Old 03-10-2016, 10:18 AM   #1
carczar_84
Drives: 2015 Subaru BRZ - Limited
Konig Hypergram?
Looking into a new set of wheels for my BRZ and came across the Konig Hypergram. Has anyone had any experience with these, or seen them first hand?
I would be looking at a 17x8 or 17x9.
http://konigwheels.com/wheels/flow-f...els/hypergram/
carczar_84 is offline   Reply With Quote
The Following User Says Thank You to carczar_84 For This Useful Post:
NWFRS (03-13-2016)
Old 03-10-2016, 10:20 AM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I doubt anyone will have a lot of experience with them, because they literally just came out like a month ago.
jawn is offline   Reply With Quote
Old 03-10-2016, 10:43 AM   #3
carczar_84
I kind of figured as much since they are so new.
They caught my eye because of the offsets available. It is available is a 17x8 and 17x9 +40 which I thought would be good with stock struts up front?
The weights look good too, at 16.3lbs and 17.5lbs.
MisterSheep (04-08-2016)
Old 03-10-2016, 10:45 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
go 17x8 keep it light.
SuperTom (08-03-2018)
Old 03-10-2016, 10:47 AM   #5
jawn
jawn's Avatar
Yeah, either size should be okay with stock fronts, depending on how big your tires are. Konig makes decent wheels.
The Following User Says Thank You to jawn For This Useful Post:
Old 03-10-2016, 11:38 AM   #6
carczar_84
I'm leaning toward the 17x9 with a 245/40R17 tire, probably a RS-3
The Following 2 Users Say Thank You to carczar_84 For This Useful Post:
CatDaddysBBQ (08-01-2016), MisterSheep (04-08-2016)
Old 03-10-2016, 10:39 PM   #7
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Hmmm not bad
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 03-14-2016, 11:37 AM   #8
carczar_84
What's the general consensus on stock strut clearance for a +40 offset? if +42 wheels clear (they do right?), these should be fine. I would be using crash bolts too.
Old 03-15-2016, 03:47 PM   #9
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Depends on what tire you use.
Depends on how much camber you plan on running.
+42 has a possibility of clearing, some people have to run 3mm spacers.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
The Following User Says Thank You to Phantobe For This Useful Post:
Monchiez (04-12-2016)
Old 03-15-2016, 06:15 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18×8.5 5X100 +38 17.41 lbs. Nice! Sadly these came out after my purchase.
Interestingly, they are slightly lighter than the 17x9 @ 17.49lbs.
Old 03-15-2016, 06:27 PM   #11
Sonic Motor
Drives: Scion FRS / BRZ / FT86
Send a message via AIM to Sonic Motor
Spoke to Konig this morning actually, and they said about 30 days till these are in stock, and ready to rock.
Sonic Motor is offline   Reply With Quote
Old 04-07-2016, 01:09 PM   #12
BoxerFour
Drives: 2014 Brz Sport tech
Just ordered a set in 17x8 for my track setup. Lightweight and Rotary Forged FTW!
BoxerFour is offline   Reply With Quote
The Following User Says Thank You to BoxerFour For This Useful Post:
Old 04-07-2016, 01:50 PM   #13
Vmax911
Drives: WRB BRZ
Where did you order them?
Vmax911 is offline   Reply With Quote
Old 04-08-2016, 11:12 AM   #14
BoxerFour
KX Wheels in BC. (I am in Canada) Est. arrival time 4-6 weeks.
http://kxwheels.com/kx/wheel/konig-w...te-grey-22b63/
Konig Rims- what do you think? KatrinaR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-25-2015 01:35 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
WTB- Konig Daylites solort Want-To-Buy Requests 0 01-07-2014 11:07 PM
Konig Wheels pghfan19 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-25-2013 12:24 AM
Konig deception oaroyale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 02-02-2013 09:02 PM
