Tracking / Autocross / HPDE / Drifting What these cars were built for! |
05-13-2024, 03:43 PM | #1 |
Drives: 2016 Scion FRS Release Series 2#439
Verus hood vents
Are there any downsides to running Verus hood vents?
I’d like the added venting out of the engine compartment. Especially at the track. I don’t DD the car any longer so it’s seldom out in the rain, except if caught while pleasure cruising or on a road trip.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) Last edited by Muskoka800; 05-13-2024 at 04:33 PM. |
05-13-2024, 04:56 PM | #2 |
Trackspec hood vents are better but will require more of the hood to be cut.
2013 Series 10 FRS #553
05-13-2024, 06:02 PM | #3 |
Wheels for Brains
They don't look gud
I've noticed that hood vents increase the HVAC intake temperature, since it's pulling air out of the bay and dumping it into the windshield/cowl where your cabin intake is. |
05-13-2024, 07:14 PM | #4 | |
That said, in normal driving conditions, there should be minimal to no impact on AC performance. |
The Following User Says Thank You to CSG Mike For This Useful Post: | RT-BRZ (05-13-2024) |
05-14-2024, 08:04 AM | #5 |
I think the Verus Hood Vents are a great first step in hood venting. it's a relatively easy installation, their templates are great to utilize, place and install.
Kyle H. - #89 STX
05-14-2024, 09:25 AM | #6 |
Rust bucket enthusiast
Very happy that I installed mine. If I could do it over, I'd just go Trackspec though. No need for half measures
The Following User Says Thank You to DarkPira7e For This Useful Post: | jflogerzi (05-14-2024) |
05-14-2024, 08:48 PM | #7 |
Drives: 2022 BRZ
I regret not going with the full sized Trackspec vents. I used a Civic Type R vent which helps with cooling, but reduction of lift is likely limited due to the size. I’ll likely end up getting a new hood and getting the full sized BRZ vents
05-18-2024, 12:30 AM | #8 |
Drives: GR86
My Verus hood vent cracked and somewhat melted, would not recommend if you intend to track heavily or run in hot weather.
The Following User Says Thank You to gr8 For This Useful Post: | Wangspeed (05-18-2024) |
05-18-2024, 02:05 PM | #9 |
You cracked and melted ALUMINUM? I think maybe you should double check what you're seeing.
05-18-2024, 06:59 PM | #10 | |
Perhaps he cracked/melted the optional rain guards. They are plastic.
TRD Short Shifter, CTS/EvoX Brakes Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. A052 on 17x8 720Form GTF2 wheels (track) |
05-19-2024, 01:21 PM | #11 | |
Drives: Fr-s
05-19-2024, 08:53 PM | #12 |
Drives: GR86
Yea, unfortunately the GR86 hood vent is plastic. Get the TrackSpec one, you’ll want the added reduction of lift anyways. |
05-19-2024, 11:18 PM | #13 |
What in the hell were they thinking? Plastic, bridging that much of a gap? Seems certain it'll buckle in the middle with high speed pressure
05-20-2024, 11:25 AM | #14 |
Drives: 13 BRZ
There is also a third option!
Similar Threads | ||||
Verus Hood Vents w/Rain Guards | M0nk3y | Exterior Parts (Aero, Lighting, Etc.) | 2 | 12-07-2023 08:19 AM |
WTB verus hood vents | alphasaur | Want-To-Buy Requests | 0 | 08-23-2023 09:57 AM |
Verus Hood Vents | Castswag | Exterior Parts (Aero, Lighting, Etc.) | 5 | 06-30-2021 06:15 PM |
Verus hood vents | norcalpb | Exterior Parts (Aero, Lighting, Etc.) | 4 | 12-09-2020 09:05 PM |
Wtb: hood vents or carbon fiber vented hood | Pooponwindows | Want-To-Buy Requests | 0 | 05-25-2018 01:24 PM |
