Old 08-05-2012, 02:01 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Tools for DIY maintenance?
Being an engineer, I am always learning something new. Goes the same for the FR-S; this will be my car where I do most of the maintenance. Need to build up my tool kit. After browsing many of the DIY threads I came up with the following minimum tool list that should cover 90% of the maintenance and modification work I'd be doing (belts, brakes, fluids, batteries, rotations, exhaust swaps, side marker swap, etc). Might try spark plugs and suspension.
Tool box
3/8" drive socket wrench
3/8" drive torque wrench
Various Length 3/8" drive extensions
10mm 3/8" socket
12mm 3/8" socket
14mm 3/8" socket
14mm combination Wrench
1/2" drive torque wrench (Thanks cmspooner)
19mm 1/2" socket (Thanks cmspooner)
Various Length 1/2" drive extensions (Thanks cmspooner)
Long Flathead Screwdriver
Long Phillips head Screwdriver
Racing Jack
4 Jack Stands
Wheel Chocks
Wheel Lug Wrench
Drain Pan
2 Funnels (clean/dirty)
Tire Pressure Meter (Thanks mediumbrown)
Air Compressor (Thanks mediumbrown)
Flash light (Thanks mediumbrown)
Shop Towel (Thanks mediumbrown)
C-Clamps (Thanks Calum)
What else should I be looking at to make a minimal kit? I don't have a garage; have to carry these things to my family/friend's. I appreciate the feedback.
F1point4 is offline   Reply With Quote
Old 08-05-2012, 02:50 PM   #2
mediumbrown
mediumbrown's Avatar
Drives: 2013 Argento Scion FR-S
don't forget the essentials:
tire pressure gauge & air compressor
shop rags
flashlight [ame="http://www.amazon.com/Nebo-Highbeam-Rechargeable-Flashlight-Lumens/dp/B003Z3SLE6/ref=sr_1_12?ie=UTF8&qid=1344192369&sr=8-12&keywords=car+charger+flashlight"]something like this... plug it inside the glovebox[/ame]
mediumbrown is offline   Reply With Quote
The Following User Says Thank You to mediumbrown For This Useful Post:
F1point4 (08-05-2012)
Old 08-05-2012, 06:50 PM   #3
Xauterus
Drives: GTS 86 Galaxy Blue
You had better look at the workshop manual for changing spark plugs. It's a major task.
Xauterus is offline   Reply With Quote
Old 08-05-2012, 07:14 PM   #4
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
cordless impact wrench FTW!
NeedsmoreCowbell is offline   Reply With Quote
Old 08-05-2012, 07:45 PM   #5
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
Don't bother with a small number of specific wrenches...get a full socket set with both metric and us sizes. You should also get a full set of combination wrenches. You will probably need a 1/2 inch torque wrench as the lug nuts are 19mm. You should also get a short 1/2 inch extension because the lug nuts are very deep, I picked up a 3 inches and it made a world of difference. You will also need ramps with extensions so you can get your car onto them without scraping.
cmspooner is offline   Reply With Quote
Old 08-05-2012, 08:55 PM   #6
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Snap On.
Thats it.
Oh and if your in high school you can get 50% off all Snap On products, i learned that a month after high school ended for me...nice.
Old 08-05-2012, 09:03 PM   #7
F1point4
Photo Specialist
F1point4's Avatar
Thought I might need a 1/2" wrench/torque wrench for the wheels. Yea the plan was to buy sets, however I wanted to see what we specifically needed for this car. Appreciate the feedback
Is there a specific use for ramps that a jack and stands can't do?
F1point4
Old 08-05-2012, 09:19 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
F1point4
It's mainly personal preference. I prefer to work with the car on ramps, I trust it more, but it's really all in my head.
Don't forget a BFH and a crow bar, maybe a c-clamp for putting caliber pistons back in place. Also a pickle fork for the various ball joints throughout the suspension.
Old 08-05-2012, 10:05 PM   #9
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I heard dealer had a special tool to reduce R&R Spark plug time...
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 08-05-2012, 10:29 PM   #10
F1point4
Photo Specialist
F1point4's Avatar
Agreed. I think ramps are safer too. Just less versatile when it comes to tire rotations.
What is a BFH? What might I use a crow bar for? Do I need to get the Freeman crowbar?
Old 08-05-2012, 10:34 PM   #11
mediumbrown
big f*cken hammer BFH
Old 08-05-2012, 10:49 PM   #12
F1point4
Photo Specialist
F1point4's Avatar
Love to, but I think it's not a required tool.
I heard both of these were true. Maybe I won't do my own plugs :/
Thanks!
Old 08-05-2012, 11:17 PM   #13
cmspooner
cmspooner's Avatar
No, but ramps can be more convenient for quick things like oil changes...and they are very stable. They are easier, and I feel safer, for doing solo work. You should also get some chocks.
Old 08-06-2012, 12:29 AM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Milwaukee 450ft/lb lithium ion 1/2" cordless impact gun!
Milwaukee 185ft/lb lithium ion 1/2" cordless impact gun! (for the small areas)
Lithium Ion, cordless LED shop light.
AIM Solo GPS OBD2 lap timer + data acquisition
Longacre digital tire pyrometer. (tire pressure gauge already mentioned)
GoPro/Contour/Drift Innovation camera plus suction cup mounts.
5 gallon air tank
Extra set of wheels with track tires mounted
Sparco gloves, Snell2010 helmet, driving shoes
whoa.. I think I was distracted there.
The Following User Says Thank You to rice_classic For This Useful Post:
Tor (01-01-2016)
alcantara maintenance. wallace03 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 07-07-2012 08:49 AM
Photo Proof: Scion FR-S loaded with 4 mounted wheels and track tools ahausheer FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 74 02-17-2012 06:18 PM
Why are Civic owners such tools? LexusFman Other Vehicles & General Automotive Discussions 29 11-28-2011 06:20 PM
AMT, Air Maintenance Technology 1660 Off-Topic Lounge [WARNING: NO POLITICS] 7 08-28-2011 03:15 AM
