Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
05-29-2017, 03:48 PM | #1 |
Drives: 2014 White BRZ
Joying Head Unit - Which model
Which model head unit should I order. There is a few different ones listed under Subaru but a few seem to be the same.
Their website is a little confusing. Will I need a separate wiring harness as well or does it come with the Subaru adapter. I looks like it comes with something just not sure if it what I need. |
05-29-2017, 03:49 PM | #2 |
05-29-2017, 04:15 PM | #3 |
Drives: 2013 BRZ Limited / 2015 Q50S
IIRC you'll want the Toyota harness they have...and some sort of dash kit as all of their universal units are smaller than OEM .
They only make one that's 200x100mm...for some reason it's not listed on the Canadian site. Amazon Canada shows it though: https://www.amazon.ca/JOYING-Android...=joying+toyota *Note that for whatever reason that model is 800x480 resolution. |
The Following User Says Thank You to BRZyJ For This Useful Post: | randomthoughts (05-29-2017) |
05-29-2017, 04:35 PM | #4 |
Drives: 2012 GT86 EU-spec
The one above is plug and play, the Toyota specific ones come with the right harness, BUT they come with a low resolution screen 800x480. The universal ones have a higher resolution screen 1240*600 or so, but they are not Toyota double din size. They require a dash kit / bezel / fascia and the right adapter cable.
05-29-2017, 04:56 PM | #5 | |
Similar Threads | ||||
Joying Android 4.4.4 Kitkat Toyota Head Unit | Griffon | Electronics | Audio | NAV | Infotainment | 542 | 09-12-2017 10:49 PM |
Adapters for Joying Head Units | Survivalism | Electronics | Audio | NAV | Infotainment | 6 | 05-14-2017 07:13 PM |
OEM Head Unit | bfrank1972 | Audio/Visual, Electronics, Infotainment, NAV | 2 | 02-07-2017 10:03 AM |
Joying head unit with 2014 a frs | ImDatSlaya | Electronics | Audio | NAV | Infotainment | 0 | 01-28-2017 05:32 PM |
Joying Android Head Unit in 2016 FRS? | michaelchatten | Electronics | Audio | NAV | Infotainment | 0 | 10-30-2016 02:03 PM |
