Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-28-2016, 02:19 PM | #1 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Adjustable Suspension/Alignment FAQ
From factory this FRS/BRZ lack camber adjustment in both the front and rear of the car. This thread is to outline the options for gaining camber adjustment (and more in time) with some of the differences in the varying options. I am in no way an expert. I have simply spent a lot of time trying not to screw up my own car and see questions related to this info asked often and people getting tired of repeating themselves. Also please note if you race in SCCA/NASA/86Cup/etc some items are limited based on class. I did my best to list legal parts for SCCA Solo 2 but am the not governing body so double check. Please do your research before purchasing on what is legal and what isn’t. All adjustment ranges are approximate and vary from car to car.
If you feel like there is something missing please PM me or post and mention me in this thread so I can add it if I think it is needed. I am in no way responsible for any damage you do to your own car based on your choices regarding the topics in this thread. I also do not endorse any companies listed or vouch that they make quality products. Do your own research and always have a licensed mechanic perform installs and adjustments. Front camber: Camber bolts: Camber bolts are a cheap, easy way to gain adjustable camber in the front of the car. They do not have the range of camber plates but are enough for many (up to +/-2.5 degrees possibly). There are a few options for camber bolts. OEM aka crash bolts (Toyota SU003-02818; Subaru 901000394): This is a 14mm bolt that replaces the 16mm bolt in the upper hole on your strut. It is able to take the torque needed to tighten with enough force to not slip since it is smaller than the hole it is inserted in. Adjustment is done by moving the strut in or out changing the camber and then tightening. While I can’t find specific numbers this bolt tends to add approximately between +/- .5 to 1 degree camber. This bolt is the same as the factory bolt in the lower hole on your stock struts. CS legal camber adjustment SPC 81280 or Whiteline KCA416 : It is a 16mm eccentric bolt installed in the upper strut hole. This bolt has a lobe that adjusts the strut angle by rotating the bolt when installed. Adds approximately +/- 1.5 degree camber. Whiteline bolt is a repackaged SPC bolt listed first. SPC 81305 or 81260: This is a 14mm eccentric camber bolt that is installed in the lower hole. This bolt has a lobe that adjusts the strut angle by rotating the bolt when installed. Adds approximately +/- 1.75 degrees camber. Pro-tip: If you install 14mm eccentric bolts in the lower strut hole, you now have a "spare" OEM crash bolt. Swap the OEM bottom bolt into the top strut hole for greater adjustability. This is how to achieve upwards of -2.5 on stock struts with just camber bolts. Adjustable top mounts aka camber plates: Camber plates provide a much wider range of adjustment over camber bolts. They also replace the oem rubber top mounts and often are made of only metal (few exceptions like the Whiteline Com-C). While this has handling benefits as you eliminate slop it can add to NVH. Camber plates cost a few hundred dollars compared to under $40 for camber bolts. Depending on how they are designed some camber plates may raise/lower ride height slightly. Some camber plates also include caster adjustment as well. Some companies that make camber plates for the twins: Beatrush Ground Control HVT (no longer in business) Racecomp Engineering Raceseng Velox/FT86Speed Factory Whiteline Front lower control arms: Racer X adjustable front lower control arms. These have both camber and caster adjustment. The standard range of adjustment is approximately +1 to -4 degrees camber. Caster adjustment is the full range until contact is made front or rear in the wheel well. An extended version is available for up to -6 degrees camber and custom set-ups are available up to -18 degrees of camber Parts Shop Max have front control arms as well. It appears to only be sold as a full front kit with tie rods, adjustable knuckles, etc. Meant for extreme steering angle. Powerflex PFF69-801G: FLCA rear bushing that claims to adjust camber +/- 1 degree Rear Camber Rear Camber Bolts: While not confirmed on H&R's website as fitting the Zx6 chassis users have reported using H&R TC112 camber bolts in the rear struts upper hole to gain =/- .5 degrees camber. Minimal cost for minimum gain that could possibly even out if mismatched too greatly side to side. These are eccentric so as always be sure to check for slippage Rear lower control arms (LCA): Adjustable LCAs are a relatively cheap and simple for gaining adjustable camber in the rear. There are many options with various adjustments and bushing types. Some also will have multiple mounting locations for swaybars to help tweak other handling characteristics as well. The downside to LCAs is camber changes done here will affect toe as well. Some companies that offer adjustable LCA: Agency Power Blox Buddy Club Cusco DME GT Spec ISC Megan Parts Shop Max Racer X (STX legal config available) RSR (STX legal) SPC (STX legal With DiF bushing installed) SPL Stance Voodoo13 Velox (STX legal config available) Whiteline (STX legal) Rear Upper control arm (UCA): Expensive and limited choices, but allows for wider range of camber adjustment compared to other options and changes are independent of toe. Some companies that offer adjustable UCA: MSI Racer X Rear UCA bushings: These are the cheapest option in terms of purchasing cost. However, they offer limited adjustment ( approximately +/- .75 degrees) and also usually require a shop to install them as an air hammer and press are required to remove the old bushings. These are also an extreme PITA to adjust so your alignment guy might start to hate you. They do however really tighten up the rear end with a harder compound bushing. Non-adjustable versions are also available. Companies that offer adjustable upper control arm bushings: Whiteline (STX legal) Powerflex Toe Toe can be adjusted from factory and has a large enough adjustment range for most vehicles that are not running crazy camber and/or are slammed. There are however options for adjustable toe links in the rear and a few options for aftermarket outer tie rods in the front. Outer tie rods also can help with bump steer correction on lowered vehicles. Some companies that offer adjustable outer tie rods: Parts Shop Max Racer X SPL Some companies that offer adjustable rear toe arms: Cusco DME FT86SpeedFactory Megan Parts Shop Max Racer X SPL SPC Voodoo13 Whiteline Useful threads regarding alignment and suspension: Alignment FAQ @Dezoris outlines factory specs and many questions to think about before buying, before the alignment, and for when the alignment is actually done. Great read and what kinda inspired me to put this together. I just felt it was missing some of the things like what adjusts what and options beyond his personal experiences and set-up. CSG and RCE tag-team suspension Q&A thread! Ask us anything! Read this. The whole thing. You will learn a ridiculous amount about the handling of this car and suspension in general. Basic tech info: spring rates, rear suspension, motion ratios, and you. Intro to some suspension theory from the guys at RCE
The Following 21 Users Say Thank You to finch1750 For This Useful Post: | Ashikabi (03-29-2016), BAOVAN (03-08-2018), CSG Mike (03-28-2016), EffaressNOOB (04-19-2018), emutcfut (03-31-2016), go_a_way1 (03-28-2016), ka-titties (08-16-2019), KevBRZ (05-28-2019), KL (03-28-2016), MisterSheep (03-29-2016), new2subaru (01-09-2017), Plumbus (08-25-2020), Pointmutation (10-11-2016), PWBRZ (03-30-2016), Qwimby1 (08-12-2019), Racecomp Engineering (03-28-2016), soulreapersteve (04-15-2016), Stonehorsw (03-10-2023), tato.valverde (03-28-2018), TeutonicShift89 (08-07-2019), wparsons (03-28-2016) |
03-28-2016, 02:20 PM | #2 |
Alignment settings are based on a lot of factors – driver style/skill, what can you adjust, springs rates, sway bars, tire grip, car use, etc. The best way to check you alignment is to watch tire wear and use a pyrometer to ensure the tires are heating evenly across the whole width. If they aren’t you are not using the whole tire and therefore not using them to their full ability and efficiency. Below are some general starting points to reference depending on the type of driving.
Camber: As you turn the car rolls causing weight to be placed on the outside edge of the inside tire. To combat this you need negative camber so that when you are turning and it matters most the whole tire is in contact with the ground evenly. In general more grip equals the need for more camber. You gain negative camber through lowering as well as under compression but most of the time this is not enough. Also, since we have a McPherson strut set-up this car naturally understeers and running more front camber than rear helps combat this as well as create better turn in. It should be noted that camber is dynamic and changes while driving so it is something that needs to be taken into account and discussed with a professional (i.e. your local performance alignment shop, CSG, RCE, etc). Toe: Toe affects different things front and rear. Front toe out helps with turn in but can sacrifice some stability at high speeds in a straight line. Rear toe in can help with straight line stability at speeds as well as under breaking since the tires are both fighting to center assisting against wandering. Toe increases tire wear more than camber and should be adjusted in low increments if you want to maintain good tire wear. It should be noted that toe is dynamic and changes while driving so it is something that needs to be taken into account and discussed with a professional (i.e. your local performance alignment shop, CSG, RCE, etc). Caster: coming soon OEM Specs Camber -0.8 to 0.8 front -2 to -0.5 rear Toe -0.12 to 0.12 front -0.04 to 0.2 rear Caster 5.2 to 6.7 front Spirited driving alignment baseline Camber -2 to -2.5 front -1.5 to -2 rear Toe Zero all around Note: Competitive auto-x and track alignments tend to run much more aggressive but is very tire and driver dependent so I have removed those settings. Especially since I do not have much experience in that realm. A pyrometer to ensure even temp across the tire is the only way to know if your track alignment is optimized Final Thoughts: Even for a DD alignment is important. Factory specs are broad and most places only care that all the numbers are in the green and not what they actually are. Handling matters in emergency breaking situations so having something that is set correctly is important to everyone. Not to mention .2 toe in may not be great for tire wear with you -2 camber. Find a reputable alignment shop. Know what specs you are looking for and can achieve with your set-up. Make sure the shop can work with those settings and your parts. Check the alignment before its off the rack and always get a final printout when done.
The Following 3 Users Say Thank You to finch1750 For This Useful Post: |
03-28-2016, 02:25 PM | #3 |
Not a troll
A FAQ on how to search would have been more useful. 99% of questions asked on here could have an answer if someone typed "How to lower scion frs" in google and the first results would be about 69 threads from this site, with more than enough info in at least have of them.
03-28-2016, 02:29 PM | #4 | |
And I'm tired of answering people with LMGTFY links and while I'm sure this won't stop people from posting the same thread for the 18485772 time I wanted to give it a shot. As it grows maybe it will be helpful enough to be a sticky even.
The Following 2 Users Say Thank You to finch1750 For This Useful Post: | go_a_way1 (03-28-2016), strat61caster (03-28-2016) |
03-28-2016, 02:32 PM | #5 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
03-28-2016, 02:54 PM | #6 |
Add Racer-X to the LCA list as well please, aside from Velox they're the only other currently available off-the-shelf SCCA STX class legal LCA. But not worth listing that level of detail, people should be responsible enough to verify the rules on their own components.
Also note that the ranges of adjustment are approximate especially on the camber bolts, the shop told me they were only able to get about -0.8 degrees of additional camber out of my 16mm eccentric bolt (Whiteline KCA416) just so you don't get kids mad the shop 'screwed me and only got me to -1.5' And the KW/RCE struts are slotted to allow for even more camber on the front, maybe others idk. |
03-29-2016, 02:33 AM | #8 |
Drives: TOYOTA
Just thought I'd note – it appears HVT is no longer around (which sucks because I have no more customer support should I need it). Their webpage (hvtauto.com) is long gone and now redirects to a inactive Facebook page. An address is listed, but no phone number or email.
The Following User Says Thank You to Ro_Ja For This Useful Post: | finch1750 (03-29-2016) |
03-29-2016, 05:26 AM | #9 |
Junior
Drives: a car
theres an app for that... now i can say
Yes, theres a thread for that.
The Following User Says Thank You to cdrazic93 For This Useful Post: | finch1750 (03-29-2016) |
03-29-2016, 08:55 AM | #10 |
Good job finch
You wanna make one of these for every component? That'd be great kthxbye |
03-29-2016, 10:26 AM | #11 |
Drives: 2014 GT86
imho for this to be stickied it should be a bit more extensive. As in components listed in table with marks if STX legal or not or available in both configurations or no data. Yes, certainly everyone should be able to verify by themselves if component fits by rules, but if info in thread will help saving time for few hundred of users, is it sin to not make those hundreds each and every to redo information search and reading lot of product descriptions/class rules/many threads of lot of pages with lot of noise in them too?
Few more bits worth adding: - why alignment is worth doing for everybody (with reference of broad stock ranges to even new and completely stock car), not just trackday junkies - few generic camber/toe number sets advisable for street/mixed/track - maybe also link to some DIY alignment thread? |
The Following User Says Thank You to churchx For This Useful Post: | finch1750 (03-29-2016) |
03-29-2016, 11:01 AM | #12 | |
Not a troll
Alignment importance General alignment specs, with tons of results DIY Alignment All of this was found within seconds of using some basic search terms. If people didn't want to be spoon fed, then they'd do the legwork for themselves. Instead, we have people who want to coddle new/inexperienced members, instead of encouraging them to do some research on their own. |
03-29-2016, 11:02 AM | #13 | ||
03-29-2016, 11:23 AM | #14 | |
K Thanks Bye |
Similar Threads | ||||
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear | deedz | Brakes, Suspension, Chassis | 11 | 03-17-2015 03:29 AM |
SPL Adjustable Suspension Arms?? | Trmx2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-28-2013 01:22 AM |
KW Suspension ** Club Sport with 2 Ways Adjustable ** | RavSpec | Brakes, Suspension, Chassis | 0 | 09-26-2013 03:22 PM |
Ground Control Complete Coilover Suspension Kit and Adjustable End Links | Eric1855 | Brakes, Suspension, Chassis | 12 | 05-26-2013 12:02 AM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
