04-05-2024, 10:10 AM | #239 | ||
For the traction mod install, I do recommend supporting the subframe with a jack (or a big strong friend if you're on a lift) even doing it 1 side at a time. Just to be safe and it does make it slightly easier. Not a lot of extra effort to do it that way. I do also recommend getting the STI pillowball trailing arm to go along with this mod if you can. Certainly not required but I think it really makes the most of the change. - Andrew |
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
04-05-2024, 10:20 AM | #240 |
Drives: Toyota GT86
Cool so what's the point of loosening the two smaller bolts that connect on the body side ? I would think removing the big bolt would be enough. That bracket doesn't need to move as the traction mod connects to it.
It's not a major deal but I know one of my smaller bolts is stripped so I am hoping to not touch it lol. Else I need to get a tap/die kit along with a new bolt lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-05-2024, 10:55 AM | #241 | |
Drives: 2018 BRZ
Timestamp at 3:25 (damn embedding not doing the timestamp right...). |
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | autoracer86 (04-05-2024) |
04-05-2024, 11:04 AM | #242 | |
Drives: '22 BRZ
I couldn't find the STI pillowball trailing arms in stock anywhere when I did mine
04-05-2024, 11:15 AM | #243 | ||
- Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | autoracer86 (04-05-2024) |
04-05-2024, 11:44 AM | #244 | |
Drives: Toyota GT86
I am pretty sure I can get away with it I did ask MCA for instructions to see if I am missing something
04-05-2024, 11:50 AM | #245 | |
Drives: Toyota GT86
https://www.rhdjapan.com/sti-trailin...-ball-zc6.html Thanks for the heads up on the bolts!
04-05-2024, 12:15 PM | #246 | |
- Andrew |
04-05-2024, 12:40 PM | #247 | |
Drives: 17 Asphalt 86
Part ordered, I'm doing SPC toe arms at the same time, I may as well refresh everything while Im there Last edited by RToyo86; 04-06-2024 at 08:21 AM. |
04-05-2024, 01:11 PM | #248 |
Drives: 2018 BRZ w/Performance Package
04-05-2024, 01:18 PM | #249 |
Drives: Toyota GT86
I don't think they are
04-05-2024, 01:24 PM | #250 |
They aren't, my signature is old...this car is very much beyond STX legal at this point...
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | strat61caster (04-05-2024), TurboLag23 (04-10-2024) |
04-05-2024, 09:04 PM | #251 | |
Also having those two small bolts loose allows you to wiggle the bracket side to side to make sure the big bolt threads back in perfectly. Since you have a small bolt that’s been stripped I would probably just leave it tight and make sure the subframe is strongly supported on that corner. |
The Following 2 Users Say Thank You to norcalpb For This Useful Post: | autoracer86 (04-06-2024), Ohio Enthusiast (04-05-2024) |
04-06-2024, 01:15 AM | #252 |
Drives: Toyota GT86
Yeah that makes a lot of sense. I was planning to support the frame anyway and was kinda surprised they didn’t. Thanks !
Similar Threads | ||||
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 02:49 PM |
"Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
