Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
11-18-2016, 03:58 PM | #1 |
Drives: 2015 Scion FR-S
ABS and Traction Control lights after taking clock spring out.
So I installed an aftermarket steering wheel using the NRG short hub adapter, but the one advertised for other scions not the FR-S. In order to install this short hub I needed to take out the clock spring, so I did, but now my ABS and Traction Control Light (the one on the center guage) are on. Anybody know how to get them to turn off? What exactly on the clockspring keeps the lights from turning on?
11-18-2016, 05:51 PM | #2 |
Drives: FR-S TRD RS1#1488
the way you worded your description sounds like you didn't put the clock spring back in. Just pointing it out...
The Following User Says Thank You to Crazypinoy9 For This Useful Post: | go_a_way1 (11-18-2016) |
11-18-2016, 06:26 PM | #3 |
Yeah I didn't put it back the short hub I used doesn't work with the clockspring in. I'm trying to figure out is there a way to turn the ABS and Traction Control lights off. Also what specifically about the clockspring makes sure those lights don't turn on.
11-18-2016, 07:04 PM | #4 |
Little Member
Drives: Bloo - The 13' BRZ
The traction control and abs like to know which way your steering wheel is pointed, so when you remove the clockspring they get really unhappy and wont work right. You need a hub that allows you to use the clockspring.
The Following 3 Users Say Thank You to yelsew For This Useful Post: |
11-18-2016, 07:39 PM | #5 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Nhaaa man these new computers can just guess
The Following User Says Thank You to go_a_way1 For This Useful Post: | yelsew (11-18-2016) |
11-18-2016, 08:02 PM | #6 |
Drives: 2016 Halo FRS
Yea no way to turn them off that I'm aware off. Need a hub that will keep it. Currently you have no abs or traction/stability control. Hopefully when you do re install it, if you do, you will not need to get it re calibrated. Tech stream needed to re calibrated it. The dealer will try to sell you a clock spring as well. Same thing happened to me except my lights came on after an alignment by a certain shop. Never went there again. Got it realigned at a much better shop, but it's still on..... need tech stream
11-18-2016, 11:58 PM | #7 |
hopefully it's as easy as replugging the clock spring back in, otherwise... rip wallet
02-03-2021, 12:24 AM | #8 | |
ABS and Traction Control clock spring
The Following User Says Thank You to omz For This Useful Post: | Thefalls (02-03-2021) |
Tags |
abs, clockspring, steering wheel, traction control |
Similar Threads | ||||
Charity parts bin - looking for connector : clock spring to horn / cruise control | philooo | Tracking / Autocross / HPDE / Drifting | 1 | 01-30-2016 05:57 PM |
traction control and abs lights coming on after 20mins? | UnLeasHer | AUSTRALIA | 28 | 02-23-2015 09:52 AM |
Random traction control and ABS lights? | Mr Kirmudget | Scion FR-S / Toyota 86 GT86 General Forum | 13 | 01-28-2015 11:36 AM |
CEL/Traction Control Lights | artizhay | Issues | Warranty | Recalls / TSB | 5 | 11-04-2012 10:33 PM |
