Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
View Poll Results: Do you still hear Cricket/Chirp AFTER getting the October 2016 TSB Service? | |||
The Crickets have NOT returned | 19 | 42.22% | |
The Crickets HAVE returned | 26 | 57.78% | |
Voters: 45. You may not vote on this poll |
06-22-2017, 08:19 AM | #1 |
Cricket Sound Poll AFTER October 2016 TSB completed
So some confusion still exists that this TSB helps and some said they still get crickets after the October 2016 TSB. Hopefully this poll will help those decide wether it's worth their wile to get this done or just leave as is. I figure after a year we should have a good idea of the effectiveness of this "Redesigned" Pump.
Simple question; Do you still hear crickets AFTER getting the latest pump as listed in the October 2016 TSB? FOR 2013- (early) 2016 CARS ONLY
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
The Following User Says Thank You to stevesnj For This Useful Post: | Tcoat (06-23-2017) |
06-22-2017, 11:46 PM | #2 |
Has member
Drives: 21 JLU Rub, 20 BRZ, 18 M3, 11 M3
Yes. I got them to go away with three ounzes per fill up of Idemitsu Premix for Mazda rotarys I had sitting around from my 7 and 8.
06-23-2017, 10:51 AM | #3 |
Drives: 2015 Scion FRS
Been 6 months now on the redesigned fuel pump and no crickets. When the dealership is going to work on your car, you have to either print the TSB for them or let them know there is a recently revised one. If you don't, they may refer to the older TSB with the older style pump. It almost happened to me. I personally had to talk to the lead tech and let him know what's going on. Toyota rarely works on these cars and hardly check up on new TSBs for Scion.
06-23-2017, 11:04 AM | #4 |
MY14 owner. Had crickets since new. Got the fuel pump replaced in 03/17. No crickets yet.
The Following User Says Thank You to funwheeldrive For This Useful Post: | stevesnj (06-25-2017) |
06-23-2017, 01:27 PM | #5 | ||
Drives: 2015 FR-S
In fact if I believe with a poll like this and we ask "what color is your car" we may end up with people answering that they like green shirts or brown dogs. For the record I had the pump changed out I believe around December and afterwards no crickets have returned. |
The Following 3 Users Say Thank You to Impureclient For This Useful Post: |
06-23-2017, 01:29 PM | #6 |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Mine is starting to sound like a mild case of crickets, definitely not as bad as before.
About 9k on the new HPFP. |
The Following 5 Users Say Thank You to dhuang For This Useful Post: | DaBoBo21 (06-23-2017), funwheeldrive (06-23-2017), ScoobsMcGee (06-23-2017), stevesnj (06-25-2017), Tcoat (06-23-2017) |
06-23-2017, 03:01 PM | #7 |
in the recliner of rage
Drives: Asphalt FR-S
My '16 had terrible crickets about 300 miles after driving it off the dealer lot. Even through the winter. The redesigned fuel pump was installed about 4 months ago and the crickets have not returned, but the pump does get louder when it kicks on at idle. It's just a much louder ticking sound, though, instead of the cricket chirp.
06-23-2017, 03:05 PM | #8 |
Junior Senior with Cheese
Drives: 15 BRZ
The Following User Says Thank You to ScoobsMcGee For This Useful Post: | funwheeldrive (06-23-2017) |
06-23-2017, 03:17 PM | #9 | |
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | stevesnj (06-25-2017), strat61caster (06-23-2017) |
06-23-2017, 06:36 PM | #10 |
Yeah, the DI injectors are noisy for sure, but always have been. This new noise is the pump. You're right, it isn't because the pump is 'kicking on', but just like when the crickets would only come on at idle when the direct injectors started firing, the new pump makes a loud mechanical noise instead. My point is, for those pondering the new pump TSB, the pump is still noisy (as most, if not all, HPFPs are), but it isn't crickets.
The Following User Says Thank You to Resolute For This Useful Post: | Tcoat (06-23-2017) |
06-24-2017, 01:01 AM | #11 | |
Has member
The Following 2 Users Say Thank You to DrinkenBeeRZ For This Useful Post: | Impureclient (06-24-2017), stevesnj (06-25-2017) |
07-03-2017, 10:17 AM | #12 |
Drives: 2014 Scion FR-S
It's been about 6 months since my last fuel pump replacement in Jan. No crickets since. I've also only used Shell 91oct...except for several occasions I had to use some other generic gas but no issues at all!
The Following User Says Thank You to chazmuska For This Useful Post: | stevesnj (07-16-2017) |
07-12-2017, 09:43 PM | #13 |
Drives: 2016 Scion FRS Asphalt
they returned worse than they were within 900 miles. sitting at a light is embarrassing. The fact that the chiing is worse (using Shell 91 octane) makes me want to blow the damn car up. A new car (~12500 miles) should not be making these sounds. especially since it's been going on from 2013.
07-16-2017, 07:47 PM | #14 | |
Similar Threads | ||||
Engine idle chirping (cricket) noise poll. | Hanzo | Issues | Warranty | Recalls / TSB | 5031 | 05-18-2017 09:41 AM |
Sykart Meet October 6th, 2016 | TheDrkNite | Northwest | 37 | 10-07-2016 02:42 AM |
Engine idle chirping (cricket) noise poll. | Hanzo | BRZ First-Gen (2012+) -- General Topics | 229 | 02-16-2016 01:21 PM |
Engine cricket sound? | 86ish | Issues | Warranty | Recalls / TSB | 19 | 10-11-2015 04:07 AM |
Cricket sound while running, normal? | Zzzquil | Issues | Warranty | Recalls / TSB | 13 | 02-13-2014 11:59 AM |
