Old 06-28-2012, 07:51 PM   #1
bneale
bneale's Avatar
Drives: Scion FR-S
Stock Suspension and Wheel Fitment
Hello Everyone,
I asked this question in another thread and sort of got ignored. I also searched on here for a while but couldn't really find my answer.
I'm interested in getting some Enkei RFP1's in 17x9 size for track duty and autocross but I'm worried they may not fit on the stock suspension. Does anyone know if I'll run into any issues like rub at full lock?
From what research i've done, it seems the biggest issue is the front end. I'm pretty sure these wheels will fit fine on the rear, but the front seems like it might rub against the spring coil depending on which tire I run.
Right now I'm looking at 245's because 255's seem like they will rub. I'm looking at the Dunlop Star Specs for tires right now.
Thanks in advance for any insights you can provide.
bneale
bneale is offline   Reply With Quote
Old 06-28-2012, 09:44 PM   #2
Silp3
Silp3's Avatar
What are the offsets on them? It seems that the fenders on these cars are pre-rolled. Depending on your final offsets you might get away with it.
Use this link for reference. It requires Java
http://www.miata.net/garage/tirecalc.html
Silp3 is offline   Reply With Quote
Old 06-28-2012, 10:22 PM   #3
Silp3
Silp3's Avatar
Looked into it further. If the Offset is closer to +42, I think you'll be able to get away with a 255. No guarantee, however.
Old 06-28-2012, 10:30 PM   #4
Tritty250
Drives: Whiteout FRS
enkei rpf1's only come in 8" wide for 5x100 unless you custom order them, and to do that I think you need to be a distributor and buy in bulk. I could be wrong. 5x100 sucks
Tritty250 is offline   Reply With Quote
Old 06-28-2012, 11:53 PM   #5
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
bneale - if you've never autoX before you should stick with 17x7 size so you can stay in stock class. Soon as you go wider you're in with a lot of crazy dudes who have spent a lot of money in mods. You can put fat tires (like 235) on 17x7 anyway. Just a thought.
I'm waiting for Enkei to release the 17x7 size (I think it was announced already)
Khyron686 is offline   Reply With Quote
Old 06-29-2012, 01:45 PM   #6
bneale
bneale's Avatar
Drives: Scion FR-S
You're right, you have to custom order them. But even then, I can get a set of 4 in black for 265 a wheel as 5x100 and 17x9 size.
tirerack will order them for you on special order if you request it through them. That was my plan in order to get them.
bneale
Old 06-29-2012, 01:48 PM   #7
bneale
bneale's Avatar
Drives: Scion FR-S
Because I want to add an exhaust to my car, its going to bump me into STX class anyway. So STX is going to be my home. For now I'm starting in stock class (with street tires, new class apparently) but I will be going to STX as soon as I buy the wheels and tires.
So yeah, I know I can put bigger tires on my stock rims, but Ultimately I want to have 1 set for racing, and 1 set for road use. So in the end, I might as well just buy my STX wheels now.
Hence the reason why I want to confirm if 17x9 will fit on the stock springs. Once I've got the wheels and tires, i'll be doing suspension followed by exhaust and intake. Thats my mod list so far.
bneale
Old 06-29-2012, 02:03 PM   #8
bneale
bneale's Avatar
Drives: Scion FR-S
I think your right about the offset. But some people have said 255 will rub at full lock. So I was hoping a 245 tire wouldn't.
Any comments or ideas on this?
bneale
Old 06-29-2012, 06:23 PM   #9
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Hard to say, but I've seen the 17x9 RPf1s on the tire rack site and was wondering the same thing.
Might be worth checking out Matt Andrews' blog: http://fecompetition.wordpress.com/
He's been trying out 255s on his car with 6UL wheels from 949 racing.
I also think that member Scooby South on here has a similar setup.
Might work if the offset gods smile on you?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-29-2012, 07:24 PM   #10
bneale
bneale's Avatar
Drives: Scion FR-S
Yeah I read his comments actually. I found it to be very interesting.
The only issue is they were saying they had some rub at full lock with a 255 tire. I'm trying to avoid the tire rub and I think thats exactly why tirerack is suggesting a 245/40/17 tire for that wheel.
The other problem is, the only 6UL wheel they have is already sold out and 949 has not indicated that they will be receiving more. So those maybe off the market completely until they get more in stock.
So far I think the Mark V's seem to be the winners. They are the only ones I've sort of confirmed fit properly and a shop in town contacted me through another forum and asked me if I wanted to come down and test fit them. I found the Mark V's in the wheel thread sticky.
I'm still about a month or 2 away from ordering the wheels and tires so I have a bit of time before I need to confirm the fitment.
bneale
Old 06-29-2012, 07:25 PM   #11
Tritty250
bneale
cost on an enkei rpf1 that size is 400$ a wheel if I remember correctly...how are you getting quoted 265?
Old 06-29-2012, 07:42 PM   #12
Tritty250
nvm
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
Stock suspension: Why change it? Moshpit37 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 04-26-2012 07:34 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) -- General Topics 6 10-28-2011 06:33 PM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 04:36 PM
