Forced Induction Turbo, Supercharger, Methanol, Nitrous |
01-17-2024, 12:22 PM | #15 | |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
+on your suggestion. My main concern is if this company is going to be around long. A while back they were soliciting for investors. |
01-17-2024, 12:59 PM | #16 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Not really easy as it looks on Roadkill.
Simple Indeterminate Blowed Up Don't even need to pick one. It's a package deal!
"I gotta rock." -- Charley Brown |
01-17-2024, 01:36 PM | #17 |
I ran E85 for a time and it helped, but in my area there's only one place to get it and it wasn't worth the effort.
The Following User Says Thank You to Qwimby1 For This Useful Post: | Teseo (01-20-2024) |
01-19-2024, 10:52 AM | #18 |
Drives: 2015 BRZ 2004 SVT Cobra
01-19-2024, 01:19 PM | #19 | |
Professional wrench
Drives: 2020 BRZ ST RS
I simply don't want to do it. Saying the other parts are hard to do is just silly. Look at how the electric ones work. People are saying they can install and remove them in less than an hour. honestly there shouldn't be anything else involved for the basic install of a centrifugal blower put on the front of the engine. remove intake piping and airbox. remove drive belt install SC bracket/SC itself fit up piping from airbox to SC Fit up piping from SC to throttle body. there is tons of room at the front of the engine bay. As for the turbo kits, I like turbos, and know how to tune with them very well, so it was my first thought. However, Id rather keep the exhaust setup I have. And I can't really see a convenient area to fit a remote mount turbo that wouldn't come with its own problems (heat, space, hanging down too low etc)
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
01-19-2024, 01:22 PM | #20 |
Professional wrench
yea there is one in my province, and its 2 hrs one way and its not even open that often. eff that
01-19-2024, 01:29 PM | #21 |
Drives: 2015 BRZ, 2005 STI
01-19-2024, 01:35 PM | #22 |
Professional wrench
no. Not only am I more than capable, I don't really trust anyone else to work on my vehicles. Some warranty stuff, sure, but something like this? nope.
The Following 2 Users Say Thank You to JohnH For This Useful Post: | Teseo (01-20-2024), Ultramaroon (01-19-2024) |
01-19-2024, 01:54 PM | #23 |
chicken tonight
Time to suck it up, Buttercup.
The Following User Says Thank You to Ultramaroon For This Useful Post: | menikmati (01-19-2024) |
01-19-2024, 03:41 PM | #24 |
I don't have the facilities or capability to install a belt-driven one, which is one reason I like the ESC. if I had to pay for and install it would add significantly to the cost I also have the option to remove it easily and put it on another car if I choose. My car is a 2014 and I'm not entirely trustful of the strength of that motor, which is why I wanted no more than 5 pounds boost. M Phantom has been working fine for a couple of years and makes a significant difference.
01-19-2024, 05:29 PM | #25 | ||
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
01-20-2024, 09:27 AM | #26 |
Drives: frs
Torque amp should take the lead on ESC but they doesn't do any marketing or make the product more ready, like doing kits + tune and other miscellaneous
01-20-2024, 01:00 PM | #27 | |
I haven't seen one for quite a while though. |
01-21-2024, 09:17 AM | #28 | |
Drives: 2014 Subaru BRZ WRB
Based on what you want and what you talk about, the Sprintex non-intercooled kit would be the best for you. I thought installing the whole kit was pretty easy considering it’s just me (hardest part was lifting it by myself and lowering it in). Having the barebones kit would mean you essentially disconnect the belt (just a 14mm on the tensioner). Then unplug and take off the TB (leave everything attached hose-wise). Take off the hoses from the manifold and remove the manifold (6 bolts). Then route the extensions from the supercharger (map extension and tb extension) and then just drop in the supercharger manifold (head unit is already on) and bolt it up (there is an extra 32mm bolt that attaches at the front to secure the manifold). Reconnect TB and hoses. Then put belt back on. Super easy and not involved compared to other kits. If you have e85 readily available, it’ll help and you can get a flex kit (another 10-15 min install depending on which kit you get). Then get it tuned via Ecutek and you’re done. It’ll push roughly 9-10 on the stock 75mm pulley and it’ll be fine with proper maintenance; adding the e85 will just increase reliability and power ***forgot, the kit uses a plastic elbow that attaches to the intake. Super simple to take off and on (just four clamps) |
Similar Threads | ||||
FI options: Turbo or Supercharger | Misha235 | Forced Induction | 44 | 06-05-2020 09:31 AM |
DC Sports cat back review and new supercharger options for the 86 | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 02-09-2017 06:17 PM |
Scion FR-S options:what options did you have dealer installed? | Scionshaun | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 01-06-2014 01:35 AM |
Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 12:53 PM |
Gearing Options and Diff options | airboy808 | Engine, Exhaust, Transmission | 26 | 12-25-2011 01:11 PM |
