go_a_way1, MisterSheep
Old 04-15-2024, 10:46 AM   #24599
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Installed Stoptech rotors and pads, only got the fronts done. Still need to get the rears replaced. Took a bit to get the original rotors off smh
Sent from my Pixel 8 Pro using Tapatalk
Rican_D is offline   Reply With Quote
The Following 4 Users Say Thank You to Rican_D For This Useful Post:
bcj (04-15-2024), JD001 (04-15-2024), Overdrive (05-02-2024), Teseo (04-18-2024)
Old 04-15-2024, 12:15 PM   #24600
Ohio Enthusiast
Drives: 2018 BRZ
Don't forget that the bolts holding the aluminum skid plate that have a 12 mm head are the right size to thread into the rotors to push them off the hub.
The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post:
bcj (04-15-2024), Lonewolf (05-17-2024), Rican_D (04-15-2024)
Old 04-15-2024, 12:17 PM   #24601
Rican_D
Rican_D's Avatar
I bought some bolts for it, but didn't know that. Thanks for info
Old 04-15-2024, 12:43 PM   #24602
2.2Lude
2.2Lude's Avatar
The brake line bolt also works.
2.2Lude is offline   Reply With Quote
Old 04-16-2024, 02:05 PM   #24603
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
New windshield
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
Old 04-17-2024, 05:39 AM   #24604
54fighting
Drives: 2020 toyota 86
Rotors
Good choice on the rotors!
54fighting is offline   Reply With Quote
Old 04-18-2024, 04:38 PM   #24605
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
It's just a sticker sadly, JDM points will wear off.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
KMA KiCKz (04-18-2024), MJones_RB (04-22-2024), Overdrive (05-02-2024)
Old 04-19-2024, 12:53 PM   #24606
chicken tonight
You will always know.
RToyo86 (05-02-2024)
Old 05-02-2024, 03:05 PM   #24607
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I bought a set of those a few years back, along with some braided stainless lines. Good hardware all around. Never really had a problem with the originals, to be fair, but the replacement feels noticeably better when you have to put your foot in it.
Only issue I've experienced is they do get a little squealy when they get wet, such as after a wash or a lot of rain, and only as you're coming down to that last 1 or 2 mph to a complete stop, where you're not really putting much pressure on the pedal (unless you're panic stopping). It takes a little time and a good amount of application for them to dry off and quiet. I'm curious if you've encountered the same behavior.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 2 Users Say Thank You to Overdrive For This Useful Post:
Busybee (05-02-2024), KMA KiCKz (05-10-2024)
Old 05-06-2024, 11:55 AM   #24608
gt86ser
gt86ser's Avatar
Drives: Toyota 86
New GR86 shift knob
gt86ser is offline   Reply With Quote
The Following User Says Thank You to gt86ser For This Useful Post:
Old 05-10-2024, 11:31 AM   #24609
AutoCulture
AutoCulture's Avatar
Drives: Toyota GT86 (ZN6)
New exhaust
AutoCulture is offline   Reply With Quote
The Following 3 Users Say Thank You to AutoCulture For This Useful Post:
KMA KiCKz (05-10-2024), new2subaru (05-16-2024), RToyo86 (05-13-2024)
Old 05-10-2024, 06:59 PM   #24610
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Running the same stoptech pads/rotors and can also confirm the squeal.
I've also noticed a lot more brake dust compared to the PP pads/rotors but overall performance is much better imo.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 05-14-2024, 10:19 AM   #24611
StraightOuttaCanadaEh
Wes
Installed RCE Tarmac 2 coils with RacerX front endlinks and SPC rear LCAs. First impressions - very comfy ride! None of that constant shimmy, the suspension seems very settled and much more confidence inducing in corners.
I had it set to what RCE recommend in terms of height, so it does look a bit 4x4 unfortunately. I'm at a point in my life where I actually prefer ride comfort over looks so while I *would* like to lower it more, I definitely do not want to do so if it will negatively affect the ride. So if anyone can chime in on this with these specific coils, that'd be great.
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
humfrz (05-14-2024), KMA KiCKz (05-16-2024)
Old 05-14-2024, 09:29 PM   #24612
Welcome to the "Senior" section of the forum ......
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (05-16-2024), MJones_RB (05-16-2024), StraightOuttaCanadaEh (05-16-2024)
Got my VIN today... Enemies BRZ First-Gen (2012+) -- General Topics 63 04-12-2012 10:19 PM
