Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-30-2020, 09:45 AM | #1 |
Drives: 2018 Toyota GT86
FI options: Turbo or Supercharger
Hi guys,
I'm trying to get a rough plan and mod list for my 86 and would like to get some opinions on the two different FI routes(definitely will do one). My end goal for power is around 325-350 Horsepower and this will likely be my daily driver for a little bit but will get workouts on track, hill climbs etc. Personally I love the lure of the turbo, efficent power and a blowoff noise, who could argue with that. But i'm a little concerned about the heat produced by dding, a less linear power curve and honestly i am a little overwhelmed by options and setups available, so any help with the best setup for my goals would be great. The more responsible side of me is pulling me towards a supercharger, specifically a Harrop supercharger, mainly because they are local to where i live and also seem to give reliable results. I like a linear power curve for DDing however i am a little concerned whether a supercharger can reach my goals, even with an e85 fuel upgrade and tune. I will likely being doing exhaust mods, after market headers and catback if i get the turbo kit. Just a catback if i get the turbo kit. I am happy to upgrade fuel injectors and run an e85 tune however ideally not run on e85 all the time, change to e85 for the more intense use. Thanks for your help guys!! TL;DR Goal:325-350whp DD/Track car Question: What forced induction route suits that goal? |
05-30-2020, 09:54 AM | #2 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
The Following User Says Thank You to BirdTRD For This Useful Post: | jcw99 (06-03-2020) |
05-30-2020, 10:09 AM | #3 |
Drives: brz 2017 hksv2
gives you somewhat an idea
turbo is funnier always, and i m saying this with an unrestricted hks supercharger |
The Following User Says Thank You to tomm.brz For This Useful Post: | Teseo (05-15-2023) |
05-30-2020, 10:58 AM | #4 |
Drives: 2017 toyota 86
From purely an engine reliability stand point a turbo can be setup to be much easier on the engine. Turbo has a lot less parasitic drain on the engine, and less load on the engine so you can make more WHP at the same crank HP, and with much less boost needed. heat issues with a turbo are a concern but if its a pure DD it wont be a big deal.
To have any chance of being somewhat reliable on stock engine 300whp is the max for a supercharger 325whp for a turbo. Even then its pushing it. but depending how often you are actually using that power. How a turbo makes power (when/where/how much, lag etc..) is way more controllable compared to a supercharger, a lot of it is dependent on the size of the turbo and you can also run boost by gear or boost by rpm to control this more as well. Supercharger will always have the same general "curve" you can only make it bigger or smaller by swapping pulley sizes. also keep in mind with turbo lag, even if you see a turbo making full boost at 4000rpm if the pull started at 3500rpm it took 500rpm to spoolup, if you are driving normally and downshift to 5k all of a sudden to start a pull it wont be making the power the dyno showed at exactly 5k right when you downshift, it'll take a second to spool up and you probably wont be "matching" the dyno plot until 5500rpm. Supercharger is entirely linked to rpm and throttle opening. they are incredibly responsive and you will always be "matching" the dyno plot at wot. A positive displacement like harrop, edlebrock, cosworth, sprintex they can make a lot of boost down low very quickly and instantly as soon as you get on it no waiting time but become less efficient top end, the powerband they make is very fun and enjoyable and even when casually cruising DDing you will always be utilizing some of the extra power in the mid range. but that instantaneous low end torque is also what snaps rods. They make the car feel like it has a strong NA 3L V6, less of a "turbo kicking in boost" feeling. centrifugal sc is the option many like to go because they lack low end and eventually at high rpm start building some great boost/power. They can have a lot of good applications for track/autocross cars, but this is my least favorite option for a DD, a turbo can do anything that can do for a DD but better, just set it up and control it to your liking. |
05-30-2020, 09:45 PM | #5 |
pessimistic skeptic
Turbo does not pull power on the crank but it is a restriction on the exhaust flow. My preference would be free-flowing exhaust and an efficient supercharger over turbo.
05-30-2020, 10:52 PM | #6 |
Turbo
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
06-01-2020, 02:31 PM | #7 |
pessimistic skeptic
Turbo generally requires more expensive support modifications for heat management. I would not ignore those requirements. If you are going to aim 325-350whp (which is significantly higher than a basic kit provides) without building the engine, I would recommend a special tune and boost control that reduces the torque at low rpm. If you aim maximum torque at low rpm without building the engine, blow up risk will be high. I wouldn't do that.
06-01-2020, 03:07 PM | #8 | |
06-01-2020, 08:21 PM | #9 |
pessimistic skeptic
Well, that power level without built engine and proper cooling is not something I can enjoy even for DD. There is simply not enough reliability margin. But, sure, I can only speak for my car.
06-02-2020, 11:07 AM | #10 |
Drives: 2017 Subaru BRZ
Turbo all day, for the noises alone
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17 |
06-02-2020, 12:53 PM | #11 | |
Drives: 2017 BRZ
Also didn't see mention of the potential for turbo install/maintenance issues that can result is boost spikes. Boost spikes can destroy an engine quickly and gear-driven chargers don't have that exposure. |
06-02-2020, 01:05 PM | #12 |
did you ever saw a log of a PD, at low. rpm and WOT?
Anyway, boost spikes are tames by a boost limiter, so if the tune is well done, turbo can be safer than PD |
The Following User Says Thank You to tomm.brz For This Useful Post: | 86TOYO2k17 (06-02-2020) |
06-02-2020, 05:39 PM | #13 |
Simply Forgotus
This is like debating boxers or briefs. There's pro's and con's to each but it really all comes down to personal preference.
NA=Commando Turbo=Boxers Root/Twin screw=Briefs Centrifugal SC=Boxer Briefs Personally, If I lived in Australia and Harrop was in my back yard, just for that reason alone...Harrop all day long. |
06-02-2020, 11:43 PM | #14 | |
My PD instantly makes 10psi at 3500rpm at WOT and slowly ramps up to 13psi at around 6500-7k, so not instantly at max boost but still making a lot of boost at low rpm, much different than a centrifugal charger. And with zero lag or spool up time it comes on instantly directly correlated to throttle opening. There is a reason car manufacturers usually use turbo over supercharger. Once setup right, it’s way better. Never said It was easier to setup correctly though. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | jcw99 (06-03-2020) |
Tags |
forced induction, mopowabby, supercharger, turbo |
Similar Threads | ||||
DC Sports cat back review and new supercharger options for the 86 | Photomikes garage | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 02-09-2017 06:17 PM |
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit | Ogremair | Forced Induction | 27 | 09-10-2015 04:39 AM |
What are turbo options for AT? | FT&6 | Forced Induction | 7 | 07-13-2015 09:40 AM |
Turbo options | robinsonbond007j | Forced Induction | 42 | 10-19-2014 12:44 AM |
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 11:50 AM |
