CANADA Canada
Old 04-16-2017, 02:03 PM   #1
v1beeee
Drives: 14 FRS Whiteout
Alignment settings/Alignment Shop
I have a set of Whiteline Camber bolts I'm looking to put in and have aligned.
My question is what kind of alignment settings would you all suggest? The car is completely stock suspension wise. I'm also looking to get a recommendation on a good alignment shop around the Mississauga area.
v1beeee is offline   Reply With Quote
Old 04-16-2017, 05:18 PM   #2
Cole
Not a troll
Cole's Avatar
What are you doing with the car?
Get as much front camber as you can, match the rears to that or go .5* less in the back than the front. 0 toe all around, maybe a little bit of toe in on the rear. As far as shops in Mississauga, no clue.
The Following User Says Thank You to Cole For This Useful Post:
v1beeee (04-17-2017)
Old 04-16-2017, 07:02 PM   #3
AREN
AREN's Avatar
Drives: Beige Corolla
Not in Mississauga, but for alignments I go to Altech in Etobicoke. Also, try NV Auto in Hamilton.
AREN is offline   Reply With Quote
The Following 2 Users Say Thank You to AREN For This Useful Post:
dattran86 (04-17-2017), v1beeee (04-17-2017)
Old 04-17-2017, 10:20 AM   #4
wparsons
wparsons's Avatar
Since you only have camber bolts for the front, you'll be stuck with whatever the rear naturally has.
Get as much camber up front as you can, 0 front toe and 1/16" total rear toe in.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 04-17-2017, 10:26 AM   #5
dattran86
Driver
Drives: 2013 Whiteout FRS
+1 for Altech.
align the car exactly as I requested.
They even call me to the back to show me alignment spec on screen.
Will probably go back again soon. Also NV Does good work too, you cant go wrong with both.
dattran86 is offline   Reply With Quote
The Following User Says Thank You to dattran86 For This Useful Post:
Old 04-17-2017, 02:07 PM   #6
tinma
Drives: '13 BRZ
I just got my alignment today. Here are my specs. Any good?
Front: left
Camber 1.63
Caster: 5.86
Toe: 0.01
Right
1.50
6.21
0.00
Rear: left
Camber: -2.25
Toe: 0.07
Right:
-1.88
0.08
Let me know what you think. Not sure about any of this stuff.
tinma is offline   Reply With Quote
Old 04-17-2017, 02:16 PM   #7
Marat
Drives: '15 Ultramarine FR-S
Front: left
Camber 1.63
Caster: 5.86
Toe: 0.01
Right
1.50
6.21
0.00
Rear: left
Camber: -2.25
Toe: 0.07
Right:
-1.88
0.08
ideally you want the camber to be the same on each end of the car. Your rear camber is 0.37 degrees off left to right. I'm not sure what the acceptable range is but I would try to get it as close as possible. Maybe consider getting adjustable rear control arms to correct camber.
Marat is offline   Reply With Quote
The Following User Says Thank You to Marat For This Useful Post:
tinma (04-17-2017)
Old 04-17-2017, 03:35 PM   #8
tinma
Drives: '13 BRZ
Hmm this makes me feel like this place did a crap job on my alignment.... thanks
The Following User Says Thank You to tinma For This Useful Post:
D_Thissen (04-21-2017)
Old 04-17-2017, 03:36 PM   #9
Cole
Not a troll
Cole's Avatar
Well, stock has no adjustment, so the guys doing the alignment are stuck doing the best they can with what they have available to them.
wparsons (04-17-2017)
Old 04-17-2017, 03:50 PM   #10
tinma
Drives: '13 BRZ
What I mean is they didn't try and make both fronts same or rears same. I have white line camber bolts up front.
Old 04-17-2017, 04:38 PM   #11
wparsons
wparsons's Avatar
What did you ask them to do, and where did you go?
They can only adjust rear toe unless you buy something to allow camber adjustment.
flickr
Old 04-17-2017, 04:41 PM   #12
strat61caster
strat61caster's Avatar
That's good enough for DD and casual fun, I wouldn't go back unless you're going to change parts (rear LCA's), you won't be able to tell the difference between before and after at this point.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
tinma (04-18-2017), wparsons (04-18-2017)
Old 04-17-2017, 05:06 PM   #13
v1beeee
Thanks for the advice boys!
Hopefully I'll get the car dialed in next weekend
Old 04-20-2017, 11:26 AM   #14
tinma
Drives: '13 BRZ
After doing more reading...(which i really should have done prior to my alignment and not just relied on the shop for the best outcome) should my front camber not be in the negatives?
here is a great link for help for anyone that needs it
http://www.ft86club.com/forums/showthread.php?t=25001
alignment shop ? FR-Sky Northern California 17 04-08-2016 11:33 PM
Recommended Alignment Settings? BFIFE22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-27-2015 05:57 PM
Alignment settings for Auto club speedway ddeflyer Tracking / Autocross / HPDE / Drifting 12 07-08-2015 09:10 PM
Recommended Toe Alignment Settings brillo Tracking / Autocross / HPDE / Drifting 18 02-05-2014 12:36 PM
RCE yellow springs. Expected alignment settings after install. diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-24-2013 03:48 PM
