Tracking / Autocross / HPDE / Drifting What these cars were built for! |
04-27-2017, 11:27 AM | #1 |
Do I need to have my track tires balanced?
I just bought a set of NT01's and I'm also new to the circuit trackworld. So do I need to have track only tires balanced?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
04-27-2017, 11:29 AM | #2 |
Drives: 2013 Scion FRS
Absolutely. Usually who ever installs your tires on the rims, will balance them for you.
Sent from my SM-N915T using Tapatalk
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
The Following User Says Thank You to FRSToyota86 For This Useful Post: | stevesnj (04-27-2017) |
04-27-2017, 11:30 AM | #3 |
Thanks, what about bead sealer? I am using the OEM wheels.
04-27-2017, 11:45 AM | #4 |
I've never even heard of that. You've got decent tires going on stout wheels, you should be fine as long as the shop does a decent job, they should be able to just treat them like normal tires.
The Following User Says Thank You to strat61caster For This Useful Post: | stevesnj (04-27-2017) |
04-27-2017, 11:53 AM | #5 |
It's mostly used on tubeless tires and in the 4x4 rock crawling world i'm in. Prevents bead separation due to extreme use.
04-27-2017, 12:10 PM | #6 |
Drives: 2013 satin white brz limited
If you end up in a situation where you are able to separate a tire from the bead you likely have bigger issues. IE you left the track at a high rate of speed.
04-27-2017, 12:13 PM | #7 |
I don't balance my tires for autox and haven't when I've been to the track in the past.
Couple sessions and your balance will be off on the tire anyways. Unless you like extra weight on the wheel and want to spend more money balancing the tires I don't see the point |
04-27-2017, 12:13 PM | #8 |
Haha, definitely not a plan to do so.
04-27-2017, 12:14 PM | #9 | |
04-27-2017, 12:16 PM | #10 | |
Track tires, like the ones you're getting will wear unevenly. Unless you believe that a stock tire off of the balancer is going to maintain that SAME balance throughout the life of the tire, then go ahead and keep on assuming that. |
The Following User Says Thank You to M0nk3y For This Useful Post: | stevesnj (04-27-2017) |
04-27-2017, 12:17 PM | #11 | |
04-27-2017, 12:18 PM | #12 |
04-27-2017, 12:20 PM | #13 |
Troll? He thanked you for your input. He simply asked the question to see if it was a thing based off previous experiences he has had. Did I miss something here?
The Following User Says Thank You to jasonojordan For This Useful Post: | stevesnj (04-27-2017) |
04-27-2017, 12:20 PM | #14 |
You took that totally the wrong way. I posted the thread because I wanted opinion through data and experience. Maybe it will help someone out too. Jeeze
Similar Threads | ||||
Are my wheels improperly balanced? | lupindub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 04-11-2016 02:54 PM |
Engine swap that will improve the car in a balanced way? | DVNARC | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 09-04-2015 01:01 AM |
Brand New FRS/BRZ Tires and Rims (mounted, balanced) | Hamza7 | Canada Classifieds | 1 | 05-16-2015 01:12 PM |
perfect balanced wheels | BRZtoni | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 05-06-2014 11:27 AM |
Got Corner Balanced and Aligned | track_warrior | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 08-10-2012 12:35 PM |
