Old 07-22-2012, 05:14 PM   #1
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Talking Lightweight pulley wow
Omg, hurry up and get one! I cant believe the difference in throttle response especially when your foot is completely off the pedal. Ive never bothered with mods like that before because i was skeptical.
So Please get rid of this
Replace it with that
Silverdub is offline   Reply With Quote
The Following 10 Users Say Thank You to Silverdub For This Useful Post:
baldolera (09-25-2012), BobDigi5060 (07-23-2012), canu_50 (09-13-2012), eriktherod (07-23-2012), gdi2290 (09-14-2012), Guff (07-24-2012), Kimsey47 (07-22-2012), Surok (08-15-2012), Tujin (07-23-2012), xpicer (09-01-2012)
Old 07-22-2012, 05:29 PM   #2
D1cker
Drives: B9 S4/ND2
Mine should be here on Monday, I was worried at first as most of the cars I've had, pulleys have caused issues with the oil pump, but the OEM pulley doesn't seem to have any harmonic balancing.
It's like a cheaper lightweight flywheel!
D1cker is offline   Reply With Quote
Old 07-22-2012, 05:37 PM   #3
bakerr6
Drives: 2013 raven black fr-s
buying mine today when I get off work
bakerr6 is offline   Reply With Quote
Old 07-22-2012, 05:44 PM   #4
luxmn
First FR-S
Drives: Whiteout MT FRS
Will this void warranty and can a newbie do the work?
luxmn is offline   Reply With Quote
Old 07-22-2012, 05:45 PM   #5
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
i was kinda wondering about the void to
kendalldwhite is offline   Reply With Quote
Old 07-22-2012, 05:46 PM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
They will use that as an excuse if something goes wrong later.
But if your chassis busts then your warranty will work because the pulley has No correlation to the actual chassis.
So all in all the dealer has to prove that the pulley is what broke whatever thing you're trying to get warranty on
Old 07-22-2012, 05:50 PM   #7
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Took me 10 minutes to install. Release belt tension with a 14mm wrench on the tensionner. Make sure you have a long and strong breaker bar put the car in 6th gear with the handbrake on and thats it. The crank bolt is on reallytight so dont be shy!
Old 07-22-2012, 05:50 PM   #8
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
I was a bit skeptical about these but I keep reading rave reviews. I am going to put this on my list of early upgrades.
Give this a read.
Apex Chase is offline   Reply With Quote
Old 07-22-2012, 05:51 PM   #9
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Should something happen, just put the origimal back on before you being thecar in for service.
The Following 3 Users Say Thank You to Silverdub For This Useful Post:
Obja (09-19-2012), Tomzilla (07-24-2012), TPO (07-28-2012)
Old 07-22-2012, 05:55 PM   #10
bakerr6
+1, I will be putting the original back on each time that I have to take it in for the complimentary service
Old 07-22-2012, 05:58 PM   #11
Don@Accelerated
Don@Accelerated's Avatar
Are the perrin units dampeners. It doesn't appear so?
Don@Accelerated is offline   Reply With Quote
Old 07-22-2012, 05:59 PM   #12
kendalldwhite
alright good because i already ordered one
Old 07-22-2012, 06:03 PM   #13
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
and don't post in this thread when you do
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-22-2012, 06:05 PM   #14
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
I'd want to reduce the weight at the back of the motor, too. Seems I won't have my warranty long...
Nezz is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
