Old 05-25-2017, 09:37 AM   #1
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
LED Hyper Flash Solution
So I bought myself a 4x 7440 LED's for my Front and Rear turn signals. They were supposedly Canbus friendly, but when I installed them I found anything but Canbus friendly LED's and was met with a Hyper Flash.
This the first time I have seen this on my car and is naturally due to the low voltage draw from the LED's, so I looked around to find a solution and supposedly one is to install load resistors, which for $10 is an ok solution but they generate a lot of heat and wasted heat at that. Heat, as most people know is wasted energy from electricity that is stored and dissipated.
[ame="https://www.youtube.com/watch?v=I6SAhMHbrEA"]Load Resistor Temperature Comparison - YouTube[/ame]
This video clearly shows how much heat these cheap resistors produce and I don't want to start clamping cables into my lights especially when it might snap the cable in two or the resistor may go and I'd have to fix the old joint and re-install.
This video shows a perfect solution:
[ame="https://www.youtube.com/watch?v=AAEz3YC8SCA&t=3s"]FR-S / BRZ Fix Turn LED Hyperblink with Flasher - YouTube[/ame]
This is what I recently bought off eBay because the numbers match and it's listed as working a Toyota 86. A Relay is what I think is the best way to go as there are no clamping or cutting wires or having to install a resistor in an area that won't burn plastic due to high temperatures.
http://www.ebay.com.au/itm/160866967...%3AMEBIDX%3AIT
So when I get this I will plug it in and show you what the best way to do it is.............
FRS2017 is offline   Reply With Quote
Old 06-07-2017, 03:45 AM   #2
FRS2017
Enthusiast 86
FRS2017's Avatar
Works
Old 06-07-2017, 03:52 AM   #3
Boomerang
86
Boomerang's Avatar
I bought a LED relay and it works fine with my LED's
you can also take off the mounting bracket from the old flasher and mount to the new one so you can reinstall it in the same place, and remove the old flasher
Old 06-07-2017, 04:22 AM   #4
FRS2017
Enthusiast 86
FRS2017's Avatar
It was too much of a fiddle for me in such a small place, I just left it there in case I have to go back to old setup.....but overall much better and safer than the resistor solution.
Old 06-07-2017, 11:00 AM   #5
ottoyu34
ottoyu34's Avatar
Drives: Mazda3
Having to just swap to the relay for LEDs, is one of the best thing on this car.
ottoyu34 is offline   Reply With Quote
Old 06-07-2017, 01:28 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
if you get aftermarket tail light like TOMS, this kind of relay comes with it
Hyper Flash Relay ThornhillSubaruOwner Cosmetic Modification (Interior/Exterior/Lighting) 2 02-19-2017 10:07 PM
Spyder Tail lights with Hyper Flash Relay ? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 8 12-24-2015 02:37 AM
Hyper silver or hyper black on raven frs? KingGT86 Scion FR-S / Toyota 86 GT86 General Forum 8 05-13-2015 04:06 PM
Hyper Silver, Hyper Black, and SBC. Are they the same? Tainen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-19-2014 11:50 PM
