Old 05-22-2016, 01:32 PM   #519
mechanick89
Drives: 2016 Scion FRS
Anyone tried the Enkei RP03 17x9.5 +38mm yet?
New size?
I believe it has been recently added to FT86SpeedFactory's website.
http://www.ft86speedfactory.com/enke...l#.V0Hsa5ErLIU
mechanick89 is offline   Reply With Quote
Old 09-04-2016, 10:41 AM   #520
ZX88
ZX88's Avatar
Drives: 22 BRZ
Originally Posted by WolfsFang View Post
Going to ask my question in here (hope someone see's it) in order to not clutter up the board with another wheel help thread.
Going to be ordering some new tires really soon. Now my question is should I run a staggered or square setup. My front wheel is 8.5 and I will be running a 215 on it. My rear is a 9 and im in debate if I want to run the 215 on it or a 225. I understand having a staggered setup will introduce more understeer, this is just my DD and I some sprinted driving around the mountains near me. Dont really plan on doing autox, maybe 4 times max this year, on that note im not concerned about my times, just more about having fun.
I have everything from the back of the front seats to the trunk gutted. I believe this moved some the weight balance more towards the front of the car so im thinking having the staggered wheels/tires will put some weight back to the rear.
With that stagger set up i will be surprised if you notice any additional under steer.
ZX88 is offline   Reply With Quote
Old 09-04-2016, 10:41 AM   #521
ZX88
ZX88's Avatar
Drives: 22 BRZ
New size?
That size is pretty common, xd9s come in that size and fit fine.
Old 09-08-2016, 08:42 PM   #522
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Yup haven't noticed any difference really. Been on a few spirited drives.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 09-20-2016, 03:44 AM   #523
SStratos
SStratos's Avatar
Drives: 2017 WRB Subaru BRZ
I have read much of this thread and others concerning wheels, fitment, and suspension, but though I have learned much from you all, I don't have any practical experience. My Question is:
Given that, the desired wheel diameter is 17 inches front and rear, and the desired wheel widths are 9inches front and 10inches rear, besides needing to switch to coil overs, what other modifications to suspension and ideal range settings for height and camber would work best for trying to stay as close to factory ride height as possible?
Also, what would be the optimal/ideal range of offset for a deep dish style wheel for the best performance?
Thank you for your assistance
I have read this thread, linked to below, which was linked earlier in this current thread but I am not looking to lower the car as much as this example:
http://www.ft86club.com/forums/showthread.php?p=1986950
SStratos is offline   Reply With Quote
Old 09-20-2016, 01:13 PM   #524
Leonardo
Country Boy 4 Life
Leonardo's Avatar
First of all, 17x9 and 17x10 wheels are rare. They are only going to come in specific offsets, or will be custom ordered with whatever offset is desired. Either way, you should find a wheel you like and go from there.
If you choose RPF1, if you can find them, they will be +35 or +45 front and +38 rear.
If you choose custom wheels like forgestar, you can choose the offset. Or better yet, you tell the manufacture what you want and they choose the "perfect offset" for you!
Now, tires. Staggering 17's sucks. You can't get 35 series. So you have to go bigger on the front to match. If you go 245/45 front you can go 275/40 rear for the same OD. Stock Diameter is 24.62". 245/45/17 is 25.68" or a 4.2% difference. the rule of thumb is to stay within 3% or less.
Here is a tire calculator. use it to find tires that are as close to the same OD (outside diameter) and different widths.
http://www.discounttire.com/dtcs/infoTireMath.do
All of this is why I have staggered 18. Good luck!
SStratos (09-21-2016)
Old 09-21-2016, 03:03 AM   #525
SStratos
SStratos's Avatar
Thank you! The wheels are going to be custom so any offset within reason will be available. Thank you for the wheel calculator link. So with the 4.2% difference being >greater than the "under 3% rule" is why you are going with 18's because 17's don't come in 35's but only 25's and 45's, is this correct?
Going with 9" fronts and 10" rears, what's the closest to stock drop and camber that can be run without hitting any of the break line brackets or other parts inside the wheel well if we use the offsets for the RPF1's from your example above 35 offset front and 38 offset rear?
Old 09-21-2016, 03:55 AM   #526
SStratos
SStratos's Avatar
Ah ha!
Ah Ha...not the 1980's band, the light bulb in my mind went off after I went to your link and put in OEM tires on one side and plugged in 275/45/r17's compared with 275/35/r18's:
The rear tires using the 17's would be traveling at 70mph when your speedometer was reading 65mph, were as using the 18's at 35 sidewall the difference is halved at only 67.5mph actual while speedometer is reading 65
and using 25's on sidewall with 17's goes the other way significantly....good call on the 18's...now I hope my custom shop will be able to make 18's in the style I want, hahaha
Old 10-10-2016, 11:46 AM   #527
b0mbA cLocK
Beware The Boricua
Drives: Toyota 86
Anyone know the brand of these rims?
b0mbA cLocK is offline   Reply With Quote
Old 10-11-2016, 06:08 PM   #528
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Gramlights57FXX, I believe.
Old 10-11-2016, 08:58 PM   #529
Tien0227
Tien0227's Avatar
Drives: FRS 10 Series MT
It's not quite the 57fxx... the spokes are not as curved and center caps seem off. Those are usually silver or red. I have the 57fxx in silver with red centercaps
Tien0227 is offline   Reply With Quote
Old 10-12-2016, 01:38 AM   #530
SStratos
SStratos's Avatar
Sizes...
Originally Posted by Tien0227 View Post
I would agree but its not quite... the spokes and center caps seem off. Those are usually silver or red. I have the 57fxx in silver with red centercaps
Beautiful wheels, what wheel dia. + width + tire size?
Old 10-12-2016, 08:39 AM   #531
Tien0227
Tien0227's Avatar
Thanks.
18x9.5+38 square
Front tires are 225 40
Rear tires are 255 35
Here's another pic. Spokes are more curved than the one above
Old 10-12-2016, 11:14 AM   #532
b0mbA cLocK
Beware The Boricua
Drives: Toyota 86
They look very similar to these BBS SL rims but they don't sell the same colors. I'm not sure if they are the brand. I don't think they are the 57fxx either. Still looking for them if anyone knows.
Thanks for the responses!
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 04:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 07:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) -- General Topics 6 10-28-2011 06:33 PM
