Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-03-2017, 04:15 PM | #1 |
Drives: 2013 Scion FRS A/T
Failing Sway Bar Bushing?
The left side looks fine but the right looks as if its leaking? The cars alignment has been acting up for a while now and with a quick inspection I'm wondering if this could be the cause. The left side looks fine but the right looks as if its leaking? Thanks - sorry if this has been posted about before.
06-03-2017, 06:26 PM | #2 |
LMGTFY
Drives: 13 FRS, 91 Miata
I could be wrong, but I've never seen a bushing that had fluid in it.
Always just a solid piece of rubber/ect. Could just be grease that got stuff on it. It doesn't look ripped or falling apart. |
The Following User Says Thank You to x808drifter For This Useful Post: | strat61caster (06-04-2017) |
06-03-2017, 07:03 PM | #3 |
Drives: 2013 BRZ Sport-tech WRB
06-03-2017, 09:35 PM | #4 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
Reverse down a slope (like a driveway into the street) and turn your wheel to full lock in both directions (do it twice) if you hear or feel a "pop" then your bushings are (for sure) going bad. They could still be bad without this occurring though. However no: they cannot 'leak' as they are not hollow in any way. What you're seeing is the bushing grease that is applied to the bar/bushing before install (for noise, vibration, and harshness reasons, as well as to give the bar a small amount of play). Some of the grease may have been pushed out by pressure overtime.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
The Following User Says Thank You to Keenercarguy For This Useful Post: | PikachuBRZ (10-18-2022) |
06-03-2017, 11:10 PM | #5 |
chicken tonight
Those bushings are greased a little when assembled. The right side is super close to the overpipe and gets hot enough to melt the grease. It looks like a leak but meh.
I'm watching mine to see if it hardens prematurely. Can't imagine all that heat cycling is good for it but mine is still plenty supple
06-04-2017, 01:06 AM | #6 |
Thanks for all the replies everyone - seems like its nothing to worry much about.
06-04-2017, 01:27 AM | #7 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
Could the heat from the overpipe have something to do with this? Perhaps poly bushings would solve the issue.
06-04-2017, 10:54 AM | #8 |
Roll bars don't influence alignment. Bushings are installed with silicone based grease to prevent squeaks. All looks normal.
The Following User Says Thank You to Gforce For This Useful Post: | maslin (07-26-2019) |
06-06-2017, 04:46 AM | #9 |
Drives: frs
exactly the same
mine looks exactly the same - attribute it to the overpipe heat
09-16-2017, 02:11 PM | #10 | |
Drives: Whiteout FR-S
My car actually does exactly what you say, and I have tried tightening everything and nothing work. Everyone said my bushing looks good and normal |
09-17-2017, 06:07 PM | #11 |
Mountain Runner
Multiple people said mine looked fine, then a Porsche GT3 Cup suspension tech took one look at it and told me to new bushings. I just got the smallest diameter Perrin adjustable and I've been good for 50,000+ miles since (all my piping is ceramic coated so to be fair: my bushings no longer get as hot as average too)... if it bothers you that's not a bad price to pay, you then also end up with a better swaybar whether you fully fix the problem or not. Win win
07-26-2019, 10:23 AM | #12 | |
Drives: 14 BRZ SWP
Thanks for posting this. I had some very minor (but annoying) noise when reversing out of parking spots, especially if there was some incline. The bushings looked mostly fine. Only a small gap where the bushing is slotted. Picture of worn bushing 75K miles I replaced the bushings and while it's still early the noise/clunk seems to have gone away. Also, for anyone trying to diagnose the same issue, I had noise when pulling away from a stop. Lastly, the sway bar did not have any up and down play, but I was able to move it horizontally, which the new bushings don't allow. This would have been a very tricky diagnosis without the above info, thanks. Edit: Actually it turned out to be the front strut mounts. Found some info on a TSB about it here. Last edited by AT-JeffT; 11-09-2019 at 09:57 AM. |
The Following 3 Users Say Thank You to AT-JeffT For This Useful Post: |
07-26-2019, 10:26 AM | #13 |
Anti stance.
Lots of bushings have fluid in them. Not saying these do, but lots do.
07-26-2019, 03:24 PM | #14 |
The OEM sway bar bushings are self lubricating and will ooze like that when exposed to heat from the over pipe.
Similar Threads | ||||
Do I have bad coil packs or a failing DI pump? | xkalelx | Forced Induction | 16 | 03-15-2016 01:56 PM |
SOLD Cusco Sway Bars Front & Rear 20mm 16mm Bushing Swaybar Swaybars | hirollaz | Brakes, Suspension, Chassis | 6 | 06-01-2015 06:30 PM |
Whiteline Front and Rear Sway Bar + Bushing Kit $550 | MicheleAbbate | Brakes, Suspension, Chassis | 1 | 01-28-2015 11:23 AM |
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
3M tape failing on front lip after time? | 1Cor10:23 | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 11-19-2013 01:51 AM |
