Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-06-2016, 07:28 PM | #29 |
Drives: White BRZ
04-08-2016, 03:15 PM | #30 | |
Drives: 2013 SWP BRZ
Wish I could tell you where that transition point is though it only seems to matter when you start talking about changing geometry by lowering. That said, once you hit the bump stops, you're effectively not compressing the suspension anymore. |
04-08-2016, 03:19 PM | #31 |
I'd be willing to bet that it's stupid low and not something anyone should be worrying about
04-08-2016, 04:36 PM | #32 |
That Guy
Drives: 2013 asphalt FRS MT
This was covered a while ago, I can't remember the thread at the moment, but the result was (paraphrasing here) the tire would have to be poking up out of the fender before you start gaining positive camber.
01-08-2017, 09:44 PM | #33 |
Drives: '87 Corolla GTS, '13 FR-S 6MT
Are those front LCAs stx legal? It looks like they use bushings instead of heim joints.
01-08-2017, 10:01 PM | #34 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I don't know myself. I have not seen any stx build include front lca and I dont know enough about the front lcas to say. If you find out let me know and I can update the thread here if they are. Maybe ask in the STX sticky
03-27-2018, 04:15 PM | #35 |
Bump this as there have been a few posts where this may have helped. Will also be updating with some caster adjustment stuff soon.
Any other updates/new parts I may have missed?
04-17-2018, 06:23 PM | #36 |
Drives: 2017 BRZ Limited Auto
Thanks for this thread to steer me in the right direction
The Following User Says Thank You to IndyBRZed For This Useful Post: | finch1750 (04-18-2018) |
06-05-2018, 04:07 PM | #37 |
Updated with H&R rear camber bolts and Powerflex RUCA adjustable bushings
08-06-2019, 02:55 PM | #38 | |
Drives: 2017 Subaru BRZ
Is there really just no consensus on if the 81305 goes in top or bottom? |
08-06-2019, 03:25 PM | #39 |
Drives: 2014 GT86
81305 is designed for use in lower, 14mm hole. Some may use it in upper, 16mm hole, but imho it may compromise a bit reliability of mount, as to not slip it probably will need to be tightened past reasonable torque value (as even with lobe it will still be smaller then upper hole diameter, and you can with same success use any regular 12mm bolt there with same "more" adjustment and with same reduced mount strength).
Use 81305 in lower hole, and KCA416 (81280) in upper, as it's meant to be. Yes, 81305 may net slightly more range in upper hole, but if you need even more camber then what two sets of proper sized camberbolts used in holes they were designed to can net, you'd be better off netting extra additional camber using other means, eg. lca offset bushing or offset topmount or camberplate, to accompany camberbolts. |
The Following User Says Thank You to churchx For This Useful Post: | strat61caster (08-06-2019) |
08-06-2019, 03:46 PM | #40 | |
Personally, I am hesitant to use both the 83105 and the KCA416 (81280) due to slippage/reliability concerns from using two eccentric bolts at the same time. I have the a similar reliability concern with using the OEM bottom bolt in the top. Maybe unfounded but it still makes me uneasy. |
08-06-2019, 04:30 PM | #41 |
Drives: 2014 GT86
83105 is even thinner/weaker then oem crashbolt. Probably comparable to KCA416.
After all, oem crashbolt is normal 14mm bolt, while 83105 needs to be even thinner then it to provide slack/adjustment range when used in same 14mm hole. While i'm ok with using 83105+KCA416 (actually am using for 3 years already) and probably would be ok with 83105+OE crashbolt on top (but as first combo nets slightly more camber, went with that), using 83105 at top sounds too much for piece of my heart, thus i voiced my opinion on it, that imho one shouldn't. |
08-08-2019, 11:49 AM | #42 | |
I have ran 81305 in the bottom hole for over 130k miles. I have ran the bottom bolt/crash bolt in the upper hole the same amount of time. Half of that time was on OEM struts and the other half was coilovers with slotted upper holes. Never had any slippage with countless mountain runs, daily driving on horrible roads, and about 8 track days. Like church I don't like the idea of extra wiggle room with an eccentric bolt. I never tried it though so can't give first hand knowledge. |
Similar Threads | ||||
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear | deedz | Brakes, Suspension, Chassis | 11 | 03-17-2015 03:29 AM |
SPL Adjustable Suspension Arms?? | Trmx2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-28-2013 01:22 AM |
KW Suspension ** Club Sport with 2 Ways Adjustable ** | RavSpec | Brakes, Suspension, Chassis | 0 | 09-26-2013 03:22 PM |
Ground Control Complete Coilover Suspension Kit and Adjustable End Links | Eric1855 | Brakes, Suspension, Chassis | 12 | 05-26-2013 12:02 AM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
