Old 04-01-2017, 10:35 PM   #1
Kristian
Cusco Carbon Fiber Steering Wheel Install
Hopefully, this is helpful to others. I shared this on my blog too - http://apexrally.blogspot.com/2017/0...ing-wheel.html . Cheers.
Installing an aftermarket OEM style wheel on the FR-S / BRZ is not as difficult as you might think. The process took me about an hour.
This video below shows the overall process. Below I'll share some things about my experience also.
[ame="https://www.youtube.com/watch?v=V7nxaFG4vxI"]https://www.youtube.com/watch?v=V7nxaFG4vxI[/ame]
Tools needed:
socket wrench
10mm socket
short socket extension
17mm socket
phillips screwdriver
flat head screwdriver
shop light (helpful but not required)
Photos from the process in the video. Be sure to disconnect the battery before you start!! Be safe too. After you're done watch out for warning lights, etc... This post is for educational use only. I assume no liability for your actions.
Notes from my install:
1) OEM steering wheel with my electric tape at the top
2) Taking the airbag out is easy just be careful with the wires. Need to have battery disconnected (use the 10mm socket). Use phillips head screwdriver on three holes by the wheel to release it. One wire should come out fairly easily. The other too just need to be released using a flat head screwdriver.
They seem to have mechanics in mind because it's quite easy to release the airbag section.
3) Now that it's out it's just a matter of using the 17mm socket on an extension to loosen the nut, pull on the wheel to break it loose, and then remove the nut.
All of the Cusco instructions were in Japanese so the video above was a great help!
4) Getting the components from the stock wheel onto the aftermarket wheel takes a little patience but it's worth it. Use the phillips here again.
5) After the components are on you can carefully thread the wires through the wheel, place it on, and snug the nut down with the 17 mm socket.
The finished product looks great. Although, I plan to have carbon fiber for the lower trim soon too.
Kristian is offline   Reply With Quote
The Following User Says Thank You to Kristian For This Useful Post:
sato (04-01-2017)
Old 04-02-2017, 03:13 AM   #2
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Nicely done video
Scrappydoo is offline   Reply With Quote
carbon fiber, cusco, jdm, steering wheel, wheel
Cusco style D shape Steering Wheel w/ Carbon Fiber top grip pansontw Interior Parts (Incl. Lighting) 293 09-25-2019 11:11 PM
DCTMS OEM Carbon Fiber Steering Wheel Review zkahle Cosmetic Modification (Interior/Exterior/Lighting) 2 08-20-2015 06:53 PM
DCT Motorsports Carbon Fiber Steering Wheel $650 Shipped kanundrum Interior Parts (Incl. Lighting) 3 06-10-2015 07:59 PM
FS|SoCal: Revier Carbon Fiber Steering Wheel $600 zAnSh1n Interior Parts (Incl. Lighting) 2 03-16-2015 05:09 AM
