Old 11-05-2017, 07:51 PM   #1
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
Official FT86Club 3D printing thread!
Hello yall...
This thread is for all 3d printing nerds, newbs, and people who have Ideas or request for 3d printed parts but have no access and skills to make 3d stuff for the FRS/BRZ.
Please share your prints, ideas, like and contribute. Enjoy the show!
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
The Following User Says Thank You to FRSToyota86 For This Useful Post:
chaoskaze (11-20-2017)
Old 11-05-2017, 08:39 PM   #2
FRSToyota86
Here is the first little usefull thing someone made...
radio or the passengers side plastic panel clips
The Following 2 Users Say Thank You to FRSToyota86 For This Useful Post:
chaoskaze (11-20-2017), Stomachbuzz (01-16-2020)
Old 11-05-2017, 08:47 PM   #3
Borden
Drives: 2017 BRZ
I want a better armrest cup holder since day 1, with more storage compartment for cards, coins, tissue etc, and with a cover, for safety while intense driving. There's no such a thing online.
Borden is offline   Reply With Quote
The Following 2 Users Say Thank You to Borden For This Useful Post:
FRSToyota86 (11-07-2017), Monkey_Boy (12-27-2017)
Old 11-07-2017, 10:13 AM   #4
FRSToyota86
I am pretty sure I had seen 3 designs. I could find one of them right now. Is this close to what you had in mind
https://www.thingiverse.com/thing:1771749
The Following 7 Users Say Thank You to FRSToyota86 For This Useful Post:
Andrew025 (11-08-2017), chaoskaze (11-20-2017), Chimera (11-07-2017), Crashdummy (11-08-2017), Dadhawk (01-25-2020), Stomachbuzz (01-16-2020), wulfstan (12-08-2017)
Old 11-08-2017, 02:24 AM   #5
Borden
Drives: 2017 BRZ
yes, it's neat, what I want is pretty much like that, but full sized, with a cover, for mind peace, like the OEM one. But the OEM design has no those slots and compartments, makes it not so useful.
Old 11-08-2017, 11:21 AM   #6
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
subbed.
thatfilipinoguy is offline   Reply With Quote
The Following User Says Thank You to thatfilipinoguy For This Useful Post:
FRSToyota86 (11-09-2017)
Old 11-08-2017, 12:42 PM   #7
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Been thinking of some sort of mount/bracket (to put magnets on) for a phone that'll slip between the 2 dash/radio bezels and held in with one of the screws in there.
I'll eventually work on it...
The Following User Says Thank You to Andrew025 For This Useful Post:
Old 11-08-2017, 01:57 PM   #8
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2015 Q50S
Something with a curved bottom and flat top to go above the center vents or gauges would be cool, so you could put/mount something there...toll transponder, one of those solar tpms monitors, dash cam, whatever. Using suction cup mounts and double sided tape there is pretty meh.
BRZyJ is offline   Reply With Quote
The Following User Says Thank You to BRZyJ For This Useful Post:
Old 11-08-2017, 02:21 PM   #9
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
What I would like is a small insert for the driver side/passenger side cup holder for smaller drinks and items. Whenever I put stuff in the driver or passenger side cup holder it rattles around and drives me crazy. A handy insert to stop it from rattling and hold small items like sunglasses/flashlights or more skinny sized drinks would be great.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Old 11-08-2017, 06:57 PM   #10
syience
Drives: 2017 Toyota 86
Post from the phone mount thread
Originally Posted by syience View Post
Bought a Scoche Pro Mount and decided it would not stick well on the suede of the 2017 Toyota 86 dash. Did some tedious measurements and 3D printed a "sleeve" which would wrap around the dash and provide a nice adhesion surface.
3D modeled test design (1st attempt)
Full design with pro mount attached (3rd attempt)
Back side of dash
Final installation, decided to go with a blue finish (4th attempt)
syience is offline   Reply With Quote
The Following User Says Thank You to syience For This Useful Post:
Old 11-13-2017, 09:27 AM   #11
FRSToyota86
https://www.thingiverse.com/thing:2496041
check this out!
The Following 5 Users Say Thank You to FRSToyota86 For This Useful Post:
chaoskaze (11-20-2017), korhun (09-13-2019), mrntd (02-26-2021), Spankopotomous (01-11-2021), wulfstan (12-08-2017)
Old 11-16-2017, 09:48 AM   #12
FRSToyota86
Its truly is a pain to try to place a small coffee cup in the door cup holder and it would be easy to come up with an insert.
The opening is large enough to have a design that can have an insert for a cup and other things at the same time, although I am not certain that it is possible. its most likely going to have to be one or the other.
That being said you don't want to reinvent the wheel. Have you checked stuff that readily available at amazon and ect? For instance the attached photo is from a mass procured product called "cell cup"...
If you can do a design that works out of CAD and by CAD I mean cardboard , I am sure we can find someone who actually would do the 3d design for you. I am not promising that it would be me, since I am little too busy at the moment.
Anyways make sure that you search for a off the shelve item first... LMK
Old 11-16-2017, 11:26 AM   #13
Racecomp Engineering
Someone needs to 3D print a dash with a standard double din opening.
I realize that's a large item, but if it were pieced together and wrapped in leather it would be awesome.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
FRSToyota86 (11-17-2017), JohnJuan (11-20-2017), tehShirt (11-18-2017), thatfilipinoguy (11-18-2017)
Old 11-20-2017, 03:48 PM   #14
syience
- Andrew
Is a standard double din larger or smaller than the touchscreen opening that the car comes with?
Official DTM Autobody Services Thread for FT86Club! DTMAUTOBODY Southern California 9 12-31-2013 02:09 PM
Official FT86Club Chatroom? wrxgoose Site Announcements / Questions / Issues 13 09-15-2012 05:26 PM
Official FT86Club decal idea? Hanzo Scion FR-S / Toyota 86 GT86 General Forum 71 06-21-2012 08:09 PM
