Old 05-12-2024, 12:42 PM   #1
jamestemperante
Drives: Subaru BRZ
Engine rattle when AC turns on
Hello everyone! Hope all is doing well,
I have a small concern regarding my 2013 Subaru brz manual transmission
I have a rattling sound coming from the engine bay every time my AC compressor turns on. It's like something is lose, The sound goes away if the ac compressor turns off, or if I press on the clutch pedal, also the sound goes away if I shift the shift knob from left to right (neutral position).
here is a video for your reference.
https://www.youtube.com/shorts/2XHeeVqwcj4
Thank you for your time reading this and I hope you can help me.
Note: I recently replace my throw out bearing and clutch. flywheel is still stock, I think? I bought the car used
jamestemperante is offline   Reply With Quote
Old 05-12-2024, 01:52 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
Sounds like normal transmission input shaft chatter due to elevated RPM when the AC compressor is engaged. Do you have any stiffer transmission mount bushings and inserts? These amplify the noise.
Depressing the clutch disconnects the engine from the input shaft, stopping it from spinning and thus not making these noises. Moving the shifter puts some pressure on the forks which might also quiet it down.
The Following 2 Users Say Thank You to Ohio Enthusiast For This Useful Post:
jamestemperante (05-12-2024), tomm.brz (05-12-2024)
Old 05-12-2024, 03:37 PM   #3
jamestemperante
Drives: Subaru BRZ
I think transmission mount is still stock. The rattle comes when I'm not pressing the clutch pedal, when I press on the clutch, the rattle goes away.
Old 05-12-2024, 05:04 PM   #4
tomm.brz
Drives: brz 2017 hksv2
it s still the throw out bearing. Even the newer one is loud i ve changed FOUR of them, all installed by certified subaru techs (not a scammy shitty garage but people who already rebuilt many different brz's) all of them lasted super silent like 15 minutes maybe less
Then all of them started chirping at idle when clutch not engaged
ignore it.
tomm.brz is online now   Reply With Quote
jamestemperante (05-13-2024)
Old 05-12-2024, 07:54 PM   #5
chicken tonight
^^^this^^^
I didn't hear any difference until the fan started. All you're capturing there is wind noise. Make a good recording of the difference you hear between clutch engaged/disengaged. ...inside the cabin with windows closed.
Ultramaroon is online now   Reply With Quote
Old 05-16-2024, 08:50 AM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Or it could be something worse:
This came out of a Dodge Caravan with less than 100K miles on it. It made the same noises as you are describing...AND...still started and ran! Only difference is this had an automatic transmission.
Stranger things have been found.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
jamestemperante (05-17-2024), Ultramaroon (05-16-2024)
Old 05-21-2024, 12:37 PM   #7
jamestemperante
Drives: Subaru BRZ
I'll try to get another video out of it. for the past few days. rattle is a bit less noticable. It usually loud when I use the car during the day when temp are hotter. I live here in the Philippines.
Engine rattle, drivers side engine bay. MikeMont Issues | Warranty | Recalls / TSB 2 01-24-2020 10:27 PM
Ticking/rattling after engine install, turns into...? Alfrz91 Engine, Exhaust, Transmission 0 10-01-2019 01:18 AM
EBC stays on for awhile when engine turns off brosifSmith Software Tuning 3 06-03-2019 01:43 PM
Engine rattle MacJunkie AFRICA 12 04-01-2015 07:12 AM
Moving in neutral....Engine turns off? deedz Issues | Warranty | Recalls / TSB 23 04-23-2013 09:23 PM
