Old 04-24-2013, 12:15 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Silly question about protecting track rims
I have heard mixed opinions (via google search) about plasti-dipping track rims. Some say they have no problems with it bubbling or heat cycling or becoming permanently applied to the rim...then others say "no don't do it there is too much heat from the brakes".
My question is to those who have anecdotal or direct personal experience with the matter. Can you plasti-dip the face of the rim without it degrading?
Old 04-24-2013, 12:24 PM   #2
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I've lit brake components on fire before. An example is coming off track during a session and the caliper piston "dust boot" is burning or I got OPR wedged in the caliper and it caught fire. Both of which were easily extinguished by fanning the parts with hands but... Plasti-dip is flammable so take that into consideration.
Secondly, 90% of the cosmetic damage to any of the 10 sets of wheels I've used over the years on the race car have come from mounting/dismounting tires. The other 10% came from contact with another car. I would say almost 0% came from just driving around the track. The majority of damage comes from having off track excursions or banging curbs and bending/denting/cracking wheels. Nothing of which plasti-dip is going to save you from.
Recommendation: enjoy your expensive wheels on the street, buy inexpensive "track" wheels for the track. Or adjust your perspective and consider any wheel a "wear item" like ball-joints and brake pads before making your wheel purchasing decisions.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
sw20kosh (04-24-2013)
Old 04-24-2013, 01:13 PM   #3
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
I tracked my car with plastidipped stockers. Couple of rocks chipped the plastidip, nothing negative otherwise.
raul is offline   Reply With Quote
Old 04-24-2013, 01:37 PM   #4
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
I've seen plastidip get "baked" onto wheels on track after many sessions - it becomes nearly impossible to get it out of corners and tight places.
GTM_Challenge is offline   Reply With Quote
The Following User Says Thank You to GTM_Challenge For This Useful Post:
Old 04-24-2013, 01:53 PM   #5
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
Using non ferrous pads can help, like Carbotech (ceramic), since the dust is non-corrosive. Regular waxing will help protect both wheels and body paint, and make removing rubber deposits much easier. Never leave any wheel coating on lug or mating surfaces, or you may lose a wheel.
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
The Following User Says Thank You to phm14 For This Useful Post:
Old 04-24-2013, 02:48 PM   #6
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
I wasn't out to protect the wheels from track damage, but did take my plastidipped stock wheels to the track. My OEM brakes gave out long before I could enough heat into them to do anything negative to the plastidip. I have since removed the dip with no issues at all, fwiw. I can't say that YMMV, but worked well for me. Will be a few months before I make it back to the track with better pads, so I'll have to let you know then if the added heat hurts anything.
trippinbillies40 is offline   Reply With Quote
Old 04-24-2013, 02:51 PM   #7
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
plastidp?? that's not a good idea.
track wheels are meant to be used and abused imho
86_ZN6 is offline   Reply With Quote
The Following User Says Thank You to 86_ZN6 For This Useful Post:
Old 04-24-2013, 04:32 PM   #8
trippinbillies40
Drives: '22 WRB
Why is it not a good idea?
Old 04-24-2013, 04:50 PM   #9
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
If you're worried about plastidip catching fire or being impossible to remove... go on youtube. There's a guy that test it with a screw driver... He plastidips the metal and takes a torch to it for like 3 minutes straight, never ignited and he scraped the plastidip off afterwards. I can't get the direct link because youtube is blocked at my current location....
edit: also with that video the plastidip showed no signs of bubbling/degrading
/thread?
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 04-24-2013, 07:30 PM   #10
rice_classic
Interesting... Seems to burn pretty well according this video:
[ame="https://www.youtube.com/watch?v=bTOLvCFmqCA"]Burning PlastiDip - YouTube[/ame]
SCCA T4 - FRS
Old 04-24-2013, 07:31 PM   #11
rice_classic
Here too:
[ame="https://www.youtube.com/watch?v=9GZQM0MWT8I"]How Real Men Use Plasti Dip (part 2) - YouTube[/ame]
SCCA T4 - FRS
Sonolin (04-24-2013)
Old 04-24-2013, 08:31 PM   #12
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I have thought about this as it seems it would be a good way to keep wheels looking newer after the track. But then I remembered all of the damage and abuse my track wheels have taken over the years, and thought better of it. I have seen pieces of brake pad come off and attach to wheels along with just the dust. Hot messy stuff that can damage the wheel finish. I think the mess would be worse with plasti-dip and I really don't want to take the chance of having permanent plasti-dip. So I decided that I would just let my track wheels take the abuse as-is. I think this is the much safer option. I am not that particular about the looks of track wheels anyway.
Old 04-25-2013, 02:44 AM   #13
rice_classic
Speaking of protecting wheels...
Don't break this wheel.
[ame="https://www.youtube.com/watch?v=dIO27gOc-uk"]Detachable Steering Wheel - YouTube[/ame]
SCCA T4 - FRS
Old 04-25-2013, 08:15 AM   #14
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
When applied and DRY.
http://m.youtube.com/#/watch?v=sE384...%3DsE3841-1E8s
Omar GC
Instagram: 2jzus
Just curious. Anyone buy some detecters or camera for protecting their FRS? ShowTime_DW Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2013 05:27 PM
Eibach Sportlines Aftermarket rims Question. HATED1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-22-2013 07:08 PM
Silly question about the dash... jm1681 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-11-2012 01:20 PM
Tips for protecting the paint on the new car brianc Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-25-2012 08:45 AM
Protecting plastic door threshold BMWDavid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-19-2012 09:04 PM
