Old 08-06-2013, 09:25 PM   #43
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
is there any better aftermarket coil plugs?
i want to replace all 4
Old 08-06-2013, 09:36 PM   #44
xjohnx
Grip>Slip
xjohnx's Avatar
I hadn't heard of any but searched after your post. Looks like Cusco makes some, but they're expensive, haven't heard any reviews on them: http://www.maperformance.com/cusco-d...cion-fr-s.html
Old 08-06-2013, 09:37 PM   #45
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
thats stupid expensive lol
Old 08-19-2013, 02:39 PM   #46
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
This hit me yesterday. I was running the car hard, shifted into second, looked down as the car seemed slightly sluggish to find a CEL. Taking it to Mastro Orlando tomorrow.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-26-2013, 12:01 PM   #47
Yruyur
Yruyur's Avatar
Got this morning on the way to work. Wot in 4th. No popping.
Running e85 with Visconti flex fuel kit. Cleared the code and did not come back the rest of the commute. Will try and reproduce it and switch back to pump and try again.
Sent from a Motorola DynaTAC 8000X
Old 08-28-2013, 10:51 AM   #48
Yruyur
Yruyur's Avatar
Any update on yours? Mine came back this morning after clearing the code the other day.
Old 08-28-2013, 02:37 PM   #49
Kido1986
Dodging cones
Kido1986's Avatar
Mine hasn't returned, and mine went through 4 runs at an autocross (though mind you, it was ~10F cooler day at this autocross with 4 runs than the one with 6 runs I popped the CEL on)
The Following User Says Thank You to Kido1986 For This Useful Post:
Yruyur (08-28-2013)
Old 08-30-2013, 11:33 PM   #50
Yruyur
Yruyur's Avatar
I got a data log tonight when the cel came back on tonight. Thought it would be interesting but didnt end up seeing anything that stood out.
Old 08-31-2013, 12:29 AM   #51
Carwhisperer
Drives: A lot of supercars.
Mine used to come on until a toyota tech flew in and looked at it. Checked DI seals since ive had leaks before, coil packs and said nothing was wrong.. once I got my car back I haven't had the p0351 pop up once.. so odd. Seems to run smoother and quiter than normal though. Used to get a crackling sound from the bay in 1st gear WOT in high rpms once the engine warmed up each morning. That's all gone.
Carwhisperer is offline   Reply With Quote
Old 08-31-2013, 07:49 AM   #52
mad_sb
Drives: 2013 Asphalt FR-S
I guess they unknowingly fixed something during the troubleshooting. That or they flashed a beta rom / replaced the ecu or DI driver box or something.
Old 08-31-2013, 08:41 AM   #53
Yruyur
Yruyur's Avatar
Bet they flashed.
Old 09-01-2013, 05:53 PM   #54
Carwhisperer
I guess so. Just extremely happy its running perfect. Starting to Love driving it again.
Old 09-04-2013, 08:10 PM   #55
danthedirt
Hadouken
danthedirt's Avatar
Drives: Whiteout FR-S
Was driving in the high desert and heard some loud popping coming from the front of the car as I was getting off the Freeway. Got a CEL a few days later, and I pulled a P0351 off of it. It cleared itself after a few days. No CEL's or popping since, but not sure what if I should still take it in to get inspected or wait and see. So happy i got the extended warranty since I'm over the 37k
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
Old 09-04-2013, 08:30 PM   #56
Carwhisperer
Loud popping and it went away? I would say check your DI's but if it went away that's odd.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
