Old 01-23-2015, 10:34 PM   #1
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
CEL P0018 Cams
Got P0018 leaving work today. Car seemed fine though, granted I babied it home just in case. I pulled the battery, reset, and the code is gone.
I haven't actually drove it around for an extended period to see if it stays gone.. but from everything I have read - P0018 was an ECU issue that was resolved a while ago? And, I am on an aftermarket tune anyways..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 01-23-2015, 11:46 PM   #2
BRZnut
Drives: BRZ DGM Limited
Cam issues seem to be an on going problem with these engines. And from what I am reading, they seemed to be linked with engine oil starvation and then engine failure.
Check out this video and go to the 5 min mark and listen to what these guys say about the weakness of these engines. They mention the code you and others have had.
Sucks
Old 01-23-2015, 11:50 PM   #3
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
http://www.ft86club.com/forums/showp...postcount=2970
Here you go!
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 3 Users Say Thank You to DesertFrs For This Useful Post:
ENVJFRSH (11-14-2023), flippy (02-25-2015), hmong337 (02-07-2015)
Old 01-24-2015, 09:03 AM   #4
BRZnut
Originally Posted by DesertFrs View Post
Interesting. Is it worth getting a tune on a stock BRZ to improve some of these issues ? If so, is it DYI or do you need to bring the car to a shop?
Old 01-24-2015, 09:05 AM   #5
woode
Boosted Member
woode's Avatar
I read that. The weird thing is that I already have the latest update.
Old 01-24-2015, 10:19 AM   #6
woode
Boosted Member
woode's Avatar
Update (or lack thereof)
After resetting my ECU, I drove it around for about 15 minutes this morning and all seems well. No more code.
I am still paranoid.
It happened when I drove off and my engine was cold still, I never do that but yesterday I had to (engine oil was still at <40f). I am wondering if that was a factor?
Old 01-24-2015, 10:30 AM   #7
BRZnut
The posting by AVO seems to suggest there could be a mechanical problem with the cam. Some spring that does not go flush and can cause a code and oil starvation? No idea how you would know unless one takes a direct look at the cam.
Old 01-24-2015, 10:42 AM   #8
woode
Boosted Member
woode's Avatar
I may be reading this wrong, and their isn't much info out there, but I am under the impression that 0018 and 0019 are ECU-related. Even the post linked above seems to state that, saying that 0016 and 0017 are mechanical-related.
Old 01-24-2015, 01:27 PM   #9
BRZnut
Not sure if the specific Cam code can delineate between ECU cam issue and a mechanical issue of the cam. Maybe someone with more knowledge knows the answer.
Anyone know?
Old 01-31-2015, 09:39 AM   #10
woode
Boosted Member
woode's Avatar
Bump.
This code keeps returning at random. The car drives 100% normal (cruising, 10+ psi boost full throttle, cold start, warm start) until it throws the code, and then it goes into some sort of limp mode until I reset.
Old 01-31-2015, 10:10 AM   #11
steve99
Bump.
think post here is the one
its supposed to look like this
http://www.ft86club.com/forums/showp...postcount=2973
Old 01-31-2015, 11:36 AM   #12
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
There is a TSB for this that involves replacing parts of the AVCS
Darryljr11 is offline   Reply With Quote
Old 02-04-2015, 06:21 PM   #13
woode
Boosted Member
woode's Avatar
TSB doesn't help since I am turbo'd. That battle with the dealership isn't even worth the effort.
More info however.. I have narrowed down when exactly my CEL is triggered. Whenever I let off the gas while in gear or apply a tiny bit of gas while in gear coasting down a hill.
Idle is fine. To the floor at 12psi of boost is fine. Cruising is fine. Let off the gas in gear to coast down a hill - CEL. And once the CEL is triggered the car drives like shit.
I suppose I need to start looking into what exactly I need to replace.
Old 02-04-2015, 11:13 PM   #14
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
TSB could still apply but I wouldnt have dealer do it. Ptuning did the TSB for CEL codes I was getting. The probable cause of the car running like shit is the AVCS is probably going into limp mode (not working). The only person I personally know of having this issue resolved it by have the cam sprockets replaced.
The Following User Says Thank You to Darryljr11 For This Useful Post:
woode (02-05-2015)
CEL P0018 brichard0625 Issues | Warranty | Recalls / TSB 8 02-10-2016 09:44 PM
Cams Fabron757 Forced Induction 10 01-13-2015 06:30 PM
HKS cams JesseTheFlash Engine, Exhaust, Transmission 4 01-09-2015 07:42 PM
Wtb oem cams midnight23 Want-To-Buy Requests 0 03-19-2014 12:07 PM
Cams Surok Engine, Exhaust, Transmission 10 01-01-2013 08:30 PM
