03-22-2014, 10:11 PM | #85 |
Drives: FRS, Supra, Colorado D, GLC63
Stupid question, but can I disable the TPMS monitors with this?
03-23-2014, 08:25 AM | #86 |
Drives: FR-S 6MT
03-23-2014, 08:26 AM | #87 |
Drives: FR-S 6MT
The Following User Says Thank You to Mikem53 For This Useful Post: | The Racers Line (03-23-2014) |
03-27-2014, 07:27 AM | #88 |
Drives: Lexus GS350 2014
Hi , thanks for this amazing thread
I was wondering can Techstream make seatbelt alarm OFF and speed warning as well ? my car is Lexus GS350 model 2014 also I think Ver 9.00.026 is out, anything new about it or its not worth the time looking for download and activation links for it ? Thanks again rated Excellent for the thread |
03-27-2014, 07:06 PM | #89 |
Drives: Scion FR-S
Can anyone else confirm whether or not keys can be added with this using a tatrix2 cable? I tried via the older software on a WinXP machine as well as with the new 9.00.025 software and no dice with either.
The Following User Says Thank You to accelerated For This Useful Post: | SSchifko (02-11-2015) |
03-29-2014, 12:01 PM | #90 |
Drives: BRZ-L
Thanks for this post, just waiting on my cable from china. I'm getting impatient to change these terrible default settings.
03-30-2014, 06:08 AM | #91 |
So I got my MINI VCI from Amazon.com
this is the link for it: [ame="http://www.amazon.com/gp/product/B00C9B32J4/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1"]Amazon.com: Fotga Newest V8.00.034 MINI VCI for TOYOTA TIS Techstream Diagnostic Cable & Software: Car Electronics[/ame] and I used the software on this thread the V9.00.025 with the Easy activation , on a Windows XP SP3 with a Java v7 everything worked just fine and I can go into settings and change many things and check for health and such I was able to turn off the Seat belt warning for Driver seat and passenger seat , I also made the sensors stop buzzing if the distance between me and and obstacle did not change for 3 sec (was annoying on Red light stops). but one of the most annoying warning is the Speed warning ! that I was not able to change or even find anything relate to it! not sure why the car comes with 120km speed warning and our roads are between 120km to 130km when I drive I always go between 115km to 125km which almost make the buzzing active all the time (when I reach 120km it buzz for 9 tics then goes off) so going up and down in speed around 120km will trigger the speed warning which is pretty annoying ! did anyone ever was able to disable the speed warning or change the speed warning limit ? Thanks again so much for this thread, it helped me a lot |
03-31-2014, 08:56 PM | #92 |
Drives: BRZ-L
In case anyone is wondering, I can confirm this works on a Macbook Pro using Parallels to run Windows XP SP3 on the latest version.
The Following User Says Thank You to CIAGDDS For This Useful Post: | Trap63 (04-04-2014) |
04-03-2014, 06:50 PM | #93 |
Drives: 2014 BRZ Limited SSM
Ok, I purchased the cable, and downloaded the software from OP's links, but I am having trouble activating the Toyota TechStream Software. How is everyone else activating the software? It says I need a registration code. Who can provide me with one for TechStream Version 9.00.025 with Software ID: E6F1C05FD268B97BE2DED1366BF7A6A? Anyone's help is greatly appreciated as I can't do anything until I activate the software!
04-03-2014, 06:52 PM | #94 | |
Hey I just saw you have the same cable I have, and are using the same software version I am....I am unable to activate, what am I missing here? You said something about the EZ activation, can you send me a link or tell me where to find this? Thanks! |
04-03-2014, 08:47 PM | #95 |
Alright...nevermind the questions about activating the software. I deleted both the TechStream program and the MVCI Firmware drivers, reinstalled them in reverse order and everything works great! I purchased my BRZ 3.5 weeks ago and the TPMS sensor light came on about 10mins after leaving the dealer. It's stayed solidly lit, so I assumed they just forgot to initialize the TPMS sensors during the pre-sale checklist. The car was NEW, it has 1 mile on it when I bought it. So, it definitely wasn't driven enough by the dealer to trigger the TPMS light until I got behind the wheel. I have an appointment to take the car in and get this fixed early next week but I wanted to figure out what was causing the problem before I went in. Sure enough, once I got TechStream working, it showed me that "Tire Pressure Monitoring Sensor #3 is not registering and has a problem". I was also able to turn off the seat belt buzzer, make both doors lock, and/or unlock at the same time when I touch the drivers door handle, and turn the security system on (it's off by default on the BRZ). I went through and changed a few other things as well, like how long I have to push the trunk pop button under the trunk lid before it opens and I adjusted the length of time that the interior and auto lights stay on. This is fantastic software, it was a little difficult to get working at first since I the Activation screen kept popping up and wouldn't allow me to do anything, but once I got that fixed, it's a powerful utility, that everyone with an 86 should have access too! Thanks OP for the links and info!
The Following User Says Thank You to 2014BRZ_kcrow For This Useful Post: | Trap63 (04-04-2014) |
04-04-2014, 08:49 AM | #96 |
I finally bought a Tatrix. can techstream adjust to where the keyless unlock unlocks both doors?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
04-08-2014, 08:45 PM | #97 |
[||•]=(86)=[•||]
Drives: 2017 Toyota 86
If you need to run it on a 64Bit computer follow this procedure. It worked fine for me!
http://www.toyota-4runner.org/genera...-8-64-bit.html
The Following 3 Users Say Thank You to trueno86power For This Useful Post: |
04-08-2014, 09:00 PM | #98 | |
Drives: 2015 Yuzu RS1.0 Scion FR-S #893
I used this same tutorial a couple days ago. Was able to install it and everything unlike before. Only issue I have now is I can't communicate with any modules on the car. I gave up after a couple hours of messing around with it. |
Similar Threads | ||||
TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 01:28 PM |
anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 11:03 AM |
Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 03:46 PM |
Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 07:47 PM |
