02-02-2016, 10:54 PM | #1 |
Drives: 2013 White-Out FRS
South Bay Wheel Stud Replacement?
Wheel stud broke off probably 5000 miles ago, lol. Need to get it replaced before I throw on 25mm spacers.
Anyone got a recommendation around the South Bay? I live in SJ if that helps.
I live my life one quarter-pounder at a time.
02-02-2016, 11:01 PM | #2 |
Sènior Member
Drives: '22 BRZ |'13 BRZ SSC (formerly)
Any place that does auto service really. It's a super simple and easy job.
02-02-2016, 11:11 PM | #3 |
I know Exact Motorsports has a press; they should be able to handle it.
02-03-2016, 12:14 AM | #4 |
Drives: 13' BRZ
As others have mentioned, any local auto mechanic shop can easily replace it.
If you have some time and basic tools, you could also replace it yourself. Front - Front Wheel Stud Replacement - Dave-ROR Rear - Rear Wheel Stud Replacement - Dave-ROR If you're feeling lazy and don't want to remove the hub, simply hammer the stud out, place the new one in, pull it through with a nut/washer. Read the posts in the linked threads though, lots of good information. |
02-04-2016, 04:56 PM | #5 |
Drives: 13 SWP BRZ
If doing stock, you can do it in the driveway without taking the hubs off with a $10 Harbor Freight tool. I did ARPs and took the hubs off and used a press; it was still not a huge job.
Similar Threads | ||||
Wheel stud replacement | Dave-ROR | DIY (Do-It-Yourself) Guides | 267 | 01-21-2022 08:20 PM |
HELP! Lug nut and wheel stud stripped! | jaydee_do_work | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 07-26-2015 01:50 PM |
Wheel stud options | chris86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-26-2014 02:40 PM |
Replacement Lug Stud/Wheel Hub | swift996 | Issues | Warranty | Recalls / TSB | 3 | 08-30-2013 01:58 PM |
Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 02:42 AM |
