04-27-2024, 08:02 AM | #295 |
Drives: Crapcan
Any kind of warranty on it?
04-27-2024, 10:30 AM | #296 |
Drives: 2013 frs base
That's a good question. A couple of other things come to mind too. Like: Does the engine come with a flywheel and will my pressure plate work with the 22+. Can RS send me a tune? I'd like to have them check the oil pickup for silicone too.
I know it sounds expensive but $6k for the engine, $500 shipping, $700 for the kit. The rest is labor, tax, etc. |
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (04-27-2024), Ultramaroon (04-27-2024) |
04-27-2024, 02:20 PM | #297 | |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (04-28-2024) |
04-27-2024, 05:24 PM | #298 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (04-28-2024) |
04-28-2024, 10:05 AM | #299 |
He is going to pull the pan and he said that there is usually more silicone in the timing cover than the pan. Ron says my 2013 flywheel (hence clutch) will work. Drop in means drop in Cam plates and modified wiring harness.
He said no warranty because he knows how this cars are driven. I will clarify that should I have a rod knock on start up that I would have some recourse. |
The Following 4 Users Say Thank You to blsfrs For This Useful Post: |
04-30-2024, 10:04 AM | #300 |
For better or worse, I'm going to go for it. I'll send updates.
The Following 14 Users Say Thank You to blsfrs For This Useful Post: | alex87f (05-04-2024), alphasaur (05-03-2024), autoracer86 (05-01-2024), bcj (04-30-2024), JBezugs (05-01-2024), kmbkk (04-30-2024), NoHaveMSG (04-30-2024), Ohio Enthusiast (04-30-2024), redlined600 (05-09-2024), RedReplicant (05-06-2024), RToyo86 (04-30-2024), Tatsu333 (04-30-2024), Teseo (04-30-2024), Ultramaroon (04-30-2024) |
05-03-2024, 01:51 PM | #301 |
Drives: 2015 FR-S
Also could be the start of your YouTube career. Start with the annoying "What's up guys, its your boy blsfrs here with another FA24 engine swap video! Make sure to hit like subscribe and hit the bell icon...blah blah blah"
05-03-2024, 02:31 PM | #302 |
If this works as anticipated, the credit goes to RS Motors. I'm just spending the money and doing the grunt work of putting the engine in my car.
The Following 5 Users Say Thank You to blsfrs For This Useful Post: | kmbkk (05-05-2024), NoHaveMSG (05-03-2024), T-Steve (05-06-2024), Teseo (05-03-2024), Ultramaroon (05-03-2024) |
05-09-2024, 12:43 PM | #303 |
Drives: None
The Following 12 Users Say Thank You to RedReplicant For This Useful Post: | alphasaur (05-13-2024), autoracer86 (05-09-2024), blsfrs (05-10-2024), new2subaru (05-10-2024), NoHaveMSG (05-09-2024), removedonut (05-09-2024), Sevs753 (05-09-2024), T-Steve (05-09-2024), Tatsu333 (05-10-2024), Teseo (05-09-2024), Ultramaroon (05-09-2024), villainous_frx (05-09-2024) |
05-10-2024, 10:21 AM | #304 | |
Edit: Duh. I just read the entire page. Last edited by blsfrs; 05-10-2024 at 10:27 AM. Reason: Duh. |
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | RedReplicant (05-10-2024), Ultramaroon (05-10-2024) |
05-10-2024, 12:25 PM | #305 | |
Drives: 2022 Toyota GR86 Premium 6MT
(also hi. i am the one building those swap kits lol. happy to answer any questions about the swap) |
The Following 11 Users Say Thank You to removedonut For This Useful Post: | alphasaur (05-13-2024), autoracer86 (05-10-2024), bcj (05-10-2024), blsfrs (05-10-2024), pope (05-14-2024), RT-BRZ (05-10-2024), RToyo86 (05-13-2024), Spankopotomous (05-12-2024), Tatsu333 (05-13-2024), Teseo (05-10-2024), Ultramaroon (05-10-2024) |
05-10-2024, 08:03 PM | #306 | |
Drives: BRZ, Canyon
For the 13-16 kit, we will be able to use the stock ECU, correct? I assume so but i just want to be sure |
05-11-2024, 12:42 AM | #307 |
The Following 7 Users Say Thank You to removedonut For This Useful Post: | blsfrs (05-12-2024), jflogerzi (05-17-2024), Sevs753 (05-11-2024), Spankopotomous (05-12-2024), T-Steve (05-12-2024), Teseo (05-12-2024), Ultramaroon (05-12-2024) |
05-11-2024, 12:48 AM | #308 |
Drives: BRZ, Canyon
Similar Threads | ||||
FA20 vs FA24 | Zata | Engine, Exhaust, Transmission | 15 | 06-01-2023 10:18 AM |
FA24 In-Depth Look | Kona61 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 36 | 10-11-2021 08:27 AM |
Second Gen Swap? FA24 | AutoNewb | Engine Swaps | 86 | 07-06-2021 10:55 AM |
FA24 Mix n Match | RiceCracker86 | Engine, Exhaust, Transmission | 1 | 04-18-2019 03:59 PM |
Incoming... | MisterSheep | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 04-02-2016 12:33 AM |
