Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-30-2017, 01:37 AM | #1 |
Drives: Scion FR-S
Widest wheels without rubbing on stock springs with eibach springs ?
Whats the widest size you can go as far as measurements with stock struts and eibach springs with flush look
09-30-2017, 09:40 PM | #2 |
Drives: Toyota frs86
20x7 et42
10-01-2017, 02:04 AM | #3 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
17x9 or 18x9.5
Depends on offset for those, +42 is the highest offset you can run on a stock spring perch without running... can't remember what the highest offset is for the 18's. Also wrong section, @ichitaka05
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build Ceramic Coated Gruppe-S UEL/OP Konig Hypergrams RS4 200tw Koni Yellows, Eibach Springs Ferodo DS2500's
The Following User Says Thank You to Keenercarguy For This Useful Post: | H214M (10-07-2017) |
10-09-2017, 11:40 AM | #4 |
Drives: 2016 Scion FR-S
I'm running 18x9.5 +34 motis on stock springs, but I will add TRD springs soon. It will be close, but they will work.
10-09-2017, 11:41 AM | #5 |
Drives: Scion FR-S
Similar Threads | ||||
FS: stock BRZ springs, Eibach Pro Kit springs + Stock shocks (socal/OC) | tracerit | Brakes, Suspension, Chassis | 7 | 04-02-2016 12:04 PM |
Stock Wheels/Tires + Eibach Pro Springs | ChandlerSwyng | Wheels and Tires | 3 | 01-13-2015 10:16 PM |
Eibach Sportline springs with 20mm front and 25mm rear spacers on stock wheels | Calin | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 60 | 12-12-2014 02:25 PM |
Anyone have pics with eibach lower springs and stock wheels | Mrqb22 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 03-20-2013 04:24 AM |
