Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-17-2017, 12:04 PM | #1 |
Drives: 2017 Toyota 86
Will TRD springs RUB on my "17" 86
Hello I have a 2017 toyota 86 and bought trd springs. I asked my friend who has a 2014 scion frs that if he knew anybody. He asked around and people said don't do it because it will 'rub' im guess that means against the tire. He was saying just do coilover but I already bought these springs and want to use them since I had trd springs on my 2014 scion tc. If I do go ahead with installing the trd springs will I need to change the struts and coilovers to? I would think not since im not slamming. Would changing the tire size have to be done as well. I would hope not. Thanks for the feedback,
06-17-2017, 12:12 PM | #2 |
Thupercharged
Do you have stock wheels/tires
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
06-17-2017, 12:16 PM | #3 |
TRD springs are designed to work with stock wheels, tires and struts.I have them on my '16 with no issues and they aren't low enough to rub.From what it looks like no significant changes to the suspension setup geometry from 2013-2017 and I believe the part number is the same for TRD spring from 2013-2017. Check with the dealer to confirm.
2017 Part number . http://www.trdusa.com/parts-detail.h...ring%20Springs 2016 Part Number http://www.trdusa.com/parts-results....ring%20Springs
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
06-17-2017, 12:22 PM | #4 |
Technically speaking the springs and struts are the coilovers. As said the TRD springs are designed for the stock set up but hey will still work with many other wheel and tire sizes. If what you are running for wheel size now are not causing issues then there is no reason why the TRD springs are likely to cause any. All will be fine.
The Following User Says Thank You to Tcoat For This Useful Post: | Gunman (12-07-2017) |
06-17-2017, 01:18 PM | #5 |
Drives: 2017 86 Coupe
I have a 2017 86 as well. I have the stock wheels with the TRD springs with no problems. The only drawback is, you will need to take some steep driveways at an angle so you don't scrape the bottom of the front end.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter |
06-17-2017, 01:25 PM | #6 |
Yep. And too fast over railway tracks will make you familiar with the bump stops in a real hurry.
The Following User Says Thank You to Tcoat For This Useful Post: | stevesnj (06-18-2017) |
06-17-2017, 01:44 PM | #7 |
Drives: 2013 Scion FRS
I have TRD springs on my '13, no problems. It's impossible to rub, the bump stop things prevent the springs from compressing enough. I live in SoFlo and our roads are very similar to any northern state that gets snowed and salted. Our tax money goes to more important things, like painting buildings.
Sent from my HTC6535LVW using Tapatalk |
The Following User Says Thank You to MurderousPandas For This Useful Post: | Vic4uf (06-18-2017) |
06-17-2017, 01:46 PM | #8 |
Yes it is stock everything right now.
06-17-2017, 01:56 PM | #9 |
Thanks for the info really do appreciate it!
The Following User Says Thank You to xxdaooxx For This Useful Post: | stevesnj (06-18-2017) |
06-17-2017, 01:58 PM | #10 |
Drives: 2013 FR-S Series 10
How much stiffer than stock are these springs? Because even mild ones like eibach pro kit will kill stock struts..
06-17-2017, 02:44 PM | #11 |
Off Topic
You're confusing drop with spring rate. Aftermarket springs kill OEM struts because they lower too far and the strut has no travel left, so it bottoms out. But even then it depends on usage. I've been on RCE yellows and OEM struts for 50K miles with no issues. Others have needed new struts within 5K. People have run Eibach sportlines or RS-R superdowns for years with no problems.
06-17-2017, 05:42 PM | #12 |
Derp
I have a '13 with TRD springs, no rub. If that helps
06-17-2017, 06:30 PM | #13 |
Drives: 2015 FR-S
I got the TRD springs because my dealer said it's a Toyota part and was covered by the warranty so if anything goes wrong with the struts later, it's on them.
The Following User Says Thank You to Impureclient For This Useful Post: | stevesnj (06-18-2017) |
06-17-2017, 06:36 PM | #14 | |
Tags |
86 model, brz, frs, toyota, trd |
Similar Threads | ||||
Hypercoil 6" Springs, 2.5" ID, 400# - Brand New | M0nk3y | Brakes, Suspension, Chassis | 6 | 07-05-2017 03:33 PM |
FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports | NvSnickers | Wheels and Tires | 2 | 04-04-2017 10:30 PM |
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Eibach Lowering Springs (1" or 1.4") w/ Free Shipping and a 10% Rebate | PhastekSport | Brakes, Suspension, Chassis | 4 | 12-09-2012 09:28 PM |
