DIY (Do-It-Yourself) Guides For all DIYs. |
03-30-2015, 07:29 PM | #1 |
Drives:
DIY: 86 Tightening Torque Values
Having as many torque vaules in one place as possible will hopefully save time for some of you do-it-your-selfers.
Please add or correct errors in the list I have compiled by posting the following and I will update the list : • proper name for part/best description of part • torque value (please convert to ft/lbs whenever possible) • location of the part • post image of and/or link to schematic, diagram, drawing, illustration, figure, etc... 86 Tightening Torque Values (**In ft/lbs unless otherwise noted**) __________________________________________ Engine/Transmission __________________________________________ Air Intake Boot Clamp (Except for Air Cleaner Case) | 1.5 Air Cleaner Case | 4.4 Air Intake Boot Clamp (Air Cleaner Case) | 2.2 Automatic Transmission Drain Plug | 7.4 Automatic Transmission Fluid (ATF) Overflow Plug | 27.3 ATF Refill Plug | 27.3 Belt Covers (#1 & #2 ) | 4.7 Cam Plate | 12 Clutch Push Rod Lock Nut | 5.9 Crank Pulley | 94 Differential Gear Oil Drain & Filler Plugs | 36.1 Differential Carrier Assembly - Rear Upper Mounts | 46 - Rear Lower Mounts | 70 Engine Grounded Cable | 5.5 ft/lbs / 66 in/lbs Engine Mounting Bracket Nut (FR) | 33.2 Engine Mounting Bracket Bolt (FR) | 26 Engine Under Cover (#1) | 22.1 Engine Under Cover (#2) | 5.5 ft/lbs / 66 in/lbs Exhaust - bolts securing bracket of exhaust pipe assembly (FR) | 36.9 Exhaust Manifold Sub-Assembly | 22.1 Exhaust Pipe Assembly (FR) | 31.3 Exhaust Pipe Assembly (CTR) | 13.3 Exhaust Pipe Sub-Assembly (FR) | 25.8 Fuel Injector (CM) | 4.7 Fuel Pump | 62.7 Fuel Tank Protector No. 3 | 80 inch/pounds Ignition Coil | 6.3 Intake Manifold Protector (LH & RH) | 6.3 Oil Filter (80mm Wrench) | 10.3 Oil Filter Union | 33.2 Oil Pan Drain Plug | 28.9 Sound Creator | 4.4 Sound Creator clamp | 1.5 Spark Plug | 12.5 Steering Shaft Joint | 25.8 Transmission Drain & Filler Plugs | 27.3 Vacuum Booster Operating Rod Lock nut | 16.2 __________________________________________ Chassis/Suspension/Wheels/Brakes __________________________________________ Body Mounting Cusion Sub-assembly (Rear LH & RH) | 44 Brake Bleeder Valve (R) | 5.9 Brake Line | 24 Cross Member Sub-assembly (FR) | 70 End Link (at Lower Control Arm) | 28 Gearbox | 44.3 Knuckle Ball Joint Castle Nut | 19.9 Lower Arm Suspension Assembly | 38 Lower Arm Support Plate Bolt | 81 Lower Arm Support Plate Nut | 81 Lower No. 2 Arm Bush (Front LH & RH) | 63 Lower Suspension Arm Bolt (FR) | 81 Parking Brake Cable Assembly No. 2 Clamp Bolt | 13 Parking Brake Cable Support Bracket | 13 Rear Body Mounting Cushion Sub-Assembly Bolts | 44 Stabilizer Bar Bushing No. 1 Front Stabilizer (End) Link Assembly (FR LH & RH) | 34 Stabilizer Bracket (R) | 22 Stabilizer (End) Link (FR) | 34 Stabilizer (End) Link (R) | 28 Steering Knuckle | 114 Strut Top Nut (R) | 41 Strut Tower (FR) | 17 Strut Tower (R) | 22 Strut Tower Bars | 12 Suspension Arm Bolt (Rear) | 81 Suspension Arm Bushing Bolt No. 1 (R) | 81 Suspension Member Sub-assembly: **Front Support | 52 (14mm) , 107 (19mm) **Rear Support | 107 (19mm) Stabilizer Bracket Bolts (FR) | 55 Stabilizer Bracket Nuts (FR) | 18 Sway Bar Bracket (R) | 44 Tie-Rod End Lock Nut | 62.7 Tie-Rod End Sub-assembly LH & RH | 20 Toe Adjust Cam | 74 Toe Control Link Sub-assembly (LH & RH) | 44 Upper Control Arm Assembly (Rear LH & RH) | 66 Wheel Lug Nuts | 89 __________________________________________ projekt zeal86 build Last edited by zeal86; 02-02-2016 at 08:59 PM. |
The Following 28 Users Say Thank You to zeal86 For This Useful Post: | 8R6 (02-01-2016), airrick (04-08-2020), Andrew025 (04-03-2015), ap5512 (04-05-2015), Ayrton (02-13-2016), Calum (04-03-2015), CxG (06-12-2018), DandoX (02-10-2020), DarkestBuddha (03-30-2015), fstlane (04-03-2015), funwheeldrive (03-25-2018), GhostOp86 (04-03-2015), gtengr (10-22-2017), juliog (04-09-2017), Kaotic Lazagna (04-08-2015), Keenercarguy (06-09-2017), melon (04-04-2015), mgarcia707 (03-10-2020), microSDHC (12-12-2018), mit_peid (04-03-2015), mokinbird87 (01-10-2017), No1der (04-03-2015), Shankenstein (02-03-2016), smg1138 (05-11-2016), STV3 (02-01-2016), Sugi (04-05-2015), SuperDave (08-28-2017), TIE Pilot (04-03-2015) |
03-30-2015, 07:31 PM | #2 |
Drives:
I'm looking for the subframe bolt torque value...can anyone help me out with that?
thanks in advance. projekt zeal86 build |
03-30-2015, 09:06 PM | #3 |
Drives:
Also, I've come across some information that is conflicting... Is the torque value for the strut tower bar nuts (front) 17 ft/lbs or 11.8 ft/lbs?
04-02-2015, 07:03 PM | #4 | |
Drives: FRS
04-03-2015, 08:28 AM | #5 |
Hit the road and I'm gone
GrimmSpeed recommends 12 ft/lbs, but I torqued mine to about 20. No problem with the bolts, but I wouldn't go any higher than that. Otherwise, SNAP!!!
17 is probably good and tight and also nice and safe.
Slip, slidin' away.
04-03-2015, 08:46 AM | #6 |
Drives:
Anyone recognize these bolt identification markings. Trying to determine proper tightening torque. Thanks in advance.
M8x1.25 M10x1.25 projekt zeal86 build |
04-03-2015, 08:46 AM | #7 | |
04-03-2015, 08:59 AM | #8 |
04-03-2015, 09:08 AM | #10 |
04-03-2015, 09:17 AM | #11 |
Drives:
I understand that but most references I've come across have the classes as 4.6, 5.8, 8.8, 9.8, etc... I have not come across the ones I posted above.
04-03-2015, 09:18 AM | #12 | |
Drives:
04-03-2015, 09:28 AM | #13 |
OK. In case you haven't seen it, the full repair manual is here:
http://www.ft86club.com/forums/showthread.php?t=12135 If you download the portfolio version it is easier to navigate. It has all of the torque values with pictures. |
The Following User Says Thank You to jvincent For This Useful Post: | zeal86 (04-03-2015) |
04-03-2015, 01:25 PM | #14 |
That Guy
Drives: 2013 asphalt FRS MT
This should be stickied in the maintenance forum.
Similar Threads | ||||
BRZ Steering Right Tightening + VSC Fault?? | BRZ2Bars | Issues | Warranty | Recalls / TSB | 4 | 05-07-2015 03:58 PM |
BRZ Values | Apex_BRZ | BRZ First-Gen (2012+) -- General Topics | 20 | 10-16-2014 05:38 PM |
Front Oxygen Sensor Scaling - How do we make it read richer values? | D-VO | Software Tuning | 7 | 05-08-2014 04:48 AM |
Safe values? | mike_ekim1024 | Software Tuning | 12 | 11-05-2013 01:19 PM |
Tightening the Rear | scottynoshotty | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 05-16-2013 12:57 PM |
