Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-08-2016, 01:18 AM | #1 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Manual Trans gearing for 2017 model ?
I've read the differential gearing has been changed from 4.1 to 4.3
I've read that 6th gear has been strengthened. I've read that overall mileage figures are lower than older models. I cannot find anything about gear ratio changes within the manual six speed transmission. Certainly sixth gear must have been changed to allow for not too high revs at freeway speeds and above. Anyone have info on actual gear ratio changes ? |
09-08-2016, 07:56 PM | #2 |
Drives: 2015 FR-S MT Steel
Googled this just now:
http://www.cars.com/toyota/86/2017/specifications/
"No matter where you go, there you are" - Buckaroo Banzai
The Following User Says Thank You to wireman957 For This Useful Post: | ToySub1946 (09-08-2016) |
09-08-2016, 08:07 PM | #3 |
Now w/ over 400 womprats!
Drives: BRZ LZR
I don't remember reading about a ratio change in the official Toyota documentation. I believe it's still 0.767.
- The Ancient BRZ Sacrament by Zaku |
09-08-2016, 08:51 PM | #4 | |
09-08-2016, 10:18 PM | #5 |
Drives: White 2014 BRZ
So two shifts to 60mph now. You can just barely hit 60 slightly past redline with the 4.10s
JDL Turbo kit - Ecutek, HRI tuned.
09-08-2016, 10:28 PM | #6 | |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
I tried searching for the gearing
NARFALICIOUS
Noob Poster 1988 | 2016 |
09-09-2016, 12:05 AM | #7 |
goldenfri:
"Gear ratios are the same. You just run a bit more rpm at highway speeds, its not a huge jump." Well I guess my real concern was not for tracking, but how high my engine might rev at very high freeway speeds (causing poorer mpg). In the northwestern inland states and portions of west Texas speed limit can be 80mph...and of course, that means running 90mph or so in reality. Possibly Toyota and Subaru did not consider this. So I'm ready for a 7 speed as in Porsche and Corvette...if 6th gear ratio has not changed since 2016 models/combined with the now (for 2017) 4.3 diff. |
09-09-2016, 02:38 AM | #8 |
Drives: 2014 GT86
Or just do unexpected mod .. of installing 4.1 diff if you prefer older year ratios and mpg / rpms @ high speed are more important then acceleration.
09-09-2016, 02:43 AM | #9 |
Drives: Toyota 86 GTS
Just swap with someone with a older MY or an AT, there won't be a shortage of takers. You should even be able to get the other party to do all the work. The gearing on the MT is fairly short anyway so you won't be losing much either way. Take pity on the MY17 AT owners who got exactly nothing as an upgrade.
The Following User Says Thank You to Wayno For This Useful Post: | Guff (09-09-2016) |
09-09-2016, 04:47 AM | #10 |
Drives: 2014 GT86
.. hmm, on second thought, this is first time i heard of different MY2017 gearing .. and starting to think, if THIS might be the reason why bigger performance numbers are cited for new MT & not for AT, with no actual performance affecting changes to engine/ecu tune/etc? Otherwise why else AT would have no gains/improvements, it sounds illogical :/
09-09-2016, 06:24 AM | #11 |
No, it's because of new engine parts including both manifolds
09-09-2016, 10:27 AM | #12 | |
As someone that used to have an S2000 with 4.56 gears that thing would be at 5k+ cruising on the highway, it wasn't a problem and still got decent gas mileage. Last edited by goldenfri; 09-09-2016 at 03:58 PM. |
09-09-2016, 10:29 AM | #13 | |
04-03-2017, 03:41 PM | #14 |
Agent 86
Drives: 2017 Toyota 86
I don't know if you've found the information but in case you need something from Toyota, this PDF link is active currently... And it is 4.30 for the manual only.
http://toyotanews.pressroom.toyota.c...tions.download |
Similar Threads | ||||
FRS/BRZ Manual Trans Fluid | shellslinger | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 131 | 11-02-2017 10:44 AM |
Final Drive Gearing, Auto vs Manual | KoolBRZ | Engine, Exhaust, Transmission | 9 | 09-11-2017 09:50 PM |
2017 Model Year Improvements | FiReStorm2013 | Scion FR-S / Toyota 86 GT86 General Forum | 353 | 03-11-2016 03:07 PM |
Manual Trans 12k miles $750 OBO | Amir Ghadiri | Transmission and Driveline | 4 | 05-23-2015 02:35 PM |
Need a favor from a Canadian BRZ owner, (Canadian Base model with Manual Trans)) | boomslang | CANADA | 1 | 09-07-2014 11:24 PM |
