Old 08-12-2012, 06:24 PM   #1
avusblue
avusblue's Avatar
Drives: 2013 FR-S, Manual, Argento
Shutting off your "key-in-with-door-open" beeper -- it's very easy
Have you ever been working on the car, or cleaning it, with the door open & key in, but can't stand that constant beeping from the "key-in" warning? Or, you're working in the garage when you want to listen to the radio with the door open, but that very same beeping prevents you? Disabling this door beeper is very easy -- assuming you're willing to use a tool.
See this bolt on your door jamb?
Loosen it a spin or two to shut off the beeper, then re-tighten it again when you're done.
Personally, I keep handy a common nutdriver with a 10mm socket and a tab of sticky-back velcro:
There's a perfectly shaped little well to store it in the gap between the driver's seat and the door sill:
Little details . . . make a difference!
Cheers,
Dave
avusblue is offline   Reply With Quote
The Following 2 Users Say Thank You to avusblue For This Useful Post:
eriktherod (08-12-2012), YinYang1980 (08-13-2012)
Old 08-12-2012, 10:06 PM   #2
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Does your door light still work? Does the car still know when the door is open?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 08-13-2012, 05:29 PM   #3
avusblue
avusblue's Avatar
Loosening the bolt essentially makes the car think the door is shut. The interior light will gradually fade out. Most importantly, the window scoots upward its last inch, as though you had closed the door. So I suggest you don't try to shut the door with the bolt unscrewed. You won't harm anything, but it takes extra force that's probably not good for the window or seals.
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Odometer Functions - "S" & "G" What are they? kablammo BRZ First-Gen (2012+) -- General Topics 59 12-01-2013 12:28 AM
Door Open Buzzer cmspooner Cosmetic Modification (Interior/Exterior/Lighting) 5 08-13-2012 10:20 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
