04-26-2024, 11:59 AM | #267 |
Drives: Toyota GT86
Ordered Trailing arms and MCA traction mod @RToyo86 did the arms come with new bolts ? The front bolts in your picture look new
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-26-2024, 02:43 PM | #268 | |
Drives: 17 Asphalt 86
The Following User Says Thank You to RToyo86 For This Useful Post: | autoracer86 (04-26-2024) |
04-28-2024, 07:40 PM | #269 |
Not everything is roses over here with the MCA.
I have wheel rub at bump with 17x10 due to correction. Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | kevaughan (05-05-2024) |
04-28-2024, 09:35 PM | #270 |
Drives: 2019 BRZ / E36 325is
yikes, maybe just trim the tab on the STI arm?
23 GR86 Halo MT Prem - Racecomp Engineering SS-2 - Sayber Designs - Voltex - RE71RS - Project Mu |
04-28-2024, 09:40 PM | #271 |
Yup. Grinder wheel to the rescue Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
The Following 4 Users Say Thank You to M0nk3y For This Useful Post: |
04-29-2024, 06:31 PM | #272 |
04-29-2024, 06:53 PM | #273 |
Drives: Toyota GT86
I wouldn't be surprised if it had something to do with the 17x10 wheels he runs.
04-29-2024, 08:05 PM | #274 |
04-30-2024, 08:17 AM | #275 | |
I have MCS Suspension, so rear bump travel is quite extensive compared to any other OTS shock.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | autoracer86 (04-30-2024) |
04-30-2024, 08:32 AM | #276 |
Drives: Toyota GT86
Ah okay well seems like the fix was easy enough. Thanks for the explanation
04-30-2024, 04:27 PM | #277 |
Could have sworn looking at rear end it is a touch lower but I did not measure to get definitive answer. I have photos from initial install of B6 on yellows with OEM wheels. Looks close from the photos.
04-30-2024, 06:34 PM | #278 |
Drives: Toyota GT86
It seems to be that the ones reporting a change in ride height are running stock or lowering springs.
I don't think I seen anyone running much higher than stock rear spring rates report a change or maybe they never noticed lol I will be taking measurements before and after hopefully there is no change
The Following User Says Thank You to autoracer86 For This Useful Post: | DocWalt (04-30-2024) |
04-30-2024, 06:42 PM | #279 |
Drives: 2020 BRZ Sport Tech RS
FWIW, I had no ride height change when I initially installed the V1 MCA Traction Mod on my stock Performance Pack suspension.
Can't comment on any change with lowering springs, because I installed my H&R springs (on stock dampers) after the Traction Mod was already installed, and same with my RCE SS1 coilovers.
The Following 6 Users Say Thank You to Tatsu333 For This Useful Post: | autoracer86 (04-30-2024), DocWalt (04-30-2024), kevaughan (05-05-2024), PulsarBeeerz (04-30-2024), Racecomp Engineering (04-30-2024), RToyo86 (05-07-2024) |
05-07-2024, 11:37 AM | #280 |
I've had mine installed enough to leave some impressions on the street.
Rear end feels a bit more sophisticated, less bothered by bumps. I tested on throttle grip mid corner on familiar bumps with my regular commute and noticed the car doesn't bounce around when I try to get the rear to break free. This morning I got the Conti's to break free and the rear just squats and is less dramatic. Previously rear end would react more to the bump which could upset the rear suspension requiring quicker snap of counter steer. |
The Following 4 Users Say Thank You to RToyo86 For This Useful Post: | autoracer86 (05-17-2024), norcalpb (05-08-2024), StraightOuttaCanadaEh (05-09-2024), Tatsu333 (05-10-2024) |
Similar Threads | ||||
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 02:49 PM |
"Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
