Old 03-27-2024, 05:02 PM   #43
KiK
KiK's Avatar
Drives: 19’ GT86
Originally Posted by J95 View Post
Hey man, for me also the car does not behave well, but as I wrote above, I believe there is something wrong with my installation. I have to take it to the mechanic and then Id be happy to share some thoughts regarding the setup.
Actually, I talked with KW and maybe I can get a replacement springs of 50-170 to substitue my current 50-200 that I have at the front. Then I should be able to lower the car more (as I wrote, it dropped only like 20-25mm at it is already in its lowest position). @Racecomp Engineering do you think it is a good workaround?
I have the following setup:
Front: rebound 10 clicks from full stiff, bump 7 clicks from full stiff
Rear: rebound 9 clicks from full stiff, bump 8 clicks from full stiff
I have aprox. 40mm lowered (and had to jack up the front quite a bit).
The ride quality is great with this setup.
Can you show a picture of your front coils? I found it very weird as my fronts were actually really easy to slam.
KiK is offline   Reply With Quote
The Following 2 Users Say Thank You to KiK For This Useful Post:
J95 (04-02-2024), Racecomp Engineering (03-28-2024)
KW Clubsport 3-way Valving TRAKRAVN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-20-2019 10:45 PM
Using KW Clubsport top mounts for KW V3 thpark93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-20-2019 11:39 AM
Tein SRC vs. KW clubsport 86wtywly Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 04-02-2017 04:55 PM
