has a scan tool?
Old 03-06-2024, 04:14 PM   #22
tomm.brz
then it was good tuned... i m not saying it s impossible, i always tuned them good too
i was just saying that it's kind of easy to have them behave bad on warm start in this car, and i ve seen it more than a couple of times with that particularly tuner he went to
RedReplicant (03-06-2024)
Old 03-06-2024, 04:15 PM   #23
tomm.brz
it is doable with techstream
https://www.ft86club.com/forums/showthread.php?t=102810
or by any dealer with the official software so only officials Toyota or Subaru, either techstream or ssm3
B00STED86 (03-11-2024)
Old 03-06-2024, 04:17 PM   #24
tomm.brz
they are basically canned tune
it s more complicated than just that, but actually it is how it is to me
The Following 2 Users Say Thank You to tomm.brz For This Useful Post:
DarkPira7e (03-06-2024), RedReplicant (03-06-2024)
Old 03-06-2024, 06:27 PM   #25
DarkPira7e
DarkPira7e's Avatar
That was my feeling as well, I just didn't want to be so harsh, hahaha
Old 03-08-2024, 12:53 PM   #26
B00STED86
Drives:
Thanks for all of the great information. I ordered a cable and will download the software.
Old 03-10-2024, 03:10 AM   #27
B00STED86
Drives:
Anyone have have or know where I can get a key for techstream v18? Cant find anything online.
I also need the MCI for TOYOTA TIS driver. Everything I found online had dead links or they were flagged by anti virus.
A disk came with my mini vci cable I ordered, but of course I don’t have a CD Rom drive on my PC
Any help would be greatly appreciated. I need to get this VIN programmed in so I can flash my tune!
Old 03-11-2024, 01:49 AM   #28
B00STED86
Drives:
Problem has been solved. Thanks for the guidance.
Ordered a mini vci and got techstream to work on my tablet.
Was able to write the VIN to the ECU and then flash the tune.
DarkPira7e (03-11-2024)
FS: Injector Dynamics 1050x injectors w/ wiring adapters EddyEggnog Engine, Exhaust, Bolt-Ons 6 02-27-2024 04:35 PM
1050x leak IsaiahW BRZ First-Gen (2012+) -- General Topics 3 04-09-2021 10:28 AM
LF: DW 770 or IC 1050X injectors kev0 Want-To-Buy Requests 2 03-16-2021 12:56 PM
Car is stalling on start after Intake+header and a tune install. WinterWolf Engine, Exhaust, Transmission 6 10-04-2019 08:44 AM
Sluggish/Stalling After aFe Intake Install FR-S Matt Engine, Exhaust, Transmission 6 01-15-2013 08:57 PM
