Member's Car Journals Car journals by our members. |
05-08-2024, 02:08 AM | #29 |
Drives: Toyota GT86
Nice thread and welcome back. Curious to hear your thoughts on those exhaust hangers. I didn’t even know that was a thing lol
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
The Following User Says Thank You to autoracer86 For This Useful Post: | Muchikori (05-09-2024) |
05-09-2024, 02:52 PM | #30 |
Smiling
Drives: BRZ 2018
More JDM goodness
Got some pedal extender and some engine bay dressups! Probably gonna install the cusco pedal over the weekend
The Following User Says Thank You to Muchikori For This Useful Post: | villainous_frx (05-09-2024) |
05-09-2024, 04:05 PM | #31 |
I just installed the Cusco pedal last week and attended a track day. Very noticeable difference. Do yourself a favor pull the pedal assembly out of the car and attach the pedal extender on a bench. Super easy off the car but I couldn't imagine doing it in the car due to the limited space. 2 10's(or 12's, I don't recall) and 1 connector and it pulls right out.
I may add some washers behind the mounting assembly to raise the height up about 2-4mm's as well at some point. |
The Following User Says Thank You to 2.2Lude For This Useful Post: | Muchikori (05-09-2024) |
05-09-2024, 04:25 PM | #32 | |
Smiling
Drives: BRZ 2018
Hey hey thanks for the reply. And thanks for the welcome back! I havent installed it yet but the concept kind of makes sense. From what i read the stock hangers cancel out the exhaust resonance for the stock exhaust. The new ones i got cancels out / dampens the resonance for after market exhausts. Im assuming since its a lot deeper. Which in turn lessens the droning. Part# is: 44066AJ010 if youre interested Ill definitely put my thoughts here once i install them (maybe this weekend)
The Following User Says Thank You to Muchikori For This Useful Post: | autoracer86 (05-09-2024) |
05-09-2024, 04:26 PM | #33 | |
Smiling
Drives: BRZ 2018
05-09-2024, 04:43 PM | #34 | |
05-09-2024, 04:55 PM | #35 | |
Smiling
Drives: BRZ 2018
Thanks thanks i might have to raise it with the washers i have lying around!
The Following User Says Thank You to Muchikori For This Useful Post: | 2.2Lude (05-09-2024) |
05-13-2024, 11:49 PM | #36 |
Smiling
Drives: BRZ 2018
Thoughts on the "JDM" Exhaust Hangers:
In case you missed it, i am referring to these So I installed it just now and drove around a few times, i did notice that the drone inside the cabin quieted down a little bit but not enough to make it worth importing from Japan I would assume it just changed the frequency of the drone to make it more bearable but what I dont like about it was it introduced a different set of noise inside the cabin: Rattle Somehow there's more panels rattling with this exhaust hangers compared with the stock one. i couldn't identify where it is to the point i already deleted my 3rd brake light and there's still rattle around 3k RPM range Currently debating whether to put the stock back or not. Might depend if i can find the rattle.
05-13-2024, 11:51 PM | #37 |
Smiling
Drives: BRZ 2018
@autoracer86 idk if this tagging thing works but i just installed the exhaust hangers
The Following User Says Thank You to Muchikori For This Useful Post: | autoracer86 (05-14-2024) |
05-14-2024, 12:04 AM | #38 |
Smiling
Drives: BRZ 2018
Cusco Pedal Installed
Thanks to @2.2Lude 's suggestion i was able to install the Cusco Pedal a lot easier than if i left it inside the vehicle. Literally had to juggle between the extender and the actual pedal just to align it properly. I also added 2 washers before i installed the pedal back. and as you can see on the previous picture, i added a washer on the pedal stop just to account for the height change. Overall i think it's a good mod since the throttle is a bit far for me. Definitely need to adjust my footing just so I'm not braking + throttling unless heel-toeing. Another skill im trying to get is how to heel-toe. hopefully this extender would help with that!
The Following 2 Users Say Thank You to Muchikori For This Useful Post: | 2.2Lude (05-14-2024), villainous_frx (05-14-2024) |
05-14-2024, 03:59 AM | #39 |
Drives: Toyota GT86
Thanks for the update. Funny timing as I was reading that older 21 page thread on them lol
The Following User Says Thank You to autoracer86 For This Useful Post: | Muchikori (05-14-2024) |
05-14-2024, 12:52 PM | #40 |
Smiling
Drives: BRZ 2018
Lool yup i was also reading it just now. Seems i have to wait for it to settle to fully see the effects. Hopefully it settles and the rattling goes away!
Similar Threads | ||||
I/H/E/ Parts For My 2018 BRZ tS. Help! | SkyeHack | Engine, Exhaust, Transmission | 54 | 12-28-2017 06:12 PM |
2018 BRZ STI | raven1231 | FR-S / BRZ vs.... | 19 | 06-26-2017 11:39 AM |
2018 BRZ orders | Benji | BRZ First-Gen (2012+) -- General Topics | 16 | 06-24-2017 06:24 PM |
Where are the 2018's ??? | ~el~jefe~ | FR-S / BRZ vs.... | 41 | 05-24-2017 12:03 PM |
