Old 10-21-2017, 11:47 PM   #29
srscion
srscion's Avatar
Drives: 2016 FRS
Never-mind, I found it. 13 ft lbs
srscion is offline   Reply With Quote
Old 02-14-2018, 09:23 PM   #30
GrantedTaken
Brake caliper mounting bracket?
Brake caliper slide pins?
GrantedTaken is offline   Reply With Quote
Old 02-15-2018, 12:31 AM   #31
FirstWinter
Drives: Car
Front Caliper mounting bracket - 59 ft lbs
Rear Caliper mounting bracket - 49 ft lbs
Caliper slide pins - 19 ft lbs (I use hand tight. Don't have to over do it.)
FirstWinter is offline   Reply With Quote
The Following 2 Users Say Thank You to FirstWinter For This Useful Post:
jflBRZ (06-27-2023), zeal86 (02-15-2018)
Old 06-06-2018, 03:15 PM   #32
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
Can someone help me identify the nut circled in blue? Trying to find out how much it should be torqued. I'm assuming all 3 should be torqued the same, let me know if this isn't the case.
Also, the ones in red, all four should be 12ft/lbs, correct?
Zoid is offline   Reply With Quote
Old 06-06-2018, 03:25 PM   #33
johan
Drives: '14 981CS, '99 NB1
Also, the ones in red, all four should be 12ft/lbs, correct? - yes
Strut Tower (FR) | 17
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
zeal86 (06-06-2018), Zoid (06-06-2018)
Old 06-16-2018, 06:41 PM   #34
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I think I have an exhaust leak. Car has some high-pitch tin/metallic sound between 2.9K to 3.1K rpms coming from the front. I have all the gaskets in place, but I tightened everything by hand. Looking to tighten by torque spec now.
I'm not sure what the terminology here is, though. I'm used to seeing "header, frontpipe, overpipe". Could someone define as like "header to overpipe", "overpipe to frontpipe", "frontpipe to midpipe"?
Exhaust - bolts securing bracket of exhaust pipe assembly (FR) | 36.9
Exhaust Manifold Sub-Assembly | 22.1
Exhaust Pipe Assembly (FR) | 31.3
Exhaust Pipe Assembly (CTR) | 13.3
Exhaust Pipe Sub-Assembly (FR) | 25.8
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 06-17-2018, 12:56 AM   #35
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Did you install a header? Mine had a slight leak, but grimmspeed gaskets (thicker than oem) and some high temp rtv on all the gasket locations fixed it
Old 06-17-2018, 01:54 AM   #36
Lakitu
Lakitu's Avatar
Yeah I installed it all myself, and need to get back under the car to torque everything down. The bolts and the flanges on my headers where they connect to the engine are also SUPER rusted to hell. I think those may have been leaking for months....
Just trying to confirm what these correspond to:
Exhaust - bolts securing bracket of exhaust pipe assembly (FR) | 36.9 (manifold->header?)
Exhaust Manifold Sub-Assembly | 22.1 (header->overpipe?)
Exhaust Pipe Assembly (FR) | 31.3 (overpipe->frontpipe?)
Exhaust Pipe Assembly (CTR) | 13.3 (frontpipe->midpipe?)
Exhaust Pipe Sub-Assembly (FR) | 25.8 (midpipe->muffler?)
Assuming that they are in order from engine to muffler.
Old 06-17-2018, 03:09 AM   #37
FRSBRZGT86FAN
Yea, I installed mine myself as well, when you go through a few heat cycles btw as the bolts loosen and such and need to be tightened a little past those torque values.
The 6 header bolts on the motor are 22 ft lbs, I tightened them to 24 on the second reinstall with the RTV
The header to overpipe is 26 ft-lbs, that I kept the same with the rtv and new gaskets
32 ft-lbs on the 2 nuts that connect the Front Pipe to the Over Pipe.
37 ft-lbs for the Front Pipe hanger bolt.
13 ft-lbs on the 2 nuts that connect the Front Pipe to the midpipe (mid pipe is part of the "catback")
As for the muffler to mid-pipe, I'd go as snug as you can feel because I'd assume they'd be anywhere from 13-25 ft-lbs
So here's what the service manual list corresponds too:
Exhaust - bolts securing bracket of exhaust pipe assembly (FR) | 36.9 (front pipe hanger)
Exhaust Manifold Sub-Assembly | 22.1 (6 bolts that connect the header to the engine)
Exhaust Pipe Assembly (FR) | 31.3 (frontpipe to over pipe)
Exhaust Pipe Sub-Assembly (FR) | 25.8 (header to overpipe)
You really shouldn't be fretting over these numbers though as they most likely aren't whats causing an exhaust leak, also if you're not used to it aftermarket headers are thin walled and make way more noise. Also try and feel around the exhaust sections during a cold start (being careful) and feel for warm air while the exhaust isn't too hot.
My fix for these woes with just a header and axleback was high temp exhaust rtv and grimmspeed gaskets, makes up for manufacturing errors and other problems and works perfectly.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Lav (09-12-2022)
Old 06-17-2018, 03:11 AM   #38
FRSBRZGT86FAN
Also adding to my last post, I realized you have an OFT. Datalog your LTFTs and other stuff like AFR, MAF, IAM etc and post them on datazap.me and post it in the tuning section, and you will definitely get people to help you figure out if theres a legitimate leak. LTFTs get higher percentages when a leak is present usually (unless your running e85 like myself and they are all over the place naturally lol)
Old 06-17-2018, 03:24 AM   #39
Lakitu
Lakitu's Avatar
Thanks! I've been driving around looking at the numbers on the OFT, the LTFT is about -17.00 to -18.00 at idle, and STFT is 0.00. Not sure if that's worth anything, but I'll do what you said. Going to tighten the bolts up and take a look again, then post them.
Old 06-17-2018, 03:31 AM   #40
FRSBRZGT86FAN
If your LTFT is that you definitely have a problem it should ideally be between +/- 10, so you most likely have a leak somewhere. Definitely look for signs of a leak i.e. soot and such around the exhaust system.
It also could be high because you have a grimmspeed CAI and your maf hasn't been scaled?
@steve99 can look into it better
Old 06-17-2018, 09:58 PM   #41
steve99
yeah -18 ltft sounds like a problem somewhere
The grimspeed intakes are very close to stock scalng might throw trims of a couple of percent but not -18%
Exhaust leaks usually make ltft go way positive
check you intake install for leaks check catch can if you have one. make sure the tiny gasket on the maf sensor is not torn or creased
but if your on petrol with a petrol tune -18% ltft indicates a problem
check you didnt flash an E85 tune by mistake
Old 06-17-2018, 11:15 PM   #42
FRSBRZGT86FAN
Yea, I thought so thanks for clarifying steve. I think its best you datalog after you make some adjustments @Lakitu
BRZ Steering Right Tightening + VSC Fault?? BRZ2Bars Issues | Warranty | Recalls / TSB 4 05-07-2015 03:58 PM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) -- General Topics 20 10-16-2014 05:38 PM
Front Oxygen Sensor Scaling - How do we make it read richer values? D-VO Software Tuning 7 05-08-2014 04:48 AM
Safe values? mike_ekim1024 Software Tuning 12 11-05-2013 01:19 PM
Tightening the Rear scottynoshotty Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 05-16-2013 12:57 PM
