Old 02-14-2017, 11:51 AM   #1
VeganGirl
Drives: Scion FR-S 2013
What does a catch can do and is it nessesary for super charged cars?
Long story short my boyfriends car blew up with a kraftwerks running perfect for 2 years and one day just didn't turn on.
Now I want to do any preventative things to keep this from happening to me and my edelbrock kit.
Are catch cans good at preventing this? And what about an oil cooler? Any tips to prevent my engine from exploding would be nice,
Thanks
VeganGirl is offline   Reply With Quote
Old 02-14-2017, 12:29 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks
Catch can and oil cooler are supporting mods that help prolong engine life. Proper maintenance and a solid tune are also helpful. Not pushing the car when cold, checking your oil level periodically are also good practice items to help conserve the engine.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
MisterSheep (02-17-2017), tCsonfrs (02-14-2017), Teseo (02-14-2017)
Old 02-14-2017, 02:48 PM   #3
VeganGirl
Thank you!
I have the solid tune in check, and I check my oil every week
Also I don't push the car much , it's just my daily driver
Do you think oil cooler is nessesary in daily driven edelbrock car or not really? I have not and will not ever track my car(just not my thing). But I also live in Florida, so I know it can get hot here in the summers
Old 02-14-2017, 03:00 PM   #4
Sportsguy83
Drives: Limited BRZ
Thank you!
Honestly not absolutely needed. Synthetic oil will stay true to it's properties to 300+ degrees. It's in the track where you could end up sustaining 280+ degrees where it's a concern. For daily and not pushing much you shouldn't see anything over 250 and very little over 230.
Old 02-14-2017, 06:11 PM   #5
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
Still calling BS the KW kit blew up an engine. Sounds like someone doesn't know how to perform maintenance or troubleshoot a FI problem. No follow-up on recommended fixes suggested by forum members either or an exact cause/ symptoms of said "blown up" engine.
Anywho, catch can...supporting mod. Not necessary, but doesn't hurt to have one.
Helios is offline   Reply With Quote
Old 02-14-2017, 06:32 PM   #6
gramicci101
Off Topic
There's no particular mod or driving style specifying that now a catch can is necessary. Check your PCV valve and crankcase breather line. If there's oil, a catch can is beneficial. If there's no oil, it isn't. FI or not, track usage or not. Every car is different.
That said, Velox and Radium both make great products.
http://www.ft86speedfactory.com/velo...l#.WKOTLmK9KSM
http://counterspacegarage.com/radium...-frs-gt86.html
Old 02-14-2017, 10:36 PM   #7
VeganGirl
Why would we lie about the engine blowing up?
We took it to 2 shops and it is true the short block =done for and there was metal in the oil. That car was brand new with 30k miles. We 100% believe it was the super charger.
Car is currently being fixed and we are getting rid of that super charger and he's going to drive it stock from now on.
Old 02-14-2017, 10:37 PM   #8
VeganGirl
Thanks!
Old 02-14-2017, 10:41 PM   #9
Teseo
Drives: frs
Maybe was a spun bearing. Even on NA engine happen
Old 02-14-2017, 10:44 PM   #10
VeganGirl
Either way, we purchased a whole separate engine and it will be swapped in hopefully next week. Lost faith in that super charger. Hopefully edelbrock doesn't blow up my engine now too. I've been looking to just get rid of it and move to an RC350 now cause I'm nervous every time i drive it.
Old 02-14-2017, 11:04 PM   #11
Irace86
Drives: BRZ + Ducati M796
When I go FI I'll get a single catch can for the PCV. Seems like a dual setup is overkill. Most don't see much from the crank case. I don't think lacking a catch can would be a cause of acute engine failure. There would be symptoms before failure. Regardless it is a good idea to get one.
Irace86 is offline   Reply With Quote
The Following User Says Thank You to Irace86 For This Useful Post:
zeal86 (02-14-2017)
Old 02-15-2017, 04:10 AM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
Wish they did the RC in a V6 here..... it's no where near a good a chassis as the 86/BRZ though for fun.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-16-2017, 07:01 PM   #13
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
edelbrock should last you forever unless you went small pulley on stock internals. technically. with that said. how do you like it compared to stock?
also. rc350 is a nice car to sit in. can get u same major boiass too.
nos145 is offline   Reply With Quote
Old 02-16-2017, 07:53 PM   #14
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
How much power was he making on the Vortech? Its interesting you say there was metal in the oil which caused the engine to seize. Now i'm not a mechanic in any sense of the word but that doesnt sound like something that could be caused specifically by the supercharger. As someone said earlier it can happen on NA as well. Something like that sounds like there was already an internal issue with the engine which got exacerbated with the kit on it but wasnt caused by the kit.
Not trying to call you out or anything but i just went FI as well and anytime someone has an issue with their car i want to see exactly what caused it so i can look out for signs haha.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following User Says Thank You to Xxyion For This Useful Post:
Hoodpins are they nessesary?? go_a_way1 Cosmetic Modification (Interior/Exterior/Lighting) 19 11-25-2016 07:00 PM
Oil catch can for Normally Aspirated cars philooo Tracking / Autocross / HPDE / Drifting 5 09-03-2015 01:54 PM
Super/ Turbo charged system issues/ fixes Newguy Forced Induction 2 02-04-2014 01:42 PM
313HP per liter, super charged and turbo charged (C-X75) rice_classic Other Vehicles & General Automotive Discussions 13 07-02-2013 11:55 PM
Spring rates for Super charged FRS jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-21-2013 09:32 PM
