07-22-2014, 09:31 PM | #1667 | |
Also, turn in earlier. If you're causing loss of traction with too much input, your car will bite and turn in with a delay after your input, similar to having a roll center that is too low. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | kavanagh (07-23-2014), THEmailman (07-23-2014) |
07-23-2014, 02:22 AM | #1668 |
Fat on Corn Syrup
All this track talk makes me wish I lived somewhere else right now. It was 119* on the drive home today. Next local event isn't until October. I can't wait to become one of those snowbirds I always complain about.
Sent from a secret volcano base using trained sharks |
07-23-2014, 07:19 AM | #1669 | |
Drives: GT-86
07-23-2014, 08:11 AM | #1670 | |
Drives: 2013 Cayenne turbo
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
07-23-2014, 09:03 AM | #1671 |
Thanks
Trying to finalize my decisions on future wheel, tire, brake setup.
I'm basically decided on AP sprint. Should I stick with XP10 pads for that, I'm using that now on stock and like them. I'd like a street pad also that is quiet. What would recommend? Is there one that will work with OEM rear pads so I don't have to buy front and rear? If not that's ok. Wheels. I am looking at PF01 17x8, they come in +45 and +35. I like +45 because it is closer to stock but I like +35 because there is more room for camber, especially for future when I will likely have a 225 tire and camber plate. I have -1.3 right now with bolts. Which offset should I get? Tires. This I just need someone to tell me what to get, I can't decide. I was leaning to AD08R I heard they are good in the wet and dry. The tires would be swapped on at the track and off before leaving but I don't want to have to sit out if it rains. I also hear RE11A and ZII. Then comes size. I was thinking just try stock size 215/45 first and next set try 225/45, or should I just start with 225? Please just tell me what to get here I think I'm too new to really make a decision lol Sorry for the long post, any input is appreciated.
07-23-2014, 09:15 AM | #1672 | |
17x8 + 45 should have plenty of room unless you want to go really crazy on the camber. |
07-23-2014, 09:42 AM | #1673 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
What you want to be considering then is Scranton, PA. Yes, it has winter, but it is the perfect place to live due to its central location, track-wise. You'd be seven hours or less from tracks ranging from VIR to Mont-Tremblant, Mosport to Mid-Ohio, and everything in between - the exact opposite of what you have now. Check it out.
The Following User Says Thank You to dradernh For This Useful Post: | kavanagh (07-25-2014) |
07-23-2014, 03:05 PM | #1674 | |
With a 17x8, either offset will work. Our RPF1 is 17x8 +45, and we run a 225 tire on it. Even at -4.5 degrees of camber, they don't touch the springs, even when using stock-size (Swift spec-r) springs on OEM dampers. I'd recommend the RE11A, as it's the easiest tire to learn with. However, you can't go wrong with the others, as well as the Hankook RS3. When you get wheels, go with 225 at the same time. |
07-23-2014, 05:10 PM | #1675 |
Im currently running PMU HC800 pads, slotted Stoptech rotors, braided lines, motul 5.1 and apr brake ducts. Do you think I'll be okay for Mid-Ohio? I'm still a noob and practicing my trail braking in this car.
07-23-2014, 07:00 PM | #1676 |
If it's still new to you, you should be okay. If the brakes stop responding, keep that in mind as you keep driving.
07-23-2014, 07:01 PM | #1677 |
07-24-2014, 07:48 PM | #1679 |
07-25-2014, 03:16 PM | #1680 | |
Fat on Corn Syrup
What are you guys running on a regular basis? or is there a regular basis for you? What has been your favorite spring/damper combo or coilover? I know this can depend on the track and other setup stuff, but what stands out to you personally as 'wow, yeah, that was awesome'? I'm planning to setup for TTD class and trying to plan the points. I'm already gonna take a 3 point hit for having the paddle shifters... |
The Following User Says Thank You to kavanagh For This Useful Post: | ZionsWrath (07-25-2014) |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
