DIY (Do-It-Yourself) Guides For all DIYs. |
04-15-2017, 04:02 AM | #1 |
Guest
Posts: n/a
DIY - Right Hand Drive (RHD) Clutch Spring Removal / MTEC Install
Hi All
Figured I'd put together a DIY guide for all those out there that own RHD 86/BRZ who want to remove/replace their clutch springs. Whats needed
Plan of attack As this is RHD, it is close to impossible to remove the clutch spring with the pedal in place. This doesn't meant that it cant be done, but be prepared for hours of pain if you are prepared to go that route. The following method is much simpler and allows you to work on the whole assembly on a bench. LHD owners in the states and other countries have a much easier time as the clutch pedal works on a cam system which provides plenty of working space in the footwell. Step 1: Inside the footwell Start by removing the following. 1. Undo both sensor plugs as shown in the following diagram. The plugs are a bit tight from factory and don't seem obvious at first on how they should be undone, don't rush and examine it carefully. You will see the prongs to press in to release them. 2. Undo the 12mm bolt that supports the clutch pedal, if you are lying on your back this is facing directly upwards. 3. Remove the retaining clip from the clutch master cylinder push rod (use needle nose pliers to gently pull it). Once out, look to the other side of the pedal and pry out of the center pin using a flat head screwdriver. Step 2: Inside the engine bay 1. Remove both the 12mm bolts which secure the Master cylinder and clutch pedal assembly. Becareful not to drop these nuts into the engine bay, otherwise you will have a fun time digging for them or removing the undertrays. Line the 12mm socket with some tape so that the nut stays captive once removed. Step 3: On the workbench. 1. With the pedal removed, it should look something like this. You can place the entire assembly on a workbench and enjoy the next few steps knowing that you wont be fighting to contort yourself into the footwell. 2. Remove the stock clutch spring by first removing the c-clips on both ends of the spring holder. Then proceed to push out the retaining pins, You should be then able to remove the entire spring assembly as shown below. Note you may need to play with the clutch pedal position to push the retaining pins out. 3. Once disassembled, it should look like the below. From here you can simply either re-install the pedal for a true clutch spring delete OR replace it with a MTEC spring. Step 4: Re-assembly 1. Reassembly is basically the reverse of the above. When re-installing, make sure the push rod is lined up with the pedal. If it is off to either side or seated incorrectly you will not be able to re-install the retaining clips. Re-installation Checklist.
Conclusion I hope this guide helps those out there who own RHD cars and have not attempted this yet. Although there appear to be quite a few steps involved, in reality this process is rather quick. I completed the install in about 1.5hours at a leisurely pace whilst documenting it all. My Thoughts Having seen hundreds of first hand reviews and opinions from LHD owners who removed the spring, I put this off for quite a while due to the difficulty of reaching the spring. It is a very worthwhile modification, The stock clutch feel is one of the most annoying traits of an otherwise fantastic car. I would highly recommend either replacing the spring with MTEC's version or removing it completely.
I chose the MTEC replacement as I personally prefer to keep as much of the factory engineering in place, but the decision is really up to each individual! I also will starting posting more content on my blog if anyone is interested. http://lawdiy.blogspot.com.au/ |
04-15-2017, 01:27 PM | #2 |
chicken tonight
Wow, much needed and superb DIY as first post. Thank you, Law.
04-15-2017, 04:05 PM | #3 |
Drives: 2017 86 GTS
I wish you posted this last week when I was adjusting the pick-up height. Bookmarked for when my MTEC spring arrives.
04-15-2017, 05:44 PM | #4 |
Guest
Posts: n/a
The Following User Says Thank You to For This Useful Post: | Ultramaroon (04-15-2017) |
04-15-2017, 05:44 PM | #5 |
Guest
Posts: n/a
05-26-2017, 09:37 AM | #6 |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
Thanks @Law for the DIY and write up - looked at doing this before but remembered how I cut my hand on the stupid metal cage when I was adjusting the pedal height and went NUPE!
But thanks to the DIY, I did this today in about an hour. The hardest parts were: • Figuring out how to undo the two plugs (pinch hard to disengage) • The push rod clevis pin had a plastic one way toggle on the end that had to be pinched in order for the pin to be pulled out - i just pulled really hard and then pushed them back into shape • Re-assembling was a pain, the order i did it was securing the clutch pedal with the 12mm bolt and then lining up the push rod clevis with the clutch pedal so i can push the pin through. From then it was just a matter lining everything up and then tightening. I also reinstalled the spring holder since it seem to make the whole assembly more stable. Overall impression was fantastic - I can only describe it as being stiffer and more 'bouncy'. I don't think I can feel the friction point any better but there's much less stuttering or hesitating when i shift now. |
07-07-2017, 09:45 PM | #7 |
Drives: 2017 86 GTS
Installed the MTEC spring last weekend. This DIY was excellent. As Enouf said, re-installation can be a pain if you're doing this alone. His point of re-securing the clutch pedal first is the way to go, otherwise it just gets pushed back though the firewall when trying to slide the clutch master cyl assy over the studs. With two people the whole job could be done in 30 mins. Can't say that the engagement point has any more feel to me but the pedal does feel firmer but not heavy and I guess more premium. |
07-07-2017, 10:53 PM | #8 | ||
Guest
Posts: n/a
Agree, that although the feel doesn't increase much. The extra pedal weight does help quite a bit in modulating the clutch now. Thanks for the comments, hopefully it will help others who attempt this. |
02-23-2018, 11:56 PM | #9 |
Drives: 2013 Toyota 86
Thanks for the write up, just finished this. Took me just over an hour. Enouf's comments were really helpful as well. Particularly the order of assembling.
I just did the full spring delete. I concur with others, slightly heavier, not much more feel but definitely better. Thanks! Think I might do the slave cylinder change next Last edited by Harey; 02-24-2018 at 01:40 AM. |
12-29-2019, 06:52 PM | #10 |
Drives: MY14 86 GTS Manual Velocity Orange
video on how to install the clutch spring on RHD vehicles: [ame]https://www.youtube.com/watch?v=6DKBRYQdBpY[/ame]
The Following User Says Thank You to sneaky_pete For This Useful Post: | 86zn6 (07-25-2020) |
07-25-2020, 11:52 PM | #11 |
Drives: White GTS then Black GTS
Would this result in premature TOB?
Tags |
clutch, mtec, removal, rhd, spring |
Similar Threads | ||||
MTEC clutch spring review | kbye | Engine, Exhaust, Transmission | 23 | 04-26-2023 05:48 AM |
FS: MTEC clutch spring | nunonuna | Transmission and Driveline | 2 | 07-13-2016 12:34 PM |
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 03:42 AM |
MTEC shifter spring install issue | jamesm | Engine, Exhaust, Transmission | 36 | 12-06-2015 09:36 AM |
Clutch spring removal | Sandy | AUSTRALIA | 4 | 07-22-2015 10:14 PM |
