Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-11-2017, 01:27 PM | #1 |
Drives: GT86 Nur spec
Intake manifold leak
Hello there,
My Brz is FI on fbm stage 1 turbo kit and today after just 3 minutes of redline when i came into a complete stop the car went off immedietly. I immedietly contacted my tuner and he asked me to clean the throttle and i did it did work until i tried stepping on the pedal a little bit and heard an air leak ! Please solutions This is what i found after checking the intake manifold could it he the only reason? |
07-11-2017, 08:36 PM | #2 |
Seņor Member
Are you suggesting your manifold sprung a leak under the heat shielding?
1974 TA22 Celica
2013 86 GT |
The Following User Says Thank You to Turdinator For This Useful Post: | Diz86x (07-13-2017) |
07-12-2017, 07:32 PM | #3 |
07-12-2017, 07:53 PM | #4 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
That's odd sorry about your luck if it is melted. Replace it with a metal one
The Following User Says Thank You to go_a_way1 For This Useful Post: | Diz86x (07-13-2017) |
07-12-2017, 09:27 PM | #5 |
Seņor Member
It seems unlikely that would happen but not impossible. I assume you have checked all the piping from the turbo to the manifold for leaks already?
1974 TA22 Celica
2013 86 GT |
07-13-2017, 12:42 PM | #6 |
Drives: 2014 BRZ
That silver heat foil that you see is just that, the adhesive bond that mates it to the surface of underneath the manifold often degrades and makes it appear that there is a slit in the intake manifold. It has happened to me, and it is more than likely fine. You have more of a probability of those EVAP solenoid hoses popping off under boost....have you clamped them down? Best way to test is to do a smoke test.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
The Following User Says Thank You to Amputechture For This Useful Post: | Diz86x (07-13-2017) |
Similar Threads | ||||
2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
Intake Manifold | Fonzi | Engine, Exhaust, Bolt-Ons | 0 | 03-03-2016 08:29 PM |
Intake manifold | dallenj | Engine, Exhaust, Transmission | 0 | 11-02-2015 02:56 PM |
Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
Oil on/around Intake Manifold | Wepeel | Issues | Warranty | Recalls / TSB | 2 | 05-12-2014 11:40 PM |
