DIY (Do-It-Yourself) Guides For all DIYs. |
06-24-2018, 01:45 AM | #43 |
Drives: 2017 Halo 86
Hello, what is the axel nut torque spec? Seems to be missing.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
The Following User Says Thank You to Lakitu For This Useful Post: | Ryan GT86 (02-12-2019) |
06-24-2018, 03:00 AM | #44 |
140 ft-lbs according to this thread: https://www.ft86club.com/forums/showthread.php?t=45949 FYI (for anyone actually) if you're looking for torque specs on things not named on this list at the start of this thread. Google or look for DIYs on installs for the thing your doing. Even aftermarket parts will tell your their torque values which they most likely pulled from the OEM service manual.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | gravitylover (03-23-2019) |
08-25-2018, 11:51 AM | #45 |
Drives: 2019 Mazda Miata RF
Anyone put this into pdf, or a spreadsheet, so it can be printed, and put in toolbox/posted on wall?
The Following User Says Thank You to Gunman For This Useful Post: | RL_BRZ (09-06-2018) |
03-04-2019, 05:53 AM | #46 |
Drives: 2019 Toyota 86
https://www.counterspacegarage.com/a...ut-bar-brz-frs
Does anyone know which torque values to use? I know there's these values. Strut Tower (FR) | 17 Strut Tower (R) | 22 Strut Tower Bars | 12 But I'm not sure which corresponds to which.
03-04-2019, 06:36 AM | #47 | |
Drives:
>>The long brace going across from strut tower to strut tower is the higher torque value... the shorter bars that connect to the firewall are the lower torque value. The other value is for the rear strut tower brace. Make sure to use a calibrated torque wrench. Good luck... IG @zeal.eightsix |
03-04-2019, 02:43 PM | #48 | |
04-08-2019, 04:55 PM | #50 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
I’m removing an oil pressure sensor that’s tapped in the engine galley. I got SU003-00108 but I need the torque value to tighten it to.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
05-14-2019, 11:49 AM | #51 |
Drives: BRZ Series HyperBlue
Thanks for the useful thread, it's been helpful.
06-18-2023, 03:41 AM | #52 |
Drives: gt86
Hello, I didn't understand exactly and I don't know its name. I want to tighten the central nut inside the front coil and also the rear coil because I changed the springs, but I don't know how many newton meters it should be for the front and rear? Please help me, thank you
06-18-2023, 09:16 AM | #53 | |
Drives: 2018 BRZ
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | r4mr4m3024 (06-20-2023) |
06-19-2023, 10:34 AM | #54 |
Drives: gt86
Thank you, and how many newton meters should the anti-roll bar link front be tightened?
06-20-2023, 07:43 AM | #55 |
Drives: 2018 BRZ
06-20-2023, 12:42 PM | #56 |
Drives: gt86
Hello, dear guys, I would like to ask you for an opinion. I would appreciate it if you could give me your opinion. I bought short springs for my car, brand H&R, the original element, my element, then I changed the spring connection base, the screw inside the shock absorber coil and the front stabilizer, and I changed the screws. I didn't use a torque meter, I tightened them as far as possible, I drove the car for a while, everything seems to be ok, is that the case or should I be worried about something? Of course, I went through all the steps with the specialized video on YouTube, I did the right steps, but I didn't torque the screws of the shock absorbers and stabilizers with a torque meter, and I tightened them as much as I could with my hands.
Similar Threads | ||||
BRZ Steering Right Tightening + VSC Fault?? | BRZ2Bars | Issues | Warranty | Recalls / TSB | 4 | 05-07-2015 03:58 PM |
BRZ Values | Apex_BRZ | BRZ First-Gen (2012+) -- General Topics | 20 | 10-16-2014 05:38 PM |
Front Oxygen Sensor Scaling - How do we make it read richer values? | D-VO | Software Tuning | 7 | 05-08-2014 04:48 AM |
Safe values? | mike_ekim1024 | Software Tuning | 12 | 11-05-2013 01:19 PM |
Tightening the Rear | scottynoshotty | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 05-16-2013 12:57 PM |
