Old 02-05-2015, 05:59 PM   #15
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Originally Posted by Darryljr11 View Post
TSB could still apply but I wouldnt have dealer do it. Ptuning did the TSB for CEL codes I was getting. The probable cause of the car running like shit is the AVCS is probably going into limp mode (not working). The only person I personally know of having this issue resolved it by have the cam sprockets replaced.
Any idea on a ballpark of how much that cost them?
@ptuning is this true? seeing as that my tune is from toan it would probably make sense to bring it to them anyways if it's not too expensive.
I should have seen this coming, my cams acted funny one time back in the fall but were 100% fine until recently.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-07-2015, 05:20 PM   #16
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
No idea about cost would have to llook up tsb add cost of parts and ask em what theyd charge for labor
Darryljr11 is offline   Reply With Quote
Old 02-07-2015, 07:00 PM   #17
SteveIsBored
Drives: 2013 subaru brz
Originally Posted by BRZnut View Post
Not sure if the specific Cam code can delineate between ECU cam issue and a mechanical issue of the cam. Maybe someone with more knowledge knows the answer.
Anyone know?
it looks like it's a cam and crank correlation code 18 and 19 are the different banks. The ecu expects the cam signal and crank signal wave forms to be at certain points at tdc. Most of the time this is a mechanical issue like timing chain slipped or bad vvt. If it were electrical like dead sensor u would see circuit output codes. As far as the tsb I didn't read it but it probably says replace the vvt and update ecu which means subaru softened the calibration with the software update. These aren't the only four cylinder engines with similar tsbs and issues with vvt
I just looked at the tsb and they actually show the wave forms captured from their data
Logging feature on their scanner that's a new one for me. And it looks like warranty pay times are listed at about five hours I would expect to pay 1.5 times that for customer pay and what ever the vvt cost
SteveIsBored is offline   Reply With Quote
The Following User Says Thank You to SteveIsBored For This Useful Post:
woode (02-07-2015)
Old 02-09-2015, 11:14 PM   #18
woode
Boosted Member
woode's Avatar
Since the BRZ was my daily driver, I went out and bought a WRX as a new daily driver so I can pull this engine and build it like I've been meaning to anyways.
I'm sick of chasing codes and dealing with my shitty FA20Club turbo kit. So, shortly I will be parting it all out and building the block and heads
Old 02-10-2015, 07:56 PM   #19
jflogerzi
jflogerzi's Avatar
Very nice! Wish i had that kind of cash laying around
2013 Series 10 FRS #553
Old 02-11-2015, 03:54 PM   #20
The_Mitz
Drives: 1998 Subaru 2.5RS
My completely stock 2014 has been in and out of the dealership for the 0018 code. 13k miles.
First time in, they just reset it. Came back a block away from the dealer.
Second time, they updated the ECU and topped my oil off, plus some drive cycles. Came back on a block from the dealer.
Third time, they replaced the AVCS oil valve, plus some drive cycles. Came back on two blocks from the dealer.
Fourth time, SOA says to replace ECU and then possibly the sprocket on the affected cam. Still waiting for the ECU to come in.
I will post an update when I get the car back.
ugh
The_Mitz is offline   Reply With Quote
The Following 2 Users Say Thank You to The_Mitz For This Useful Post:
strat61caster (02-11-2015), woode (02-11-2015)
Old 02-11-2015, 05:06 PM   #21
woode
Boosted Member
woode's Avatar
ugh
I think when I pull the engine, I am just going to buy a built head. 2 birds with 1 stone.
I might bring it to the dealer as is, and see if they will honor the warranty and replace the AVCS valve and cam sprocket.. but I have a feeling they will see the turbo and laugh (even though I am certain this issue has nothing to do with any modifications to the car). Regardless.. worth a shot. Worst case is they say no.
Old 02-20-2015, 11:18 AM   #22
woode
Boosted Member
woode's Avatar
An update for anyone interested or who encounters similar problem;
I replaced the LH intake cam oil control valve and the CEL seems to have gone away. Now that I know what the problem was I am pulling the engine and selling the turbo kit though. Already bought part of my new project for her
The Following 3 Users Say Thank You to woode For This Useful Post:
Astroboy (01-10-2016), Darryljr11 (02-20-2015), Ultramaroon (02-23-2015)
Old 02-20-2015, 12:11 PM   #23
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Damn... this type of shit makes me want to trade in my car more and more. I heard these cars are plagued by this inevitable failure. It's hit or miss some say though.
hmong337 is offline   Reply With Quote
Old 02-20-2015, 10:08 PM   #24
BRZnut
Drives: BRZ DGM Limited
I AGREE ......too many issue for my liking
Old 02-23-2015, 12:22 AM   #25
woode
Boosted Member
woode's Avatar
And... the CEL is back. Annoying. I'm trying to get this motor built and all these other big changes - but I really don't want to proceed with known bad parts.
I guess the cam sprocket is next on the list. Hopefully that isn't too much of a pain in the ass.
Old 02-23-2015, 08:58 AM   #26
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Yeah, This is what's holding back my modding....
BlueSky is offline   Reply With Quote
Old 02-23-2015, 11:35 AM   #27
woode
Boosted Member
woode's Avatar
The irony being that this problem is not caused by modding at all..
Old 02-23-2015, 02:31 PM   #28
BlueSky
BlueSky's Avatar
I agree, but in the dealers eyes.....
it's pretty well a lose lose situation
CEL P0018 brichard0625 Issues | Warranty | Recalls / TSB 8 02-10-2016 09:44 PM
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
